查看: 8214|回复: 5
TE6410 dnw uboot 找不到 NAND FLASH
发表于 2010-11-17 10:22:31 | 显示全部楼层 |阅读模式
[ADDRESS:57e00000h,TOTAL:196618(0x30000)]
(34.750MB/s,0.005s)
Checksum is being calculated....
(If you want to skip, press 'x' key)
Checksum O.K.
K
U-Boot 1.1.6 (Jan 14 2010 - 00:48:10) for SMDK6410
CPU:     S3C6410 @532MHz
Board:   SMDK6410
DRAM:    128 MB
Flash:   0 kB
NAND:    No NAND device found!!!
0 MB
 楼主| 发表于 2010-11-17 10:24:37 | 显示全部楼层
回复 1# xzycq
 楼主| 发表于 2010-11-17 10:32:05 | 显示全部楼层
下载WINCE的STEPLDR.bin,校验完后竟然自动复位,板子上原来厂家写的WINCE可以跑起来
[ADDRESS:50030000h,TOTAL:4785(0x12a7)]
(1.303MB/s,0.004s)
Checksum O.K.
Reset by XnRESET[RSTSTAT:0x1]
VCO=1.064GHz
|  TE6410 USB OTG Downloader v0.1 (2009.12.22)  |
|  Forlinx embedded          www.witech.com.cn  |
ARMCLK: 532.00MHz  HCLKx2: 266.00MHz  HCLK: 133.00MHz  PCLK: 66.50MHz
VIC mode / Sync Mode
USB host is not connected yet.
Waiting for USB host connection.
!!! USB host is connected !!!
- Bulk In EP : 1
- Bulk Out EP : 2
- Speed : High
- Op Mode : DMA mode
Download & Run is selected
Select a file to download in DNW
发表于 2010-11-17 23:08:14 | 显示全部楼层
继续操作,或者从下载专区下载最新的一键烧写~
wmsulin 该用户已被删除
发表于 2010-11-23 09:39:31 | 显示全部楼层
发表于 2010-11-23 17:07:59 | 显示全部楼层
:handshake
GMT+8, 2026-10-5 00:00
