查看: 9743|回复: 3
alsa arecord录音
发表于 2010-8-17 09:26:43 | 显示全部楼层 |阅读模式
移植alsa-lib alsa-utils到开发板
运行 arecord -t wav -f dat myrecord.wav录音
运行 aplay myrecord.wav 没有声音
请问怎么解决?谢谢。
运行 alsactl store -f asound.state获得alsa相关状态数据
state.SMDK6400 {
        control.1 {
                comment.access 'read write'
                comment.type INTEGER
                comment.count 2
                comment.range '0 - 31'
                iface MIXER
                name 'Speaker Playback Volume'
                value.0 31
                value.1 31
        control.2 {
                comment.type BOOLEAN
                comment.count 2
                iface MIXER
                name 'Speaker Playback Switch'
                value.0 true
                value.1 true
        control.3 {
                comment.count 2
                iface MIXER
                name 'Headphone Playback Volume'
                value.0 31
                value.1 31
        control.4 {
                comment.count 2
                iface MIXER
                name 'Headphone Playback Switch'
                value.0 true
                value.1 true
        control.5 {
                comment.count 2
                iface MIXER
                name 'Line In Volume'
                value.0 23
                value.1 23
        control.6 {
                comment.count 2
                iface MIXER
                name 'PCM Playback Volume'
                value.0 23
                value.1 23
        control.7 {
                comment.count 1
                iface MIXER
                name 'Mic 1 Volume'
                value 23
        control.8 {
                comment.count 1
                iface MIXER
                name 'Mic 2 Volume'
                value 23
        control.9 {
                comment.count 1
                iface MIXER
                name 'Mic Boost (+20dB) Switch'
                value true
        control.10 {
                comment.count 1
                comment.range '0 - 7'
                iface MIXER
                name 'Mic Headphone Mixer Volume'
                value 5
        control.11 {
                comment.count 1
                iface MIXER
                name 'Capture Switch'
                value true
        control.12 {
                comment.type ENUMERATED
                comment.count 2
                comment.item.0 '+1.5dB Steps'
                comment.item.1 '+0.75dB Steps'
                iface MIXER
                name 'Capture Volume Steps'
                value.0 '+1.5dB Steps'
                value.1 '+1.5dB Steps'
        control.13 {
                comment.count 2
                iface MIXER
                name 'Capture Volume'
                value.0 15
                value.1 15
        control.14 {
                comment.count 1
                iface MIXER
                name 'Capture ZC Switch'
                value true
        control.15 {
                comment.count 1
                iface MIXER
                name 'Capture to Headphone Volume'
                value 5
        control.16 {
                comment.count 1
                iface MIXER
                name 'Capture to Mono Boost (+20dB) Switch'
                value true
        control.17 {
                comment.count 1
                iface MIXER
                name 'Capture ADC Boost (+20dB) Switch'
                value true
        control.18 {
                comment.count 1
                comment.range '0 - 15'
                iface MIXER
                name 'ALC Target Volume'
                value 11
        control.19 {
                comment.count 1
                iface MIXER
                name 'ALC Hold Time'
                value 0
        control.20 {
                comment.count 1
                iface MIXER
                name 'ALC Decay Time'
                value 3
        control.21 {
                comment.count 1
                iface MIXER
                name 'ALC Attack Time'
                value 2
        control.22 {
                comment.count 1
                comment.item.0 None
                comment.item.1 Left
                comment.item.2 Right
                comment.item.3 Stereo
                iface MIXER
                name 'ALC Function'
                value None
        control.23 {
                comment.count 1
                iface MIXER
                name 'ALC Max Volume'
                value 7
        control.24 {
                comment.count 1
                comment.range '0 - 3'
                iface MIXER
                name 'ALC ZC Timeout'
                value 3
        control.25 {
                comment.count 1
                iface MIXER
                name 'ALC ZC Switch'
                value true
        control.26 {
                comment.count 1
                iface MIXER
                name 'ALC NG Switch'
                value true
        control.27 {
                comment.count 1
                comment.item.0 'Constant Gain'
                comment.item.1 Mute
                iface MIXER
                name 'ALC NG Type'
                value 'Constant Gain'
        control.28 {
                comment.count 1
                iface MIXER
                name 'ALC NG Threshold'
                value 0
        control.29 {
                comment.count 2
                iface MIXER
                name 'Speaker Playback ZC Switch'
                value.0 true
                value.1 true
        control.30 {
                comment.count 2
                iface MIXER
                name 'Headphone Playback ZC Switch'
                value.0 true
                value.1 true
        control.31 {
                comment.count 1
                iface MIXER
                name 'Out4 Playback Switch'
                value true
        control.32 {
                comment.count 1
                iface MIXER
                name 'Out4 Playback ZC Switch'
                value true
        control.33 {
                comment.count 1
                comment.range '0 - 63'
                iface MIXER
                name 'Out4 Playback Volume'
                value 63
        control.34 {
                comment.count 1
                iface MIXER
                name 'Out3 Playback Switch'
                value true
        control.35 {
                comment.count 1
                iface MIXER
                name 'Out3 Playback ZC Switch'
                value true
        control.36 {
                comment.count 1
                iface MIXER
                name 'Out3 Playback Volume'
                value 63
        control.37 {
                comment.count 1
                iface MIXER
                name 'Mono Capture Volume'
                value 23
        control.38 {
                comment.count 1
                iface MIXER
                name 'Mono Playback Switch'
                value true
        control.39 {
                comment.count 1
                iface MIXER
                name 'Mono Playback ZC Switch'
                value true
        control.40 {
                comment.count 1
                iface MIXER
                name 'Mono Playback Volume'
                value 31
        control.41 {
                comment.count 1
                iface MIXER
                name 'PC Beep Playback Headphone Volume'
                value 5
        control.42 {
                comment.count 1
                iface MIXER
                name 'PC Beep Playback Speaker Volume'
                value 5
 楼主| 发表于 2010-8-17 09:37:54 | 显示全部楼层
control.43 {
                comment.count 1
                iface MIXER
                name 'PC Beep Playback Mono Volume'
                value 5
        control.44 {
                comment.count 1
                iface MIXER
                name 'Voice Playback Headphone Volume'
                value 5
        control.45 {
                comment.count 1
                iface MIXER
                name 'Voice Playback Master Volume'
                value 5
        control.46 {
                comment.count 1
                iface MIXER
                name 'Voice Playback Mono Volume'
                value 5
        control.47 {
                comment.count 1
                iface MIXER
                name 'Aux Playback Headphone Volume'
                value 5
        control.48 {
                comment.count 1
                iface MIXER
                name 'Aux Playback Master Volume'
                value 5
        control.49 {
                comment.count 1
                iface MIXER
                name 'Aux Playback Mono Volume'
                value 5
        control.50 {
                comment.count 1
                comment.item.0 'Linear Control'
                comment.item.1 'Adaptive Boost'
                iface MIXER
                name 'Bass Control'
                value 'Linear Control'
        control.51 {
                comment.count 1
                iface MIXER
                name 'Bass Cut-off Switch'
                value true
        control.52 {
                comment.count 1
                iface MIXER
                name 'Tone Cut-off Switch'
                value true
        control.53 {
                comment.count 1
                iface MIXER
                name 'Playback Attenuate (-6dB) Switch'
                value true
        control.54 {
                comment.count 1
                iface MIXER
                name 'Bass Volume'
                value 0
        control.55 {
                comment.count 1
                iface MIXER
                name 'Tone Volume'
                value 0
        control.56 {
                comment.count 1
                iface MIXER
                name '3D Upper Cut-off Switch'
                value true
        control.57 {
                comment.count 1
                iface MIXER
                name '3D Lower Cut-off Switch'
                value true
        control.58 {
                comment.count 1
                iface MIXER
                name '3D Depth'
                value 15
        control.59 {
                comment.count 1
                iface MIXER
                name 'Speaker Mixer PC Beep Playback '
                value true
        control.60 {
                comment.count 1
                iface MIXER
                name 'Speaker Mixer Voice Playback Sw'
                value true
        control.61 {
                comment.count 1
                iface MIXER
                name 'Speaker Mixer Aux Playback Swit'
                value true
        control.62 {
                comment.count 1
                iface MIXER
                name 'Speaker Mixer PCM Playback Swit'
                value true
        control.63 {
                comment.count 1
                iface MIXER
                name 'Speaker Mixer MonoIn Playback S'
                value true
        control.64 {
                comment.count 1
                iface MIXER
                name 'Speaker Mixer Bypass Playback S'
                value true
        control.65 {
                comment.count 1
                iface MIXER
                name 'Mono Mixer PC Beep Playback Swi'
                value true
        control.66 {
                comment.count 1
                iface MIXER
                name 'Mono Mixer Voice Playback Switc'
                value true
        control.67 {
                comment.count 1
                iface MIXER
                name 'Mono Mixer Aux Playback Switch'
                value true
        control.68 {
                comment.count 1
                iface MIXER
                name 'Mono Mixer PCM Playback Switch'
                value true
        control.69 {
                comment.count 1
                iface MIXER
                name 'Mono Mixer Bypass Playback Swit'
                value true
        control.70 {
                comment.count 1
                iface MIXER
                name 'Mono Mixer Mic 1 Sidetone Switc'
                value true
        control.71 {
                comment.count 1
                iface MIXER
                name 'Mono Mixer Mic 2 Sidetone Switc'
                value true
        control.72 {
                comment.count 1
                iface MIXER
                name 'Right HP Mixer PC Beep Playback'
                value true
        control.73 {
                comment.count 1
                iface MIXER
                name 'Right HP Mixer Voice Playback S'
                value true
        control.74 {
                comment.count 1
                iface MIXER
                name 'Right HP Mixer Aux Playback Swi'
                value true
        control.75 {
                comment.count 1
                iface MIXER
                name 'Right HP Mixer PCM Playback Swi'
                value true
        control.76 {
                comment.count 1
                iface MIXER
                name 'Right HP Mixer MonoIn Playback '
                value true
        control.77 {
                comment.count 1
                iface MIXER
                name 'Right HP Mixer Bypass Playback '
                value true
        control.78 {
                comment.count 1
                iface MIXER
                name 'Left HP Mixer PC Beep Playback '
                value true
        control.79 {
                comment.count 1
                iface MIXER
                name 'Left HP Mixer Voice Playback Sw'
                value true
        control.80 {
                comment.count 1
                iface MIXER
                name 'Left HP Mixer Aux Playback Swit'
                value true
        control.81 {
                comment.count 1
                iface MIXER
                name 'Left HP Mixer PCM Playback Swit'
                value true
        control.82 {
                comment.count 1
                iface MIXER
                name 'Left HP Mixer MonoIn Playback S'
                value true
 楼主| 发表于 2010-8-17 09:38:37 | 显示全部楼层
control.83 {
                comment.count 1
                iface MIXER
                name 'Left HP Mixer Bypass Playback S'
                value true
        control.84 {
                comment.count 1
                comment.item.0 MPB
                comment.item.1 MPA
                iface MIXER
                name 'Mic B Source'
                value MPA
        control.85 {
                comment.count 1
                comment.item.0 'Mic 1'
                comment.item.1 'Mic 2 A'
                comment.item.2 'Mic 2 B'
                iface MIXER
                name 'Mic A Source'
                value 'Mic 1'
        control.86 {
                comment.count 1
                comment.item.1 'Mic 2'
                comment.item.2 Line
                comment.item.3 'Mono In'
                comment.item.4 Headphone
                comment.item.5 Speaker
                comment.item.6 'Mono Out'
                comment.item.7 Zh
                iface MIXER
                name 'Right Capture Source'
                value 'Mic 1'
        control.87 {
                comment.count 1
                comment.item.2 Line
                comment.item.7 Zh
                iface MIXER
                name 'Left Capture Source'
                value 'Mic 1'
        control.88 {
                comment.count 1
                comment.item.0 Off
                comment.item.1 Mono
                comment.item.2 Speaker
                comment.item.3 'Left Headphone'
                comment.item.4 'Right Headphone'
                comment.item.5 'Headphone Mono'
                comment.item.6 NC
                comment.item.7 Vmid
                iface MIXER
                name 'DAC Inv Mux 2'
                value Speaker
        control.89 {
                comment.count 1
                comment.item.0 Off
                comment.item.1 Mono
                comment.item.6 NC
                comment.item.7 Vmid
                iface MIXER
                name 'DAC Inv Mux 1'
                value Speaker
        control.90 {
                comment.count 1
                comment.item.0 Vmid
                comment.item.1 Zh
                comment.item.2 'Inv 2'
                comment.item.3 'Inv 2 Vmid'
                iface MIXER
                name 'Out 4 Mux'
                value Vmid
        control.91 {
                comment.count 1
                comment.item.0 Vmid
                comment.item.1 Zh
                comment.item.2 'Inv 1'
                comment.item.3 'Inv 1 Vmid'
                iface MIXER
                name 'Out 3 Mux'
                value Vmid
        control.92 {
                comment.count 1
                comment.item.0 Vmid
                comment.item.1 Zh
                comment.item.2 Headphone
                iface MIXER
                name 'Right Headphone Out Mux'
                value Vmid
        control.93 {
                comment.count 1
                comment.item.0 Vmid
                comment.item.1 Zh
                iface MIXER
                name 'Left Headphone Out Mux'
                value Vmid
        control.94 {
                comment.count 1
                comment.item.0 Vmid
                comment.item.1 Zh
                comment.item.3 Speaker
                comment.item.4 Inv
                comment.item.5 'Headphone Vmid'
                comment.item.6 'Speaker Vmid'
                comment.item.7 'Inv Vmid'
                iface MIXER
                name 'Right Speaker Out Mux'
                value Vmid
        control.95 {
                comment.count 1
                comment.item.0 Vmid
                comment.item.1 Zh
                comment.item.4 Inv
                iface MIXER
                name 'Left Speaker Out Mux'
                value Vmid
        control.96 {
                comment.count 1
                comment.item.0 Vmid
                comment.item.1 Zh
                comment.item.2 Mono
                comment.item.3 Inv
                iface MIXER
                name 'Mono Out Mux'
                value Vmid
        control.97 {
                comment.count 1
                comment.item.0 Stereo
                comment.item.1 Left
                comment.item.3 Mute
                iface MIXER
                name 'Capture Mono Mux'
                value Mute
        control.98 {
                comment.count 1
                comment.item.1 'Mic 1'
                comment.item.2 'Mic 2'
                comment.item.3 Mute
                iface MIXER
                name 'Sidetone Mux'
                value Mute
        control.99 {
                comment.count 1
                comment.item.1 Left
                comment.item.3 Mute
                iface MIXER
                name 'Capture Headphone Mux'
                value Mute
发表于 2010-8-18 08:53:46 | 显示全部楼层
楼主能不能介绍一下所移植的程序以及简略的移植方法。
楼主碰到的问题,大家不一定碰到过。
GMT+8, 2026-9-23 11:16
