查看: 5577|回复: 1
用一键烧写工具写WINCE出错,求助!
XX18通行证
发表于 2011-1-19 19:15:29 | 显示全部楼层 |阅读模式
DNW的打印信息如下:(我用的是USB转串口线,OK6410的256M的NAND Flash,客服alexlee 提供的“IROM_SD_EBOOT_256M.nb0”文件,比以前有很大进展了,在此衷心的感谢一下!:handshake )
下列打印信息完后,蜂鸣器开始响。不再有任何动静了。
请客服帮忙分析下是什么问题,谢谢!
Download BIN file information:
[0]: Base Address=0x80100000  Length=0x25ede80
RAM image
rom_offset=0x0.
ImageStart = 0x80100000, ImageLength = 0x25EDE80, LaunchAddr = 0x80107734
Completed file(s):
[0]: Address=0x80100000  Length=0x25EDE80  Name="" Target=RAM
ROMHDR at Address 80100044h
+WriteOSImageToBootMedia: g_dwTocEntry =1, ImageStart: 0x80100000, ImageLength: 0x25ede80, LaunchAddr:0x80107734
INFO: OEMLaunch: Found chain extenstion: '' @ 0x80100000
Writing single region/multi-region update, dwBINFSPartLength: 39771776
IsValidMBR: MBR sector = 0x200 (valid MBR)
OpenPartition: Partition Exists=0x0 for part 0x21.
CreatePartition: Enter CreatePartition for 0x21.
LastLogSector: Last log sector is: 0x1fd3f.
CreatePartition: Start = 0x1c0, Num = 0x4c00.
Log2Phys: Logical 0x1c0 -> Physical 0x3c0
WriteMBR: MBR block = 0x8.
BP_SetDataPointer at 0x0
WriteData: Start = 0x0, Length = 0x25ede80.
Writing Image ......
###############################################################################################################################################################################################################################################################################################################Updated TOC!
OpenPartition: Partition Exists=0x0 for part 0xb.
CreatePartition: Enter CreatePartition for 0xb.
FindFreeSector: FreeSector is: 0x4dc0 after processing part 0x21.
CreatePartition: Num sectors set to 0x1ae40 to allow for compaction blocks.
CreatePartition: Start = 0x4dc0, Num = 0x1ae40.
TOC {
dwSignature: 0x434F544E
BootCfg {
  ConfigFlags: 0x20830
  BootDelay: 0x2
  ImageIndex: 1
  IP: 0.0.0.0
  MAC Address: 00:00:00:00:00:00
  Port: 0.0.0.0
  SubnetMask: 255.255.255.0
ID[0] {
  dwVersion: 0x20004
  dwSignature: 0x45424F54
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x3C
  dwLoadAddress: 0x80030000
  dwJumpAddress: 0x80041D3C
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x80
  sgList[0].dwLength: 0x3C
ID[1] {
  dwVersion: 0x1
  dwSignature: 0x43465348
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x4BDC
  dwLoadAddress: 0x80100000
  dwJumpAddress: 0x80107734
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x3C0
  sgList[0].dwLength: 0x4BDC
chainInfo.dwLoadAddress: 0X00000000
chainInfo.dwFlashAddress: 0X00000000
chainInfo.dwLength: 0X00000000
waitforconnect
INFO: using TOC[1] dwJumpAddress: 0x80107734
Success!
SpinForever...
发表于 2011-1-20 08:29:49 | 显示全部楼层
联系一下客服~~
GMT+8, 2026-10-5 02:01
