查看: 7168|回复: 3
串口工作模式的问题
firstime 该用户已被删除
发表于 2010-11-7 21:21:22 | 显示全部楼层 |阅读模式
发表于 2010-11-8 08:07:19 | 显示全部楼层
When the receiver transfers the data of the receive shifter to the receive FIFO register in FIFO mode and the number
of received data reaches Rx FIFO Trigger Level, Rx interrupt is generated. If the Receive mode is in control register
(UCONn) and is selected as 1 (Interrupt request or polling mode). In the Non-FIFO mode, transferring the data of the
receive shifter to receive holding register will cause Rx interrupt under the Interrupt request and polling mode
NULL 该用户已被删除
发表于 2010-11-9 10:53:05 | 显示全部楼层
firstime 该用户已被删除
 楼主| 发表于 2010-11-9 21:18:51 | 显示全部楼层
GMT+8, 2026-10-4 22:47
