查看: 10035|回复: 6
OK6410 NFS挂不上 实在崩溃
发表于 2010-10-30 00:03:13 | 显示全部楼层 |阅读模式
好几天了,搞了好几遍,NFS还是挂不上,都快骂娘了,谁给看看,十分感谢
宿主机IP:192.168.0.2
虚拟机内IP:192.168.0.231
宿主机ping192.168.0.231ping的通,重启板子,还是连不上,以下是显示信息:
IP-Config: Complete:
     device=eth0, addr=192.168.0.232, mask=255.255.255.0, gw=192.168.0.201,
     host=witech, domain=, nis-domain=com.cn,
     bootserver=192.168.0.231, rootserver=192.168.0.231, rootpath=
Looking up port of RPC 100003/2 on 192.168.0.231
hub 1-0:1.0: connect-debounce failed, port 2 disabled
usb 1-2: new full speed USB device using s3c2410-ohci and address 2
usb 1-2: device descriptor read/64, error -62
usb 1-2: new full speed USB device using s3c2410-ohci and address 3
usb 1-2: new full speed USB device using s3c2410-ohci and address 4
usb 1-2: device not accepting address 4, error -62
usb 1-2: new full speed USB device using s3c2410-ohci and address 5
usb 1-2: device not accepting address 5, error -62
hub 1-0:1.0: unable to enumerate USB device on port 2
rpcbind: server 192.168.0.231 not responding, timed out
Root-NFS: Unable to get nfsd port number from server, using default
Looking up port of RPC 100005/1 on 192.168.0.231
Root-NFS: Unable to get mountd port number from server, using default
Root-NFS: Server returned error -5 while mounting /dahai/root
VFS: Cannot open root device "nfs" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00             256 mtdblock0 (driver?)
1f01            3840 mtdblock1 (driver?)
1f02           81920 mtdblock2 (driver?)
1f03          962560 mtdblock3 (driver?)
 楼主| 发表于 2010-10-30 00:05:01 | 显示全部楼层
ubuntu的nfs也启动了
发表于 2010-10-30 14:43:09 | 显示全部楼层
uboot pri看一下~
发上来~
发表于 2010-11-2 14:59:40 | 显示全部楼层
NFS挂载需要注意的事项  已经多次在论坛中讨论
LZ和LS这次可以体验一下论坛的搜索功能
simon_dd 该用户已被删除
发表于 2010-11-3 23:08:24 | 显示全部楼层
发表于 2010-11-4 08:13:27 | 显示全部楼层
uboot你设置的参数,贴出来吧~
ywmlovecss 该用户已被删除
发表于 2011-9-27 12:36:53 | 显示全部楼层
GMT+8, 2026-10-6 14:05
