查看: 6614|回复: 1
TE9263 的SDRAM调试如何进行
发表于 2010-10-8 14:44:43 | 显示全部楼层 |阅读模式
我有一个MDK工程,在sram中调试没有问题, 在sdram中调试时不稳定。 有时不能调。
请问 debug_sdram.ini 配置文件如何编写。
TE9263的晶振采用bypass模式, 不然不能调试, 以下配置是否可以
DEFINE CHAR Setup;
DEFINE INT  Entry;
DEFINE LONG PMC;
DEFINE LONG PIO_SD;
DEFINE LONG MATRIX;
DEFINE LONG SDRAMC;
DEFINE LONG SDRAM;
// Memory mapped peripherals address definitions
PMC    = 0xFFFFFC00;
PIO_SD = 0xFFFFF800;
MATRIX = 0xFFFFEC00;
SDRAMC = 0xFFFFE200;
SDRAM  = 0x20000000;
FUNC void __PllSetting()
        // Disable all PMC interrupt ( $$ JPP)
        // AT91C_PMC_IDR   ((AT91_REG *) 0xFFFFFC64) //(PMC) Interrupt Disable Register
        // pPmc->PMC_IDR = 0xFFFFFFFF;
    _WDWORD(0xFFFFFC64,0xFFFFFFFF);
        // AT91C_PMC_PCDR  ((AT91_REG *) 0xFFFFFC14) //(PMC) Peripheral Clock Disable Register
    _WDWORD(0xFFFFFC14,0xFFFFFFFF);
        // Disable all clock only Processor clock is enabled.
    _WDWORD(0xFFFFFC04,0xFFFFFFFE);
        // AT91C_PMC_MCKR  ((AT91_REG *)         0xFFFFFC30) // (PMC) Master Clock Register
    _WDWORD(0xFFFFFC30,0x00000001);
    _sleep_(10);
    // write reset value to PLLA and PLLB
    // AT91C_PMC_PLLAR ((AT91_REG *)         0xFFFFFC28) // (PMC) PLL A Register
    _WDWORD(0xFFFFFC28,0x00003F00);
    // AT91C_PMC_PLLBR ((AT91_REG *)         0xFFFFFC2C) // (PMC) PLL B Register
    _WDWORD(0xFFFFFC2C,0x00003F00);
    _sleep_(10);
//      __PllSetting100MHz()
// Function description
//  Set core at 200 MHz and MCK at 100 MHz
FUNC void __PllSetting100MHz()
        printf( "------------------------------- PLL Set at 100 MHz ----------------------------------\n");
        //* pPmc->PMC_MOR = (( AT91C_CKGR_OSCOUNT & (0x40 <<8) | AT91C_CKGR_MOSCBYPASS ));
    _WDWORD(0xFFFFFC20,0x00004002);   //TE9263需要旁路模式
    _sleep_(40);
        //*   AT91C_BASE_CKGR->CKGR_PLLAR = (AT91C_CKGR_SRCA | ((72 << 16) & AT91C_CKGR_MULA) |
        //    (AT91C_CKGR_PLLACOUNT | (AT91C_CKGR_OUTA_0 | (7);
        _WDWORD(0xFFFFFC28,  0x2063BF08);   //16M晶振时 刚好配置成100M
    _sleep_(40);
        //*   AT91C_BASE_PMC->PMC_MCKR =  AT91C_PMC_CSS_PLLA_CLK | AT91C_PMC_PRES_CLK / 2 | AT91C_PMC_MDIV;
    _WDWORD(0xFFFFFC30,  0x00000006);
    _sleep_(40);
//      __initSDRAM()
//  Set SDRAM for works at 100 MHz
FUNC void SDRAM_Setup()
    // Configure PIOs
    // AT91F_PIO_CfgPeriph( AT91C_BASE_PIOD, AT91C_PC16_D16 to AT91C_PC16_D31
    // pPio->PIO_ASR = periphAEnable; AT91C_PIOC_ASR ((AT91_REG *) 0xFFFFF870) // (PIOC) Select A Register
    // pPio->PIO_BSR = periphBEnable;AT91C_PIOC_BSR  ((AT91_REG *) 0xFFFFF874) // (PIOC) Select B Register
    // pPio->PIO_PDR = (periphAEnable | periphBEnable); // Set in Periph mode
    // -I- Configure PIOD as peripheral (D16/D31)
    _WDWORD(0xFFFFF870,0xFFFF0000);
    _WDWORD(0xFFFFF874,0x00000000);
    _WDWORD(0xFFFFF804,0xFFFF0000);
    // Init MATRIX to support EBI0 CS1 for SDRAM"
    // AT91PS_CCFG ((AT91_REG *)         0xFFFFED20) // (CCFG)  EBI0 Chip Select Assignement Register
    _WDWORD(0xFFFFED20,0x1000A);
    // psdrc->SDRAMC_CR =  AT91C_SDRAMC_NC_9  | AT91C_SDRAMC_NR_13 | AT91C_SDRAMC_CAS_2 |
    // AT91C_SDRAMC_NB_4_BANKS | AT91C_SDRAMC_DBW_32_BITS | AT91C_SDRAMC_TWR_2 | AT91C_SDRAMC_TRC_7 |
    // AT91C_SDRAMC_TRP_2 | AT91C_SDRAMC_TRCD_2 | AT91C_SDRAMC_TRAS_5 | AT91C_SDRAMC_TXSR_8 ;
     _WDWORD(0xFFFFE208,0x85227259);
     _sleep_(10);
    // psdrc->SDRAMC_MR        = 0x00000002;                // Set PRCHG AL
    _WDWORD(0xFFFFE200,0x00000002);
    // *AT91C_SDRAM        = 0x00000000;                        // Perform PRCHG
     _WDWORD(0x20000000,0x00000000);
     _sleep_(10);
    //        psdrc->AT91C_SDRAMC0_MR        = AT91C_SDRAMC_MODE_RFSH_CMD;                // Set 1st CBR
    _WDWORD(0xFFFFE200,0x00000004);
    // *(AT91C_SDRAM+4)        = 0x00000001;        // Perform CBR
    _WDWORD(0x20000000,0x00000001);
    // psdrc->AT91C_SDRAMC0_MR        = 0x00000004;                // Set 2 CBR
    // *(AT91C_SDRAM+8)        = 0x00000002;        // Perform CBR
    // psdrc->AT91C_SDRAMC0_MR        = AT91C_SDRAMC_MODE_RFSH_CMD;                // Set 3 CBR
    // *(AT91C_SDRAM+0xc)        = 0x00000003;        // Perform CBR
    // psdrc->AT91C_SDRAMC0_MR        = AT91C_SDRAMC_MODE_RFSH_CMD;                // Set 4 CBR
    // *(AT91C_SDRAM+0x10)        = 0x00000004;        // Perform CBR
    // psdrc->AT91C_SDRAMC0_MR        = AT91C_SDRAMC_MODE_RFSH_CMD;                // Set 5 CBR
    // *(AT91C_SDRAM+0x14)        = 0x00000005;        // Perform CBR
    // psdrc->AT91C_SDRAMC0_MR        = AT91C_SDRAMC_MODE_RFSH_CMD;                // Set 6 CBR
    // *(AT91C_SDRAM+0x18)        = 0x00000006;        // Perform CBR
    // psdrc->AT91C_SDRAMC0_MR        = AT91C_SDRAMC_MODE_RFSH_CMD;                // Set 7 CBR
    // *(AT91C_SDRAM+0x1c)        = 0x00000007;        // Perform CBR
    // psdrc->AT91C_SDRAMC0_MR        = AT91C_SDRAMC_MODE_RFSH_CMD;                // Set 8 CBR
    // *(AT91C_SDRAM+0x20)        = 0x00000008;        // Perform CBR
    // psdrc->AT91C_SDRAMC0_MR        = AT91C_SDRAMC_MODE_LMR_CMD;                // Set LMR operation
    _WDWORD(0xFFFFE200,0x00000003);
    // *(AT91C_SDRAM+0x20)        = 0xcafedede;                // Perform LMR burst=1, lat=2
    _WDWORD(0x20000020,0xcafedede);
    // psdrc->AT91C_SDRAMC0_TR        = (AT91C_MASTER_CLOCK * 7)/1000000;                                // Set Refresh Timer 390 for 25MHz (TR= 15.6 * F )
    // (F : system clock freq. MHz
    //_WDWORD(0xFFFFE204,0x000002B7);
        _WDWORD(0xFFFFE204, 0x0000030B );
    // psdrc->AT91C_SDRAMC0_MR        = AT91C_SDRAMC_MODE_NORMAL_CMD;                // Set Normal mode
    _WDWORD(0xFFFFE200,0x00000000);
    // *AT91C_SDRAM        = 0x00000000;        // Perform Normal mode
    printf( "------------------------------- SDRAM Done at 100 MHz -------------------------------\n");
FUNC void Remap (void) {
  if (Setup & 0x10) {
    _WDWORD(MATRIX+0x100,0x00000003);   // MATRIX_MRCR: Remap IRAM to 0
    _sleep_(100);
FUNC void PC_Setup (void) {
  if (Setup & 0x40) {
    PC = Entry;
FUNC void GoMain (void) {
  if ((Setup & 0xA0) == 0xA0) {
    exec("g,main");
// <o1.0> Clock Setup
// <o1.1> SDRAM Setup
// <e1.4> Remap
// </e>
// <e1.5> Download Program
FUNC void Download (void) {
  if (Setup & 0x20) {
//  <s0.80> Command for Loading
    exec("LOAD debug_sdram\\DebugSdram.axf INCREMENTAL");
// </e>
// <e0.6> Setup Program Counter to Entry Point
//   <o1> Program Entry Point <0x0-0xFFFFFFFF>
// </e>
// <e.7> Execute Program untill Main Function
// </e>
Setup = 0x7F;
Entry = 0x20000000;
__PllSetting();                   //* Init PLL
__PllSetting100MHz();
SDRAM_Setup();
Remap();
Download();
PC_Setup();
GoMain();
发表于 2010-10-8 17:15:00 | 显示全部楼层
帮顶一下,没碰到过。
GMT+8, 2026-9-25 17:21
