查看: 10503|回复: 2
版主看看我的板子是怎么回事
发表于 2012-6-7 15:15:35 | 显示全部楼层 |阅读模式
前段时间用的好好的,这两天不好使了。系统起不来,用SD卡重新烧程序也不成功,这下是不是没招了,看看我还能干点什么。不行就得寄给你们返修了
下面是sd卡烧系统的log,读完filesize就不动了
Welcome! This tool just for TE/OK6410
+OALArgsInit()
SocID:0x36410101
Arguments area is initialized
-OALArgsInit()
INFO: (unsigned)C_IsrHandler : 0x800668C4
INFO: (unsigned)ASM_IsrHandler : 0x80069F80
INFO: (unsigned)pISR : 0xEA01A7D8
HSMMC init
[HSMMC1] Setting registers for the EPLL (for SDCLK) : SYSCon.
[HSMMC0] Setting registers for the GPIO.
[HSMMC1] Setting registers for the EPLL : HSMMCCon.
#### this SD card is made on SPEC 2.0
This SD card is made on SPEC 2.0
CardSize: 504365056
[HSMMCLIB:INF] ClockConfig() Card Working Frequency = 24MHz
BP_Init
[FMD] ++FMD_Init() ****
[FMD:INF] FMD_Init() : Read ID = 0x0000ecd5
[FMD] FMD_Init() : NUM_OF_BLOCKS = 4096
[FMD] FMD_Init() : SECTORS_PER_PAGE = 8
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 4096(0x1000), SECTORSPERBLOCK = 128(0x80), BYTESPERSECTOR = 4096(0x1000)
wNUM_BLOCKS : 4096(0x1000)
[Eboot] ++InitializeDisplay()
[Eboot] --InitializeDisplay()
Initiating image launch -1 seconds.
Starting auto-download ...
Erase  the block '0..3'
System ready!
Preparing for download...
IsCardInserted
f_mount return = 0x0
FileInfo.fsize = 0x2000
g_pDownPt = 0xA300211B
BL_IMAGE_TYPE_MANIFEST
BL_IMAGE_TYPE_UNKNOWN
Download BIN file information:
[0]: Base Address=0x0  Length=0x2000
Stepldr image
ImageStart = 0x0, ImageLength = 0x2000, LaunchAddr = 0x0
Completed file(s):
[0]: Address=0x0  Length=0x2000  Name="stepldr.nb0" Target=RAM
BP_Init  iSighForSlcMlc = 1
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 8192(0x2000), SECTORSPERBLOCK = 8(0x8), BYTESPERSECTOR = 2048(0x800)
dwImageLength = 0x2000
dwNumBlocks = 0x1
dwBlock(0x0) X g_FlashInfo.wSectorsPerBlock(0x8) = 0x0
dwBytesPerBlock : 16384
INFO: Step loader image stored to Smart Media.  Please Reboot.  Halting...
IsCardInserted
FileInfo.fsize = 0x1C81B
g_pDownPt = 0xA301C81B
BL_IMAGE_TYPE_BIN
[0]: Base Address=0x80030000  Length=0x1d86c
Eboot image
rom_offset=0x0.
ImageStart = 0x80030000, ImageLength = 0x1D86C, LaunchAddr = 0x800420C0
Completed file(s):
[0]: Address=0x80030000  Length=0x1D86C  Name="" Target=RAM
ROMHDR at Address 80030044h
BP_Init  iSighForSlcMlc = 0
[FMD] --FMD_Init()
dwImageLength = 0x1d86c
dwNumBlocks = 0x1
dwBlock(0x2) X g_FlashInfo.wSectorsPerBlock(0x80) = 0x100
dwBytesPerBlock : 524288
TOC {
dwSignature: 0x434F544E
BootCfg {
  ConfigFlags: 0x20830
  BootDelay: 0x1
  ImageIndex: 1
  IP: 0.0.0.0
  MAC Address: 00:00:00:00:00:00
  Port: 0.0.0.0
  SubnetMask: 255.255.255.0
ID[0] {
  dwVersion: 0x20004
  dwSignature: 0x45424F54
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x1E
  dwLoadAddress: 0x80030000
  dwJumpAddress: 0x800420C0
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x100
  sgList[0].dwLength: 0x1E
ID[1] {
  dwVersion: 0x1
  dwSignature: 0x43465348
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x0
  dwLoadAddress: 0x0
  dwJumpAddress: 0x0
  dwStoreOffset: 0x0
chainInfo.dwLoadAddress: 0X00000000
chainInfo.dwFlashAddress: 0X00000000
chainInfo.dwLength: 0X00000000
INFO: Eboot image stored to Smart Media.  Please Reboot.  Halting...
Reserving Blocks [0x0 - 0x2] ...
...reserve complete.
Enter LowLevelFormat [0x3, 0xfff].
Erasing flash block(s) [0x3, 0xfff] (please wait): EraseBlocks: found a bad block (0x46f) - skipping...
EraseBlocks: found a bad block (0x586) - skipping...
EraseBlocks: found a bad block (0x587) - skipping...
EraseBlocks: found a bad block (0x588) - skipping...
EraseBlocks: found a bad block (0x589) - skipping...
EraseBlocks: found a bad block (0x96c) - skipping...
EraseBlocks: found a bad block (0xade) - skipping...
Done.
WriteMBR: MBR block = 0x3.
Done.
BinFS format done.
IsCardInserted
FileInfo.fsize = 0x23F940B
 楼主| 发表于 2012-6-7 15:17:34 | 显示全部楼层
等了好长时间又蹦出来这么两句
[HSMMCLIB:INF] IssueCommand() Command NOT Complete 0x8000 0x100
[HSMMCLIB:ERR] ReadFrommoviNAND() FAIL OUT-----------
 楼主| 发表于 2012-6-8 09:26:50 | 显示全部楼层
版主哪去了?我这项目急用呢,要是板子有问题就赶紧返修了,怎么等了一天也没人回复
GMT+8, 2026-9-26 05:49
