查看: 4028|回复: 0
OK6410 mjpg-streamer摄像头问题
i.MX6Q通行证
发表于 2012-11-30 13:56:28 | 显示全部楼层 |阅读模式
我把编译好的mjpg-streamer文件夹拷贝到了/下(我的文件系统是nfs启动加载yaffs2)
[root@FORLINX6410]# export LD_LIBRARY_PATH=/mjpg-streamer:$LD_LIBRARY_PATH
export HOME='/'
export LD_LIBRARY_PATH='/mjpg-streamer:'
export LOGNAME='root'
export OLDPWD='/mjpg-streamer'
export PATH='/sbin:/usr/sbin:/bin:/usr/bin'
export PS1='[$USER@$HOSTNAME]# '
export PWD='/mjpg-streamerl'
export SHELL='/bin/sh'
export TERM='vt102'
export USER='root'
[root@FORLINX6410]# cd /mjpg-streamer
[root@FORLINX6410]# ./mjpg_streamer -i "input_nvc.so -d /dev/video2 -yuv" -o "output_http.so -w www"
MJPG Streamer Version: svn rev:
ERROR: could not find input plugin
       Perhaps you want to adjust the search path with:
       # export LD_LIBRARY_PATH=/path/to/plugin/folder
       dlopen: input_nvc.so: cannot open shared object file: No such file or directory
但仍提示找不到input_nvc.so库 求解答 急
GMT+8, 2026-10-5 07:41
