查看: 13787|回复: 11
烧写zImage出现问题。求解!
发表于 2011-1-23 17:54:04 | 显示全部楼层 |阅读模式
按照linux用户手册上的“编译Uboot  编译内核”一章进行 做zImage,与uboot,然后 用光盘自带的  cramfs,一步一步,成功烧写了 系统(提示SMDK6410 #),
然后设置为nand 启动,信息如下: (nand 我已经用eboot  选A   察除过)
请问什么问题?检查坏快??请知道的朋友解释一下!谢谢
U-Boot 1.1.6 (Jan 20 2011 - 22:43:36) for SMDK6410
CPU:     S3C6410 @532MHz
Board:   SMDK6410
DRAM:    128 MB
Flash:   0 kB
NAND:    select s3c_nand_oob_mlc_128
2048 MB
*** Warning - bad CRC or NAND, using default environment
In:      serial
Out:     serial
Err:     serial
NAND read: device 0 offset 0x100000, size 0x300000
3145728 bytes read: OK
Boot with zImage
Starting kernel ...
Uncompressing Linux......................... done, booting the kernel.
Linux version 2.6.28.6 (root@ok6410-desktop) (gcc version 4.2.2) #236 Thu Jan 20 23:15:22 CST 2011
CPU: ARMv6-compatible processor [410fb766] revision 6 (ARMv7), cr=00c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: SMDK6410
CPU S3C6410 (id 0x36410101)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C64XX: HCLKx2=266000000, HCLK=133000000, PCLK=66500000
div1: 00000555
mout_epll: source is fout_epll (1), rate is 24000000
mmc_bus: source is dout_mpll (1), rate is 44333333
usb-host-bus: source is mout_epll (0), rate is 24000000
audio-bus0: source is mout_epll (0), rate is 24000000
audio-bus1: source is mout_epll (0), rate is 24000000
audio-bus2: source is mout_epll (0), rate is 24000000
s3c64xx: 15728640 bytes SDRAM reserved for fimc at 0x50637000
s3c64xx: 8388608 bytes SDRAM reserved for pp at 0x51537000
s3c64xx: 8388608 bytes SDRAM reserved for tv at 0x51d37000
s3c64xx: 6291456 bytes SDRAM reserved for mfc at 0x52537000
s3c64xx: 8388608 bytes SDRAM reserved for jpeg at 0x52b37000
s3c64xx: 8388608 bytes SDRAM reserved for cmm at 0x53337000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: root=/dev/mtdblock2 rootfstype=cramfs console=ttySAC0,115200
PID hash table entries: 512 (order: 9, 2048 bytes)
s3c24xx_serial_init_ports: initialising ports=4...
console [ttySAC0] enabled
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 70200KB available (4596K code, 526K data, 148K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 530.84 BogoMIPS (lpj=1327104)
net_namespace: 316 bytes
S3C6410: Initialising architecture
S3C DMA-pl080 Controller Driver, (c) 2006-2007 Samsung Electronics
Total 32 DMA channels will be initialized.
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: US
        (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
        (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
        (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
cfg80211: Calling CRDA for country: US
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
 楼主| 发表于 2011-1-23 17:54:35 | 显示全部楼层
NetWinder Floating Point Emulator V0.97 (double precision)
yaffs Jan 20 2011 23:04:47 Installing.
msgmni has been set to 137
io scheduler noop registered
io scheduler anticipatory registered
S3C_LCD clock got enabled :: 133.000 Mhz
LCD TYPE :: LTE480WV will be initialized
Window[0] - FB1: map_video_memory: clear ff000000:0007f800
            FB1: map_video_memory: dma=57180000 cpu=ff000000 size=0007f800
Window[0] - FB2: map_video_memory: clear ff03fc00:0003fc00
            FB2: map_video_memory: dma=571bfc00 cpu=ff03fc00 size=0003fc00
[DEBUG]logo_lines 0, vc->vc_bottom 34
fbcon_init: disable boot-logo (boot-logo bigger than screen).
Console: switching to colour frame buffer device 60x34
Window[1] - FB1: map_video_memory: clear ff080000:0007f800
            FB1: map_video_memory: dma=57200000 cpu=ff080000 size=0007f800
Window[1] - FB2: map_video_memory: clear ff0bfc00:0003fc00
            FB2: map_video_memory: dma=5723fc00 cpu=ff0bfc00 size=0003fc00
Window[2] - FB1: map_video_memory: clear ff100000:0003fc00
            FB1: map_video_memory: dma=57140000 cpu=ff100000 size=0003fc00
Window[3] - FB1: map_video_memory: clear ff140000:0003fc00
            FB1: map_video_memory: dma=57280000 cpu=ff140000 size=0003fc00
enter s3c6410_leds_init
leds initialized
s3c6400-uart.0: s3c2410_serial0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: s3c2410_serial1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: s3c2410_serial2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: s3c2410_serial3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
brd: module loaded
loop: module loaded
dm9000 Ethernet Driver
eth2090025615: con201 Invalid ethernet MAC address. using default config,  Please set using ifconfig
eth0: dm9000 at f7b00300,f7b00304 IRQ 108 MAC: 00:e0:4a:bc:15:e7
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver zd1211rw
usbcore: registered new interface driver rndis_wlan
usbcore: registered new interface driver zd1201
libertas_sdio: Libertas SDIO driver
libertas_sdio: Copyright Pierre Ossman
usbcore: registered new interface driver lbtf_usb
Linux video capture interface: v2.00
printk ov965x_init
s3c-fimc: info ov965x_init
S3C6400 MFC Driver, (c) 2007 Samsung Electronics
S3C PostProcessor Driver v3.12, (c) 2009 Samsung Electronics
S3C6410 TV encoder Driver, (c) 2008 Samsung Electronics
S3C6410 TV encoder Driver init OK.
S3C6410 TV scaler Driver, (c) 2008 Samsung Electronics
S3C6410 TV scaler Driver init OK.
S3C Rotator Driver, (c) 2008 Samsung Electronics
s3c_rotator_probe called
s3c_rotator_probe success
S3C JPEG Driver, (c) 2007 Samsung Electronics
s3c_g2d_probe called
s3c_g2d_probe Success
S3C G2D Init : Done
S3C G3D Driver, (c) 2007-2009 Samsung Electronics
s3c_g3d version : 0x1050000
S3C G3D Init : Done
S3C CMM Driver, (c) 2008 Samsung Electronics
Driver 'sd' needs updating - please use bus_type methods
S3C NAND Driver, (c) 2008 Samsung Electronics
S3C NAND Driver is using software ECC.
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd5 (Samsung NAND 2GiB 3,3V 8-bit)
Creating 4 MTD partitions on "NAND 2GiB 3,3V 8-bit":
0x00000000-0x00040000 : "Bootloader"
0x00040000-0x00400000 : "Kernel"
0x00400000-0x20400000 : "Rootfs"
0x20400000-0x80000000 : "File System"
Samsung SoC SPI Driver loaded for SPI-0
        Max,Min-Speed [33250000, 129882]Hz
        Irq=80        IOmem=[0x7f00bfff-0x7f00b000]        DMA=[Rx-33, Tx-34]
Samsung SoC SPI Driver loaded for SPI-1
        Irq=81        IOmem=[0x7f00cfff-0x7f00c000]        DMA=[Rx-35, Tx-36]
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver usb-storage
s3c-udc : S3C HS USB OTG Device Driver, (c) 2008-2009 Samsung Electronics
s3c-udc : version 15 March 2009 (DMA Mode)
mice: PS/2 mouse device common for all mice
gpio keys driver.
input: gpio-keys as /class/input/input0
S3C Touchscreen driver, (c) 2008 Samsung Electronics
S3C TouchScreen got loaded successfully : 12 bits
input: S3C TouchScreen as /class/input/input1
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410_rtc: tick irq 34, alarm irq 92
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 377 KHz
[OV965X]ov965x_attach_adapter.
[CAM]s3c_fimc_register_camera,cam->id=0
parent clock for camera: 266.000 MHz, divisor: 11
[CAM]RESET CAM.[CAM]Reset and init reg!1cam->client=0
[CAM]Reset and init reg!3
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
sdhci: Secure Digital Host Controller Interface driver
s3c-sdhci s3c-sdhci.0: clock source 2: mmc_bus (44333333 Hz)
sdhci: card inserted.
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (44333333 Hz)
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.18rc3.
ASoC version 0.13.2
WM9713/WM9714 SoC Audio Codec 0.15
playback: 1, capture : 1
asoc: AC97 HiFi <-> s3c64xx-ac97 mapping ok
[WM9713]Open speaker volume.
ALSA device list:
  #0: SMDK6400 (WM9713)
TCP cubic registered
can: controller area network core (rev 20081130 abi 8)
can: raw protocol (rev 20081130)
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
s3c2410-rtc s3c2410-rtc: setting system clock to 2000-10-10 16:25:16 UTC (971195116)
mtd->size = 20000000 blocks = 400
cheaking bad block...............
..............        .(在这里出现了错误)
<3>uncorrectable error :: VFS: Mounted root (cramfs filesystem) readonly.
Freeing init memory: 148K
Error -3 while decompressing!
c050a580(1530)->c3c09000(4096)
c0510390(2472)->c3c17000(4096)
<3>uncorrectable error : Error -3 while decompressing!
c050d597(2313)->c3c2b000(4096)
Kernel panic - not syncing: Attempted to kill init!
 楼主| 发表于 2011-1-24 19:00:00 | 显示全部楼层
怎么没有人回答我啊?
发表于 2011-1-25 08:26:16 | 显示全部楼层
文件系统,擦除一下,之后重新烧文件系统~
 楼主| 发表于 2011-1-25 22:59:27 | 显示全部楼层
回复 4# 飞凌-alexlee
    文件系统怎么察除???? 具体怎么操作?
发表于 2011-1-26 08:20:35 | 显示全部楼层
nand scrub ***** 文件系统的地址~~
手册有写~
 楼主| 发表于 2011-1-26 13:19:55 | 显示全部楼层
好。晚上回家试一下!
 楼主| 发表于 2011-1-26 22:35:54 | 显示全部楼层
不行啊。。!!!!!
我的操作如下。nand scrub 400000 5000000
提示察除成功后,我按照手册上 4-3-1 操作,烧写文件系统。完成后,重启开发板,还是出现以上错误,!!
我也试过,erase all
我看到“0x00000000-0x00040000 : "Bootloader"
0x20400000-0x80000000 : "File System"”
我也试了 nand scrub 20400000  80000000  都不行啊。。!!帮帮忙啊!!很郁闷,烧了这么久都不行啊
lmuestc 该用户已被删除
发表于 2011-2-28 16:09:47 | 显示全部楼层
发表于 2011-2-28 16:54:49 | 显示全部楼层
敢问楼主的uboot  zImage的来源
这涉及到一个匹配的问题。
lmuestc 该用户已被删除
发表于 2011-3-1 09:39:45 | 显示全部楼层
发表于 2011-3-2 08:32:22 | 显示全部楼层
编译的时候编译器的版本?编译前最好make clean一下。
GMT+8, 2026-10-5 04:21
