查看: 9720|回复: 9
nfs挂载网络文件系统问题
发表于 2012-7-27 17:07:59 | 显示全部楼层 |阅读模式
我用的是ok6410A板256Mnandflash的板子,都是按照光盘里OK6410-A开发板LINUX3.0.1用户手册操作,用的文件也都是光盘里带的,就是挂载不成功
U-Boot 1.1.6 (Feb  4 2012 - 18:07:29) for SMDK6410
**    Updated for OK6410  TE6410 Board  **
**    Version (2012-02-04)          **
CPU:     S3C6410 @532MHz
Board:   SMDK6410
DRAM:    256 MB
Flash:   0 kB
NAND:    2048 MB
In:      serial
Out:     serial
Err:     serial
NAND read: device 0 offset 0x100000, size 0x500000
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
Linux version 3.0.1 (root@forlinx) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #348 Fri Feb 10 09:58:08 CST 2012
Kernel command line: root=/dev/nfs nfsroot=172.18.123.110:/forlinx/root ip=172.18.123.123:172.18.123.110:172.18.123.1:255.255.255.0:witech.com.cn:eth1:off console=ttySAC0,115200
PID hash table entries: 1024 (order: 0, 4096 bytes)
Memory: 256MB = 256MB total
Memory: 197672k/197672k available, 64472k reserved, 0K highmem
Virtual kernel memory layout:
    vmalloc : 0xd0800000 - 0xf4000000   ( 568 MB)
    lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
      .init : 0xc0008000 - 0xc0033000   ( 172 kB)
      .text : 0xc0033000 - 0xc06f570c   (6922 kB)
      .data : 0xc06f6000 - 0xc0736fc8   ( 260 kB)
       .bss : 0xc0736fec - 0xc07b4848   ( 503 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:246 nr_irqs:246 246
console [ttySAC0] enabled
Calibrating delay loop... 528.79 BogoMIPS (lpj=2643968)
devtmpfs: initialized
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
PL080: IRQ 73, at d0804000, channels 0..8
PL080: IRQ 74, at d0806000, channels 8..16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
------------[ cut here ]------------
WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x58/0x124()
---[ end trace da227214a82491b7 ]---
中间省略
[<c0039ca8>] (unwind_backtrace+0x0/0xfc) from [<c04a044c>] (dump_stack+0x18/0x1c)
[<c04a044c>] (dump_stack+0x18/0x1c) from [<c04a04b0>] (panic+0x60/0x1ac)
[<c04a04b0>] (panic+0x60/0x1ac) from [<c0008fd0>] (mount_block_root+0x204/0x25c)
[<c0008fd0>] (mount_block_root+0x204/0x25c) from [<c00090b0>] (mount_root+0x88/0xd0)
[<c00090b0>] (mount_root+0x88/0xd0) from [<c0009204>] (prepare_namespace+0x10c/0x1a8)
[<c0009204>] (prepare_namespace+0x10c/0x1a8) from [<c00084c4>] (kernel_init+0xf0/0x130)
[<c00084c4>] (kernel_init+0xf0/0x130) from [<c0034a34>] (kernel_thread_exit+0x0/0x8)
本人菜鸟,望大家多多赐教!
发表于 2012-7-28 09:06:10 | 显示全部楼层
能ping通吗?看一下网络能不能通,然后检查nfs服务启动没有,再查参数设置是不是正确
 楼主| 发表于 2012-7-28 12:10:03 | 显示全部楼层
多谢!挂上了,是因为设置Uboot时,指令少了个空格
zdyanshi 该用户已被删除
发表于 2012-7-30 09:10:15 | 显示全部楼层
发表于 2012-7-30 13:06:16 | 显示全部楼层
能打开的,设置好串口就可以了
 楼主| 发表于 2012-8-4 10:04:15 | 显示全部楼层
我挂载根文件系统到宿主机已经完成,但是挂载目录文件到宿主机总是不成
我先将/etc/exports的最后一行改成/ *(rw,sync,no_root_squash)了,然后重新启动了nfs执行语句和报错如下,之前看到有人问同样问题,版主让下个新版本的linux3.0.1,可我昨天刚下了新版本(5月版)还是不行
mount -t nfs -o nolock 172.18.123.110:/mnt/share /temp/shared
mount: cannot read /etc/fstab: No such file or directory
求版主赐教呀!
 楼主| 发表于 2012-8-4 10:23:13 | 显示全部楼层
我到FileSystem-Yaffs2/etc下确实找不到fstab这个文件,从别处考个fstab到FileSystem-Yaffs2/etc也都不好用,不过错误变成了mount: can't find 172.1d in /etc/fstab
 楼主| 发表于 2012-8-4 14:07:44 | 显示全部楼层
解决了,很奇怪,不知咋的就好了,啥也没改!哎!
发表于 2012-8-6 08:35:46 | 显示全部楼层
以前不成功可能与网络或者nfs服务设置有问题
 楼主| 发表于 2012-10-5 20:56:30 | 显示全部楼层
今天重新挂载网络文件系统遇到同样问题,不过这次找到原因了,写出了给大家分享下,原因竟然是PC机上的Yaffs2文件系统有问题,换了个文件系统重新解压就好用了。
GMT+8, 2026-10-5 09:51
