查看: 14800|回复: 1
[已解决] OK2440-iii启动引导选项和说明书里面完全不一样
发表于 2010-1-12 08:41:57 | 显示全部楼层 |阅读模式
我刚刚买了快OK2440-III按照说明书上面操作不过引导选项和说明书里面完全不一样。请指教
Microsoft Windows CE Ethernet Bootloader Common Library Version 1.1 Built Dec 12
2007 18:04:21
Microsoft Windows CE Bootloader for the S
2 2007
FMD: ReadID (Mfg=ec, Dev=f1)
FMD_Init: finished successful
FMD_Init: reserved_blocks 548
FMD_GetInfo
Press [ENTER] to launch image stored on boot media, or [SPACE] to enter boot mon
itor.
Initiating image launch in 2 seconds.
Ethernet Boot Loader Configuration:
0) IP address: 192.168.1.115
1) Subnet mask: 255.255.255.0
2) DHCP: Disabled
3) Boot delay: 5 seconds
7) Program CS8900 MAC address (00:11:22:33:44:55)
8) Kernel Debugger: DISABLED
D) Download image now
U) DOWNLOAD image now(USB)
R) Read Configuration
Enter your selection:
发表于 2010-1-12 15:28:11 | 显示全部楼层
你好 ,这是eboot的启动信息,没看到什么问题。可能你看到的是手册里面的bootloader的信息。这两个是不一样的。
GMT+8, 2026-10-4 15:18
