查看: 11702|回复: 11
飞凌6410-android2.3 3G模块拨号
sunzhi 该用户已被删除
发表于 2012-5-28 11:05:29 | 显示全部楼层 |阅读模式
发表于 2012-5-28 17:07:13 | 显示全部楼层
电话里已经回复。
i.MX RT通行证
发表于 2012-7-2 17:45:27 | 显示全部楼层
/ # pppd call wcdma3812 &
/ # abort on (NO CARRIER)
abort on (ERROR)
abort on (NO DIALTONE)
abort on (BUSY)
abort on (NO ANSWER)
send (AT^M)
expect (OK)
AT^M^M
OK
-- got it
send (ATZ^M)
expect (OK)
^M
ATZ^M^M
OK
-- got it
send (AT+CGDCONT=1,\"IP\",\"3gnet\",,0,0^M)
expect (OK)
^M
AT+CGDCONT=1,"IP","3gnet",,0,0^M^M
OK
-- got it
send (AT+CFUN=1^M)
expect (OK)
^M
AT+CFUN=1^M^M
OK
-- got it
send (ATDT*99#^M)
expect (CONNECT)
^M
ATDT*99#^M^M
CONNECT
-- got it
send (^M)
Serial connection established.
Using interface ppp0
Connect: ppp0 <--> /dev/ttyUSB3
CHAP authentication succeeded
IPCP: timeout sending Config-Requests
Connection terminated.
abort on (OK)
abort on (BUSY)
abort on (DELAYED)
abort on (VOICE)
abort on (ERROR)
abort on (RINGING)
timeout set to 12 seconds
send (\K^M)
send (\K^M)
send (\K^M)
send (+++ATH^M)
send (+++ATH^M)
send (+++ATH^M)
send (ATZ^M)
Goodbay
Serial link disconnected.
Modem hangup
版主这个是怎么问题,该怎么解决?
i.MX RT通行证
发表于 2012-7-2 17:46:18 | 显示全部楼层
abort on (ERROR)
abort on (BUSY)
send (AT^M)
expect (OK)
AT^M^M
OK
-- got it
send (ATZ^M)
expect (OK)
^M
ATZ^M^M
OK
-- got it
expect (OK)
^M
OK
-- got it
send (AT+CFUN=1^M)
expect (OK)
^M
AT+CFUN=1^M^M
OK
-- got it
send (ATDT*99#^M)
expect (CONNECT)
^M
ATDT*99#^M^M
CONNECT
-- got it
send (^M)
abort on (OK)
abort on (BUSY)
abort on (DELAYED)
abort on (VOICE)
abort on (ERROR)
abort on (RINGING)
send (\K^M)
send (\K^M)
send (\K^M)
send (+++ATH^M)
send (+++ATH^M)
send (+++ATH^M)
send (ATZ^M)
Goodbay
Modem hangup
版主这个是怎么问题,该怎么解决?
发表于 2012-7-3 08:48:42 | 显示全部楼层
用的脚本对吗?还有楼主用的什么卡,是3G卡吗?能发出指令并收到指令,但是后面就出错了
i.MX RT通行证
发表于 2012-7-3 10:44:21 | 显示全部楼层
abort on (ERROR)
abort on (BUSY)
send (AT^M)
expect (OK)
AT^M^M
OK
-- got it
send (ATZ^M)
expect (OK)
^M
ATZ^M^M
OK
-- got it
expect (OK)
^M
OK
-- got it
send (AT+CFUN=1^M)
expect (OK)
^M
AT+CFUN=1^M^M
OK
-- got it
send (ATDT*99#^M)
expect (CONNECT)
^M
ATDT*99#^M^M
CONNECT
-- got it
send (^M)
Could not determine remote IP address: defaulting to 10.64.64.64
local  IP address 172.26.246.5
remote IP address 10.64.64.64
primary   DNS address 221.12.1.227
secondary DNS address 221.12.33.227
这样了,结果还是不能上网,该怎么办?
发表于 2012-7-3 12:55:05 | 显示全部楼层
这就奇怪了,已经能分配ip了怎么会不能上网呢?ping 一下外网试一下
i.MX RT通行证
发表于 2012-7-3 13:30:40 | 显示全部楼层
我Ping百度,谷歌都没有反应
发表于 2012-7-3 16:08:07 | 显示全部楼层
你ping一下ip,别ping 地址试试,如果还不行的话进行返修吧
i.MX RT通行证
发表于 2012-7-3 18:37:41 | 显示全部楼层
是数据线的问题,换了根好的线就可以了
发表于 2012-7-3 19:04:54 | 显示全部楼层
usb线的问题啊,没想到啊,换了一根什么样的线,是不是比以前的短了一些,还是有其它的不同呢?
xiaoanasi 该用户已被删除
发表于 2013-3-2 16:13:55 | 显示全部楼层
GMT+8, 2026-10-5 05:35
