查看: 12290|回复: 8
Erase... Error
发表于 2010-11-1 02:22:06 | 显示全部楼层 |阅读模式
A) Erase All Blocks
Enter your selection: a
All block(2048) Erase...
LB######## Error Erasing block 428!
LB######## Error Erasing block 1111!
Enter your selection: f
Reserving Blocks [0x0 - 0x5] ...
...reserve complete.
Low-level format Blocks [0x6 - 0x7ff] ...
...erase complete.
Enter your selection: 9
Enter LowLevelFormat [0x6, 0x7ff].
Erasing flash block(s) [0x6, 0x7ff] (please wait): EraseBlocks: found a bad block (0x1ac) - skipping...
EraseBlocks: found a bad block (0x457) - skipping...
Done.
WriteMBR: MBR block = 0x6.
Done.
Enter your selection: b
Log2Phys: Logical 0x140 -> Physical 0x240
More than 4-bit error, uncorrectable
raseBlocks: found a bad block (0x27) - skipping...
EraseBlocks: erase didn't set all bits high (marking block 0x29 bad).
EraseBlocks: found a bad block (0x7af) - skipping...
Is bad borad?
发表于 2010-11-1 08:20:03 | 显示全部楼层
重新烧写后,能启动吗?
 楼主| 发表于 2010-11-1 21:47:42 | 显示全部楼层
reboot
ECC error
发表于 2010-11-2 08:33:09 | 显示全部楼层
uboot能擦除吗?
发表于 2010-11-2 15:38:22 | 显示全部楼层
why is the board bad?
U can get useful info from user manual.
 楼主| 发表于 2010-11-4 11:09:55 | 显示全部楼层
回复 2# 飞凌-alexlee
    uboot erase
发表于 2010-11-4 11:40:08 | 显示全部楼层
这是wince的erase吧~
你用uboot的 scrub试试
 楼主| 发表于 2010-11-9 22:34:02 | 显示全部楼层
这是 uboot erase
发表于 2010-11-10 08:07:01 | 显示全部楼层
你先用scrube擦除一下nand再烧
GMT+8, 2026-10-4 22:47
