查看: 7401|回复: 1
te6410 nand flash wince 一键烧些 ,坏块很多,是导致 dnw 写 LINUX 有问题?
发表于 2010-11-17 14:19:42 | 显示全部楼层 |阅读模式
EraseBlocks: found a bad block (0x354) - skipping.
EraseBlocks: found a bad block (0x726) - skipping...b
EraseBlocks: found a bad block (0x355) - skipping.
EraseBlocks: found a bad block (0x727) - skipping...r
EraseBlocks: found a bad block (0x356) - skipping.
EraseBlocks: found a bad block (0x729) - skipping...
EraseBlocks: found a bad block (0x357) - skipping.
EraseBlocks: found a bad block (0x72a) - skipping...d
EraseBlocks: found a bad block (0x359) - skipping.
EraseBlocks: found a bad block (0x72b) - skipping...b
More than 4-bit error, uncorrectableound a bad blo
EraseBlocks: found a bad block (0x72c) - skipping...      EraseBlocks: erase didn't set all bits highblo
EraseBlocks: found a bad block (0x72d) - skipping...k (0x4f) - skipping...E
(marking block 0x35a bad).lo
EraseBlocks: found a bad block (0x72e) - skipping...ock (0x35a) - skipping...raseBlocks: found a bad blo
EraseBlocks: found a bad block (0x72f) -und a bad blment
E
EraseBlocks: found a bad block (0x73d) - skipping...d a bad block (0x5c) - skipping....
BP_write  IS_BLO
EraseBlocks: found a bad block (0x73e) - skipping...a bad block (0x5d) -
EraseBlocks: found a bad block (0x73f) - skipping...bad block (0x5e) - s
EraseBlocks: found a bad block (0x741) - skipping...d block (0x5f) - ski
EraseBlocks: found a bad block (0x742) - skipping...block (0x61) - skippin
EraseBlocks: found a bad block (0x743) - skipping...ock (0x62) - skipping.
EraseBlocks: found a bad block (0x744) - skipping...                            EraseBlocks: erase didn'
EraseBlocks: found a bad block (0x745) - skipping...ll bits high (marking b
(marki
EraseBlocks: found a bad block (0x746) -D (0x
EraseBlocks: found a bad block (0x755) - skipping...ite  IS_BLOCK_BAD (0x3
EraseBlocks: found a bad block (0x756) - skipping...ra
BP_write  IS_
BP_wr
EraseBlocks: found a bad block (0x757) - skipping...0x389).n't set all bi
B
EraseBlocks: found a bad block (0x759) - skipping...4 bad).te  IS_BLOCK_BAD
EraseBlocks: found a bad block (0x75a) - skipping...ock (0x74) - skipping..
EraseBlocks: found a bad block (0x75b) - skipping...
EraseBlocks: found a bad block (0x75c) - skipping...                            EraseBlocks: erase didn'
EraseBlocks: found a bad block (0x75d) -bad b
EraseBlocks: found a bad block (0x76c) - skipping...b
EraseBlocks: found a bad block (0x76d) - skipping...d
EraseBlocks: found a bad block (0x76e) - skipping...                            EraseBlocks: erase didn'
EraseBlocks: found a bad block (0x76f) - skipping...o
EraseBlocks: found a bad block (0x193) - sk
(marki
EraseBlocks: found a bad block (0x771) - skipping...Blocks: found a bad block (0x37c) - skipping...
EraseBlocks: found a bad block (0x772) - skipping...Blocks: found a bad block (0x37d) - skipping...ghCK_
EraseBlocks: found a bad block (0x773) -94 bad
EraseBlocks: found a bad block (0x385) - skipping.
EraseBlocks: found a bad block (0x782) - skipping...e
EraseBlocks: found a bad block (0x386) - skipping.
EraseBlocks: found a bad block (0x783) - skipping...l
EraseBlocks: found a bad block (0x387) - skipping.
EraseBlocks: found a bad block (0x784) - skipping...c
EraseBlocks: found a bad block (0x389) - skipping.
EraseBlocks: found a bad block (0x785) - skipping...s
More than 4-bit error, uncorrectable2) - skipping.
EraseBlocks: found a bad block (0x786) - skipping...      EraseBlocks: erase didn't set all bits highng.
EraseBlocks: found a bad block (0x787) - skipping...r
More than 4-bit er
(marking block 0x38a bad).
EraseBlocks: found a bad block (0x789) - skipping...ock (0x38a) - skipping...didn't set all bits highck
EraseBlocks: found a bad block (0x78a) -und a bad bl
发表于 2010-11-17 23:05:36 | 显示全部楼层
如果之前有eboot,先用eboot擦除
如果之前是uboot,用scrube擦
GMT+8, 2026-10-4 22:47
