查看: 9129|回复: 0
安装USB摄像头驱动后测试程序不出图像
发表于 2012-4-20 10:46:12 | 显示全部楼层 |阅读模式
wince6.0 在内核中加入了USB摄像头驱动,插摄像头串口提示
  1. RT2870:==> DllEntry
  2. RT2870: DLL_PROCESS_ATTACH
  3. Build Date: Dec 23 2008 Time: 17:52:15
  4. Release Driver Version: 0x01020305
  5. CPU=ARM
  6. PageSize=4096
  7. ProcessorLevel=4
  8. ProcessorRevision=0006
  9. --== TestMoveMemory ==--
  10. Case 1-1(pDest=pSrc+16)::NdisMoveMemory OK.
  11. Case 1-2(pDest=pSrc+16)::RtlMoveMemory OK.
  12. Case 2-1(pSrc=pDest+16)::NdisMoveMemory OK.
  13. Case 2-2(pSrc=pDest+16)::RtlMoveMemory OK.
  14. RT2870:<== DllEntry
  15. This device is not found in the supported USB device table.
  16. Device(VID=0x0ac8, PID=0x3330)RT2870:==> DllEntry
  17. RT2870: DLL_PROCESS_DETACH
  18. RT2870:<== DllEntry
  19. RT2870:==> DllEntry
  20. RT2870: DLL_PROCESS_ATTACH
  21. Build Date: Dec 23 2008 Time: 17:52:15
  22. Release Driver Version: 0x01020305
  23. CPU=ARM
  24. PageSize=4096
  25. ProcessorLevel=4
  26. ProcessorRevision=0006
  27. --== TestMoveMemory ==--
  28. Case 1-1(pDest=pSrc+16)::NdisMoveMemory OK.
  29. Case 1-2(pDest=pSrc+16)::RtlMoveMemory OK.
  30. Case 2-1(pSrc=pDest+16)::NdisMoveMemory OK.
  31. Case 2-2(pSrc=pDest+16)::RtlMoveMemory OK.
  32. RT2870:<== DllEntry
  33. This device is not found in the supported USB device table.
  34. Device(VID=0x0ac8, PID=0x3330)RT2870:==> DllEntry
  35. RT2870: DLL_PROCESS_DETACH
  36. RT2870:<== DllEntry
运行cameradshowapp 可以找到CAM2 ,但看不到图像,串口提示:
  1. CCaptureFramework: Starting the graph failed.
  2. CameraDShowApp: Starting the capture graph failed.
如何解决?
GMT+8, 2026-9-26 08:56
