查看: 2770|回复: 2
求救,linux3.0.1烧成功后进系统黑屏
发表于 2012-10-4 18:40:04 | 显示全部楼层 |阅读模式
我根据OK6410-A开发板LINUX3.0.1用户手册去做的,烧成功,但重启进不去,先是白了一下,屏幕就黑了,什么反应都没,怎么办?
KK
U-Boot 1.1.6 (Feb  4 2012 - 18:04:44) for SMDK6410
**    Updated for OK6410  TE6410 Board  **
**    Version (2012-02-04)          **
CPU:     S3C6410 @532MHz
Board:   SMDK6410
DRAM:    128 MB
Flash:   0 kB
NAND:    2048 MB
In:      serial
Out:     serial
Err:     serial
NAND read: device 0 offset 0x100000, size 0x500000
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
Linux version 3.0.1 (root@forlinx) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #425 Mon May 7 16:56:20 CST 2012
Kernel command line: root=/dev/mtdblock2 rootfstype=yaffs2 console=ttySAC0,115200
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 67672k/67672k available, 63400k reserved, 0K highmem
Virtual kernel memory layout:
    vmalloc : 0xc8800000 - 0xf4000000   ( 696 MB)
    lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
      .init : 0xc0008000 - 0xc0034000   ( 176 kB)
      .text : 0xc0034000 - 0xc0701080   (6965 kB)
      .data : 0xc0702000 - 0xc0744330   ( 265 kB)
       .bss : 0xc0744354 - 0xc07c1ce0   ( 503 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:246 nr_irqs:246 246
console [ttySAC0] enabled
Calibrating delay loop... 528.79 BogoMIPS (lpj=2643968)
devtmpfs: initialized
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
PL080: IRQ 73, at c8804000, channels 0..8
PL080: IRQ 74, at c8806000, channels 8..16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
------------[ cut here ]------------
WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x58/0x124()
---[ end trace da227214a82491b7 ]---
usbcore: registered new inte**ce driver usbfs
usbcore: registered new inte**ce driver hub
Advanced Linux Sound Architecture Driver Version 1.0.23.
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
RPC: Registered named UNIX socket transport module.
audit: initializing netlink socket (disabled)
type=2000 audit(0.270:1): initialized
msgmni has been set to 132
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
LCD TYPE :: LTE480WV will be initialized
Console: switching to colour frame buffer device 60x34
s3c6400-uart.0: ttySAC0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: ttySAC1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: ttySAC2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: ttySAC3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
gspca_gl860: driver startup - version 0.9d10
usbcore: registered new inte**ce driver gspca_gl860
gspca_gl860: driver registered
s3c-fimc: info ov965x_init
cym s3c_mfc_mememap: addr:55af9000 size:1138688
S3C6400 MFC Driver, (c) 2007 Samsung Electronics
S3C PostProcessor Driver v3.12, (c) 2009 Samsung Electronics
S3C6410 TV encoder Driver, (c) 2008 Samsung Electronics
S3C6410 TV scaler Driver, (c) 2008 Samsung Electronics
S3C Rotator Driver, (c) 2008 Samsung Electronics
s3c_rotator_probe called
S3C JPEG Driver, (c) 2007 Samsung Electronics
s3c_g2d_probe called
s3c_g2d_probe Success
S3C G3D Driver, (c) 2007-2009 Samsung Electronics
S3C CMM Driver, (c) 2008 Samsung Electronics
usbcore: registered new inte**ce driver uvcvideo
USB Video Class driver (v0.1.0)
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (24000000 Hz)
usbhid: USB HID core driver
mmc0: new SDHC card at address b368
asoc: wm9713-hifi <-> samsung-ac97 mapping ok
mmcblk0: mmc0:b368 SD08G 7.41 GiB
mmcblk0: p1
ALSA device list:
  #0: smdk6410
TCP cubic registered
s3c-rtc s3c64xx-rtc: setting system clock to 2000-01-01 01:18:00 UTC (946689480)
yaffs: passed flags ""
devtmpfs: error mounting -2
Freeing init memory: 176K
[<c003aca8>] (unwind_backtrace+0x0/0xfc) from [<c04a7d84>] (dump_stack+0x18/0x1c)
[<c04a7d84>] (dump_stack+0x18/0x1c) from [<c04a7de8>] (panic+0x60/0x1ac)
[<c04a7de8>] (panic+0x60/0x1ac) from [<c00345dc>] (init_post+0xc8/0x140)
[<c00345dc>] (init_post+0xc8/0x140) from [<c00084c8>] (kernel_init+0xf4/0x130)
[<c00084c8>] (kernel_init+0xf4/0x130) from [<c0035a34>] (kernel_thread_exit+0x0/0x8)
xuexi0282016 该用户已被删除
发表于 2012-10-12 20:27:10 | 显示全部楼层
发表于 2012-10-13 10:33:55 | 显示全部楼层
有可能是别的原因,贴下具体操作步骤和每一个烧写映像的来源。
GMT+8, 2026-10-5 09:51
