查看: 9077|回复: 4
有没有在winc下,ov9650拍照的应用程序啊
josh915 该用户已被删除
发表于 2010-7-22 15:45:09 | 显示全部楼层 |阅读模式
发表于 2010-7-23 09:58:41 | 显示全部楼层
看是不是可以参考如下代码
*  SAVE PICTURE
void CCameraTest2Dlg::OnBnClickedSave()
        int        pic_size=320*240*2;                        //图形缓冲区大小
        int        nBytesRead;                        //读取的数据长度
        unsigned char *bufOut;
        BOOL f;
        bufOut=(unsigned char *)malloc(pic_size);
        f=ReadFile(hCam,bufOut,pic_size,(LPDWORD)&nBytesRead,NULL);
        BITMAPINFO   RGB16BitsBITMAPINFO;
    ZeroMemory(&RGB16BitsBITMAPINFO,   sizeof(BITMAPINFO));
    RGB16BitsBITMAPINFO.bmiHeader.biSize   =   sizeof(BITMAPINFOHEADER);
    RGB16BitsBITMAPINFO.bmiHeader.biWidth   =   320;
    RGB16BitsBITMAPINFO.bmiHeader.biHeight   =   240;
    RGB16BitsBITMAPINFO.bmiHeader.biPlanes   =   1;
    RGB16BitsBITMAPINFO.bmiHeader.biBitCount   =   16;
    RGB16BitsBITMAPINFO.bmiHeader.biCompression        = BI_BITFIELDS;
        //在填充数据
        BITMAPFILEHEADER   bmBITMAPFILEHEADER;
        ZeroMemory(&bmBITMAPFILEHEADER,   sizeof(BITMAPFILEHEADER));
        bmBITMAPFILEHEADER.bfType   =   0x4d42;     //bmp
    bmBITMAPFILEHEADER.bfOffBits   =   sizeof(BITMAPFILEHEADER)   +   sizeof(BITMAPINFOHEADER) +16/*调色板结构大小*/;
    bmBITMAPFILEHEADER.bfSize   =   bmBITMAPFILEHEADER.bfOffBits   +   (pic_size);   ///2=(16   /   8)
#if 0//待调试
        //停止采集
        f = DeviceIoControl (hCam, IOCTL_CAM_STOP,
                                                 NULL, 0,
                                                 NULL, 0, NULL, NULL);
        if(!f)
                printf("IOCTL_CAM_STOP wrong!\n");
        else
                Bplay->SetWindowText(_T("play"));
                CAM_PLAY=0;
        CFileDialog Save(false /*如果为真则对话框为打开对话框,为否则为保存对话框*/,
        TEXT("bmp") /*默认后缀名*/,
        TEXT("cam") /*默认文件名*/,
        0 /*对话框风格*/,
        TEXT("bmp|*.bmp|"),
        this /*父窗口指针*/);
        CString strFilePath;
        if (Save.DoModal() == IDOK)
                strFilePath = Save.GetPathName();
        //CString 转char *  用了Unicode字符集,CString是宽字符
            wchar_t* wCharString = strFilePath.GetBuffer(strFilePath.GetLength()+1);
        size_t origsize = wcslen(wCharString) + 1;
        char *name;
        name=new char(origsize);
        wcstombs(name,  wCharString ,origsize);
                printf("%s\n",name);
#else
        static int file_index=0;
        char name[64];
        memset(name, 0, sizeof(name));
        sprintf(name, "%s%02d.jpg", "cam", file_index++);
#endif
    FILE   *mStream   =   NULL;
        if((mStream   =   fopen(name,"wb")))
                //write   bitmap   file   header
                fwrite(&bmBITMAPFILEHEADER, sizeof(BITMAPFILEHEADER), 1, mStream);
                //write   bitmap   info
                fwrite(&(RGB16BitsBITMAPINFO.bmiHeader), sizeof(BITMAPINFOHEADER), 1, mStream);
                //write palette    info
                fwrite(&RGB565, 16, 1, mStream);
                //write   bitmap   pixels   data
                fwrite(bufOut, pic_size, 1, mStream);
                //close   file
                fclose(mStream);
                printf("save pic %s done\n",name);
        else
                printf("open %s fail\n",name);
csk0411 该用户已被删除
发表于 2010-12-10 09:14:15 | 显示全部楼层
csk0411 该用户已被删除
发表于 2010-12-10 09:14:57 | 显示全部楼层
胖丁 该用户已被删除
发表于 2012-4-9 15:07:11 | 显示全部楼层
GMT+8, 2026-9-29 13:02
