查看: 3656|回复: 2
OK6410正常启动Linux2.6.28,一分钟之内程序跑飞了
发表于 2012-6-10 09:21:08 | 显示全部楼层 |阅读模式
串口打印如下:
[root@OK6410 /]#
[root@OK6410 /]#
[root@OK6410 /]# Unable tn handle kernel paging request at virtual address 804e459c
pgd = c0004000
[804e459c] *pgd=00000000
Internal error: Oops: 5 [#1]
Modules linked in:
CPU: 0    Not tainted  (2.6.28.6 #238)
PC is at scheduler_tick+0x2c/0xac
LR is at sched_clock_cpu+0x2c/0x38
pc : [<c004aca0>]    lr : [<c00662d >]    psr: 20000193
sp : c04ade60  ip : c04ade50  fp : c04ade84
r10: d0024d24  r9 : 410fb766  r8 : c04afa80
r7 : 00000064  r6 : 00000000  r5 : 00000000  r4 : 804e4568
r3 : c04b8140  r2 : 004c4b40  r1 : 004c4b14  r0 : 249232c0
Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 00c5387d  Table: 5f4d8008  DAC: 00000017
Process swapper (pid: 0, stack limit = 0xc04ac260)
Stack: (0xc04ade60 to 0xc04ae000)
de60: 410fb766 00000000 c04afa80 00000000 00000064 50024d58 c04ade9c c04ade88
de80: c0057264 c004ac80 c04b8be4 00000000 c04adeb4 c04adea0 c00318d4 c0057220
dea0: c04b5df8 00000000 c04adec4 c04adeb8 c0039498 c00317f0 c04adee4 c04adec8
dec0: c00709d8 c0039494 c04bad0c 00000064 c04b5df8 c04bad40 c04adf04 c04adee8
dee0: c00726fc c00709a8 0000003c 00000000 00000003 c04e2424 c04adf14 c04adf08
df00: c0037c78 c0072604 c04adf24 c04adf18 c0037cf8 c0037c4c c04adf3c c04adf28
df20: c002d064 c0037cf0 ffffffff f4000000 c04adf94 c04adf40 c002da34 c002d00c
df40: c04e4568 00000000 f4100000 00000021 c002f408 c04ac000 c002f408 c04e2424
df60: 50024d58 410fb766 d0024d24 c04adf94 c04adf88 c04adf88 c0037864 c002f458
df80: a0000013 ffffffff c04adfb4 c04adf98 c002f2c8 c002f414 c05091e0 c04e1fc8
dfa0: c0026f00 c04b0768 c04adfc4 c04adfb8 c0366460 c002f2a0 c04adff4 c04adfc8
dfc0: c0008bb0 c0366418 c0008518 00000000 00000000 c0026f00 00000000 00c5387d
dfe0: c04e2494 c0027304 00000000 c04adff8 50008034 c000894c 00000000 00000000
Backtrace:
[<c004ac74>] (scheduler_tick+0x0/0xac) from [<c0057264>] (update_process_times+0x50/0x5c)
r8:50024d58 r7:00000064 r6:00000000 r5:c04afa80 r4:00000000
[<c0057214>] (update_process_times+0x0/0x5c) from [<c00318d4>] (timer_tick+0xf0/0x118)
r5:00000000 r4:c04b8be4
[<c00317e4>] (timer_tick+0x0/0x118) from [<c0039498>] (s3c2410_timer_interrupt+0x10/0x18)
r5:00000000
求高手们帮分析一下这是什么问题,多谢啦
发表于 2012-6-11 09:54:38 | 显示全部楼层
信息太少,2.6.28很久不更新了,建议使用最新的3.0.1
 楼主| 发表于 2012-6-11 21:49:43 | 显示全部楼层
多谢楼上,现在系统已经稳定了,成功格式化nand flash后,就没有烧写的问题了
GMT+8, 2026-10-5 17:05
