查看: 11760|回复: 8
OK6410无法挂载nfs文件系统
khanns 该用户已被删除
发表于 2010-10-6 20:44:57 | 显示全部楼层 |阅读模式
发表于 2010-10-7 08:31:50 | 显示全部楼层
ip=192.168.0.102
是你板子的ip
ip=192.168.0.102
是你板子的ip
发表于 2010-10-15 12:56:29 | 显示全部楼层
Ubuntu ip192.168.0.231   网线也查了
setenv bootargs "root=/dev/nfs nfsroot=192.168.0.231:/forlinx/root ip=192.168.0.232:255.255.255.0:eth0:off console=ttySAC0,115200"
还是出错Looking up port of RPC 100003/2 on 192.168.0.231
eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
rpcbind: server 192.168.0.231 not responding, timed out
Root-NFS: Unable to get nfsd port number from server, using default
Looking up port of RPC 100005/1 on 192.168.0.231
Root-NFS: Unable to get mountd port number from server, using default
Root-NFS: Server returned error -5 while mounting /forlinx/root
VFS: Cannot open root device "nfs" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00             256 mtdblock0 (driver?)
1f01            3840 mtdblock1 (driver?)
1f02           81920 mtdblock2 (driver?)
1f03          962560 mtdblock3 (driver?)
b300         1921024 mmcblk0 driver: mmcblk
求解
发表于 2010-10-15 13:51:58 | 显示全部楼层
我的问题解决了。要把本地连接的ip改成和Ubuntu一段内。我一开始用的无线有干扰,所以先禁用。无线最好用静态ip
发表于 2010-10-15 18:14:08 | 显示全部楼层
:handshake
wuyu92877 该用户已被删除
发表于 2010-12-12 18:04:07 | 显示全部楼层
发表于 2010-12-13 08:05:10 | 显示全部楼层
你pc上怎么设置的啊?
wuyu92877 该用户已被删除
发表于 2010-12-13 11:15:08 | 显示全部楼层
GMT+8, 2026-10-5 00:00
