查看: 4003|回复: 3
rcS内容
kaitianjian 该用户已被删除
发表于 2012-6-3 17:53:25 | 显示全部楼层 |阅读模式
发表于 2012-6-3 20:23:19 | 显示全部楼层
怎么就不网上查一下呢?
mount命令有这么难吗?
jhk@ubuntu:~/# mount --help
Usage: mount -V                 : print version
       mount -h                 : print this help
       mount                    : list mounted filesystems
       mount -l                 : idem, including volume labels
So far the informational part. Next the mounting.
The command is `mount [-t fstype] something somewhere'.
Details found in /etc/fstab may be omitted.
       mount -a [-t|-O] ...     : mount all stuff from /etc/fstab
       mount device             : mount device at the known place
       mount directory          : mount known device here
       mount -t type dev dir    : ordinary mount command
Note that one does not really mount a device, one mounts
a filesystem (of the given type) found on the device.
One can also mount an already visible directory tree elsewhere:
       mount --bind olddir newdir
or move a subtree:
       mount --move olddir newdir
One can change the type of mount containing the directory dir:
       mount --make-shared dir
       mount --make-slave dir
       mount --make-private dir
       mount --make-unbindable dir
One can change the type of all the mounts in a mount subtree
       mount --make-rshared dir
       mount --make-rslave dir
       mount --make-rprivate dir
       mount --make-runbindable dir
A device can be given by name, say /dev/hda1 or /dev/cdrom,
or by label, using  -L label  or by uuid, using  -U uuid .
Other options: [-nfFrsvw] [-o options] [-p passwdfd].
For many more details, say  man 8 mount .
kaitianjian 该用户已被删除
 楼主| 发表于 2012-6-4 11:05:21 | 显示全部楼层
发表于 2012-6-4 16:53:27 | 显示全部楼层
/bin/echo /sbin/mdev > /proc/sys/kernel/hotplug
这一句是写入
mdev -s
这一句是执行
详细请查mdev的使用方法和原理。
GMT+8, 2026-10-5 18:21
