查看: 4994|回复: 3
启动linux2.6.12出现问题?
发表于 2010-10-20 20:39:59 | 显示全部楼层 |阅读模式
starting pid 377, tty '': '/etc/init.d/rcS'
nand_erase: attempt to erase a bad block at page 0x00007780
**>> Erasure failed 415
**>> Block 415 retired
Block 415 is in state 9 after gc, should be erased
nand_erase: attempt to erase a bad block at page 0x000077c0
**>> Erasure failed 416
**>> Block 416 retired
Block 416 is in state 9 after gc, should be erased
yaffs tragedy: no more eraased blocks
!!!!!!!!! Allocator out !!!!!!!!!!!!!!!!!
yaffs tragedy: no space during cache write
nand_erase: attempt to erase a bad block at page 0x00007800
**>> Erasure failed 417
**>> Block 417 retired
Block 417 is in state 9 after gc, should be erased
nand_erase: attempt to erase a bad block at page 0x00007840
**>> Erasure failed 418
**>> Block 418 retired
Block 418 is in state 9 after gc, should be erased
nand_erase: attempt to erase a bad block at page 0x00007880
**>> Erasure failed 419
**>> Block 419 retired
Block 419 is in state 9 after gc, should be erased
nand_erase: attempt to erase a bad block at page 0x000078c0
**>> Erasure failed 420
**>> Block 420 retired
Block 420 is in state 9 after gc, should be erased
nand_erase: attempt to erase a bad block at page 0x00007900
**>> Erasure failed 421
**>> Block 421 retired
Block 421 is in state 9 after gc, should be erased
nand_erase: attempt to erase a bad block at page 0x00007940
**>> Erasure failed 422
**>> Block 422 retired
Block 422 is in state 9 after gc, should be erased
mount: mounting tmpfs on /dev/shm failed
eth0: link down
ifconfig: SIOCSIFADDR: No such device
Please press Enter to activate this console. ./qpe: relocation error: /usr/lib/libts-0.0.so.0: symbol stderr, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
我是新手 大家帮帮我啊!!!!!!
发表于 2010-10-21 08:06:18 | 显示全部楼层
到bootloader里。将kernel与fs分区擦除,重新烧写吧~
 楼主| 发表于 2010-10-22 19:03:23 | 显示全部楼层
解决啦
发表于 2010-10-23 08:03:47 | 显示全部楼层
:handshake
GMT+8, 2026-10-4 21:44
