查看: 4835|回复: 4
关于OK6410一键烧写linux的问题 求教
i.MX6Q通行证
发表于 2012-9-2 11:53:37 | 显示全部楼层 |阅读模式
按照pdf手册上的过程做了sd(4g)并烧写,但启动后dnw输出如下:
K
U-Boot 1.1.6 (Mar 23 2011 - 15:19:29) for SMDK6410
CPU:     S3C6410 @532MHz
Board:   SMDK6410
DRAM:    128 MB
Flash:   0 kB
NAND:    tmp = 95
256 MB
SD/MMC:  3724 MB (SDHC)
*** Warning - bad CRC or moviNAND, using default environment
In:      serial
Out:     serial
Err:     serial
Erasing at 0x0 --   0
Erasing at 0x280000 --   1plete.
Erasing at 0x500000 --   2plete.
Erasing at 0xffe0000 -- 100mplete.
OK
reading u-boot.bin
196608 bytes read
NAND write: device 0 offset 0x0, size 0x100000
1048576 bytes written: OK
reading zImage
2735808 bytes read
NAND write: device 0 offset 0x100000, size 0x500000
Writing data at 0x100000 --   0
Writing data at 0x10c800 --   1
Writing data at 0x119800 --   2
Writing data at 0x126000 --   3
Writing data at 0x5f3000 --  99
Writing data at 0x5ff800 -- 100ten: OK
reading cramfs
31301632 bytes read
NAND write: device 0 offset 0x600000, size 0x7800000
Writing data at 0x600000 --   0
Writing data at 0x733000 --   1
Writing data at 0x7dff800 -- 100ritten: OK
SMDK6410 # KK
U-Boot 1.1.6 (Jan 19 2011 - 14:08:29) for SMDK6410
Board:   SMDK6410
DRAM:    128 MB
Flash:   0 kB
NAND:    256 MB
*** Warning - bad CRC or NAND, using default environment
In:      serial
Out:     serial
Err:     serial
NAND read: device 0 offset 0x100000, size 0x300000
3145728 bytes read: OK
Boot with zImage
Starting kernel ...
Uncompressing Linux.................................................................................................................................................................................. done, booting the kernel.
Linux version 2.6.28.6 (root@fatfish-desktop) (gcc version 4.2.2) #253 Thu Apr 7 17:55:28 CST 2011
CPU: ARMv6-compatible processor [410fb766] revision 6 (ARMv7), cr=00c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: SMDK6410
CPU S3C6410 (id 0x36410101)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C64XX: HCLKx2=266000000, HCLK=133000000, PCLK=66500000
div1: 00000555
mout_epll: source is fout_epll (1), rate is 24000000
mmc_bus: source is dout_mpll (1), rate is 44333333
usb-host-bus: source is mout_epll (0), rate is 24000000
audio-bus0: source is mout_epll (0), rate is 24000000
audio-bus1: source is mout_epll (0), rate is 24000000
audio-bus2: source is mout_epll (0), rate is 24000000
s3c64xx: 15728640 bytes SDRAM reserved for fimc at 0x506d3000
s3c64xx: 8388608 bytes SDRAM reserved for pp at 0x515d3000
s3c64xx: 8388608 bytes SDRAM reserved for tv at 0x51dd3000
s3c64xx: 6291456 bytes SDRAM reserved for mfc at 0x525d3000
s3c64xx: 8388608 bytes SDRAM reserved for jpeg at 0x52bd3000
s3c64xx: 8388608 bytes SDRAM reserved for cmm at 0x533d3000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: root=/dev/mtdblock2 rootfstype=cramfs console=ttySAC0,115200
PID hash table entries: 512 (order: 9, 2048 bytes)
s3c24xx_serial_init_ports: initialising ports=4...
console [ttySAC0] enabled
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 69560KB available (5156K code, 580K data, 156K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 530.84 BogoMIPS (lpj=1327104)
net_namespace: 316 bytes
s3c-sdhci s3c-sdhci.0: clock source 2: mmc_bus (44333333 Hz)
sdhci: card inserted.
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (44333333 Hz)
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.18rc3.
ASoC version 0.13.2
WM9713/WM9714 SoC Audio Codec 0.15
playback: 1, capture : 1
asoc: AC97 HiFi <-> s3c64xx-ac97 mapping ok
mmc0: new high speed SDHC card at address 1234
mmcblk0: mmc0:1234 SA04G 3.63 GiB
mmcblk0: p1
[WM9713]Open speaker volume.
ALSA device list:
  #0: SMDK6400 (WM9713)
TCP cubic registered
can: controller area network core (rev 20081130 abi 8)
can: raw protocol (rev 20081130)
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
s3c2410-rtc s3c2410-rtc: hctosys: invalid date/time
mtd->size = 5000000 blocks = 280
cheaking bad block...............
................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................List of all partitions:
1f00             256 mtdblock0 (driver?)
1f01            3840 mtdblock1 (driver?)
1f02           81920 mtdblock2 (driver?)
1f03          176128 mtdblock3 (driver?)
b300         3813376 mmcblk0 driver: mmcblk
  b301         3710976 mmcblk0p1
No filesystem could mount root, tried:  cramfs Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2)
并且屏幕上只有背光 没有任何信息!!!请问我的问题处在了那?
发表于 2012-9-3 08:52:30 | 显示全部楼层
你好 请帖出更多信息,以便协助楼主解决问题。
另外请看我的签名
i.MX6Q通行证
 楼主| 发表于 2012-9-3 13:00:13 | 显示全部楼层
2.6.36成功了 但2.6.28不成功回复 2# 飞凌-fatfish
发表于 2012-9-3 16:50:50 | 显示全部楼层
把开发板的型号、nandflash型号、烧写文件的来源(比如来源于光盘)、操作的步骤、以及所有打印的串口信息(这个很重要)写出来.如果有特殊情况,也可以在附件中添加截图
i.MX6Q通行证
 楼主| 发表于 2012-9-4 20:35:53 | 显示全部楼层
先谢了 我先用这个能用的吧
回复 4# 飞凌-fatfish
GMT+8, 2026-10-5 11:08
