查看: 6015|回复: 5
6410/demo/nk.bin的烧写后不能启动
发表于 2011-1-11 16:39:01 | 显示全部楼层 |阅读模式
烧写步骤:
1.从eboot界面:选择U
2.按F,   9   ,进行擦除。
3.按U下载,中选择nk.bin 文件(位于用户基础资料光盘的“WinCE6.0\demo”目录下)。
wince 停在OEMInit上.  请技术支持。
以下是串口反应:
Ethernet Boot Loader Configuration:
0) IP address: 0.0.0.0
1) Subnet mask: 255.255.255.0
2) DHCP: Disabled
3) Boot delay: 5 seconds
6) Program disk image into SmartMedia card: Disabled
7) Program DM9000A MAC address (00:00:00:00:00:00)
8) KITL Configuration: DISABLED
A) Erase All Blocks
B) Mark Bad Block at Reserved Block
C) Clean Boot Option: FALSE
D) Download image now
E) Erase Reserved Block
R) Read Configuration
S) Lcd Resolution select(480x272)
U) DOWNLOAD image now(USB)
Enter your selection: u
System ready!
Preparing for download...
INFO: *** Device Name 'SMDK64100' ***
Please send the Image through USB.
BL_IMAGE_TYPE_BIN
Download BIN file information:
[0]: Base Address=0x80150000  Length=0x2311184
RAM image
rom_offset=0x0.
ImageStart = 0x80150000, ImageLength = 0x2311184, LaunchAddr = 0x80157734
Completed file(s):
[0]: Address=0x80150000  Length=0x2311184  Name="" Target=RAM
ROMHDR at Address 80150044h
waitforconnect
INFO: OEMLaunch: Jumping to Physical Address 0x50157734h (Virtual Address 0x80157734h)...
Windows CE Kernel for ARM (Thumb Enabled) Built on Sep 25 2009 at 11:04:23
[OAL] ++OEMInit()
[OAL] S3C6410_APLL_CLK   : 532000000
[OAL] ARMCLK : 532000000
[OAL] HCLK   : 133000000
[OAL] PCLK   : 66500000
[OAL] InitializeGPIO()
[OAL] InitializeCLKSource()
[OAL] InitializeCLKGating()
[OAL] InitializeBlockPower()
DCache: 128 sets, 4 ways, 32 line size, 16384 size
ICache: 128 sets, 4 ways, 32 line size, 16384 size
+OALArgsInit()
Arguments area has some values
-OALArgsInit()
+OALTimerInit( 1, 33249, 0 )
-OALIntrRequestSysIntr(irq = 38, sysIntr = 16)
[OAL] --OEMInit()
 楼主| 发表于 2011-1-11 17:11:25 | 显示全部楼层
回复 1# zhhx
    我的光盘中“一件烧录”中的nk.bn(36120159字节)和“demo”目录中nk.bin(36120499字节),两个映像文件有差别。
小小 该用户已被删除
发表于 2011-1-11 17:11:31 | 显示全部楼层
 楼主| 发表于 2011-1-11 17:18:11 | 显示全部楼层
回复 3# 小小
还是不行,这是串口反应。
2) DHCP: Disabled
A) Erase All Blocks
Enter your selection: f
Reserving Blocks [0x0 - 0x3] ...
...reserve complete.
Low-level format Blocks [0x4 - 0xfff] ...
LB######## Error Erasing block 2156!
LB######## Error Erasing block 2158!
...erase complete.
2) DHCP: Disabled
A) Erase All Blocks
Enter your selection: 9
Enter LowLevelFormat [0x4, 0xfff].
Erasing flash block(s) [0x4, 0xfff] (please wait): EraseBlocks: found a bad block (0x86c) - skipping...
EraseBlocks: found a bad block (0x86e) - skipping...
Done.
WriteMBR: MBR block = 0x4.
Done.
2) DHCP: Disabled
A) Erase All Blocks
Enter your selection: w
Successfully Written
2) DHCP: Disabled
A) Erase All Blocks
System ready!
BL_IMAGE_TYPE_BIN
RAM image
rom_offset=0x0.
Completed file(s):
TOC {
dwSignature: 0x434F544E
BootCfg {
  ConfigFlags: 0x20830
  BootDelay: 0x5
  ImageIndex: 1
  IP: 0.0.0.0
  MAC Address: 00:00:00:00:00:00
  Port: 0.0.0.0
  SubnetMask: 255.255.255.0
ID[0] {
  dwVersion: 0x20004
  dwSignature: 0x45424F54
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x3C
  dwLoadAddress: 0x80030000
  dwJumpAddress: 0x800420F4
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x100
  sgList[0].dwLength: 0x3C
ID[1] {
  dwVersion: 0x1
  dwSignature: 0x43465348
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x4623
  dwLoadAddress: 0x80150000
  dwJumpAddress: 0x80157734
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x480
  sgList[0].dwLength: 0x4623
chainInfo.dwLoadAddress: 0X00000000
chainInfo.dwFlashAddress: 0X00000000
chainInfo.dwLength: 0X00000000
+WriteOSImageToBootMedia: g_dwTocEntry =1, ImageStart: 0x80150000, ImageLength: 0x2311184, LaunchAddr:0x80157734
INFO: OEMLaunch: Found chain extenstion: '' @ 0x80150000
Writing single region/multi-region update, dwBINFSPartLength: 36770180
IsValidMBR: block = 0x0.
IsValidMBR: block = 0x1.
IsValidMBR: block = 0x2.
IsValidMBR: block = 0x3.
IsValidMBR: MBR sector = 0x200 (valid MBR)
OpenPartition: Partition Exists=0x0 for part 0x21.
CreatePartition: Enter CreatePartition for 0x21.
LastLogSector: Last log sector is: 0x7fc7f.
CreatePartition: Start = 0x280, Num = 0x4680.
Log2Phys: Logical 0x280 -> Physical 0x480
BP_SetDataPointer at 0x0
Write OS to Nand Flash finished!!!
Updateded TOC!
OpenPartition: Partition Exists=0x0 for part 0xb.
CreatePartition: Enter CreatePartition for 0xb.
FindFreeSector: FreeSector is: 0x4900 after processing part 0x21.
CreatePartition: Num sectors set to 0x7ae80 to allow for compaction blocks.
CreatePartition: Start = 0x4900, Num = 0x7ae80.
-WriteOSImageToBootMedia
waitforconnect
[OAL] ++OEMInit()
+OALArgsInit()
-OALArgsInit()
[OAL] --OEMInit()
WinCE 6.0 Steploader for SMDK6410
Launch Eboot...
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Aug  8 2010 13:24:59
Microsoft Windows CE Bootloader for the Samsung SMDK6410 Version 2.4 Built Aug 15 2010
+OALArgsInit()
SocID:0x36410101
Arguments area is initialized
-OALArgsInit()
INFO: (unsigned)C_IsrHandler : 0x8003FEF4
INFO: (unsigned)ASM_IsrHandler : 0x800424DC
INFO: (unsigned)pISR : 0xEA01092F
BP_Init
[FMD] ++FMD_Init() ****
[FMD:INF] FMD_Init() : Read ID = 0x0000ecd3
[FMD] FMD_Init() : NUM_OF_BLOCKS = 4096
[FMD] FMD_Init() : SECTORS_PER_PAGE = 4
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 4096(0x1000), SECTORSPERBLOCK = 128(0x80), BYTESPERSECTOR = 2048(0x800)
wNUM_BLOCKS : 4096(0x1000)
[Eboot] ++InitializeDisplay()
EBOOT_FRAMEBUFFER_PA_START == 53800000
[Eboot] --InitializeDisplay()
Initiating image launch in 0 seconds.
Launching image from boot media ...
OEMPlatformInit: IMAGE_TYPE_RAMIMAGE
RAM image
RAM image
OpenPartition: Partition Exists=0x1 for part 0x21.
**[Eboot] BP_ReadData***
ReadData: Start = 0x0, Length = 0x2311800.
Loading Kernel......
System ready!
INFO: Using static IP address 0000.
INFO: Using subnet mask 2525250.
waitforconnect
INFO: using TOC[1] dwJumpAddress: 0x80157734
[OAL] ++OEMInit()
+OALArgsInit()
-OALArgsInit()
[OAL] --OEMInit()
archeng504 该用户已被删除
发表于 2011-1-11 22:31:01 | 显示全部楼层
发表于 2011-1-12 08:05:10 | 显示全部楼层
eboot,按一下选项a, e
然后你重新下载eboot。stepldr,nk
GMT+8, 2026-10-5 02:01
