查看: 7828|回复: 6
ok6410一键烧写问题
i.MX8MM通行证
发表于 2011-3-1 15:39:39 | 显示全部楼层 |阅读模式
前边都是按照说明书做的,最后DNW上的信息是这样的,然后就是无尽的等待
Write OS to Nand Flash finished!!!
Updated TOC!
IsValidMBR: block = 0x0.
IsValidMBR: block = 0x1.
IsValidMBR: block = 0x2.
IsValidMBR: block = 0x3.
IsValidMBR: MBR sector = 0x200 (valid MBR)
OpenPartition: Partition Exists=0x0 for part 0xb.
CreatePartition: Enter CreatePartition for 0xb.
FindFreeSector: FreeSector is: 0x4b00 after processing part 0x21.
CreatePartition: Num sectors set to 0x68400 to allow for compaction blocks.
CreatePartition: Start = 0x4b00, Num = 0x68400.
WriteMBR: MBR block = 0x4.
TOC {
dwSignature: 0x434F544E
BootCfg {
  ConfigFlags: 0x20830
  BootDelay: 0x5
  ImageIndex: 1
  IP: 0.0.0.0
  MAC Address: 00:00:00:00:00:00
  Port: 0.0.0.0
  SubnetMask: 255.255.255.0
ID[0] {
  dwVersion: 0x20004
  dwSignature: 0x45424F54
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x3C
  dwLoadAddress: 0x80030000
  dwJumpAddress: 0x800420B8
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x100
  sgList[0].dwLength: 0x3C
ID[1] {
  dwVersion: 0x1
  dwSignature: 0x43465348
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x4805
  dwLoadAddress: 0x80150000
  dwJumpAddress: 0x80157734
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x2880
  sgList[0].dwLength: 0x4805
chainInfo.dwLoadAddress: 0X00000000
chainInfo.dwFlashAddress: 0X00000000
chainInfo.dwLength: 0X00000000
waitforconnect
INFO: using TOC[1] dwJumpAddress: 0x80157734
INFO: OEMLaunch: Jumping to Physical Address 0x50157734h (Virtual Address 0x80157734h)...
鼿Windows CE Kernel for ARM (Thumb Enabled) Built on Sep 25 2009 at 11:04:23
[OAL] ++OEMInit()
[OAL] S3C6410_APLL_CLK   : 532000000
[OAL] ARMCLK : 532000000
[OAL] HCLK   : 133000000
[OAL] PCLK   : 66500000
[OAL] InitializeGPIO()
[OAL] InitializeCLKSource()
[OAL] InitializeCLKGating()
[OAL] InitializeBlockPower()
DCache: 128 sets, 4 ways, 32 line size, 16384 size
ICache: 128 sets, 4 ways, 32 line size, 16384 size
+OALArgsInit()
Arguments area has some values
-OALArgsInit()
+OALTimerInit( 1, 33249, 0 )
-OALIntrRequestSysIntr(irq = 38, sysIntr = 16)
[OAL] --OEMInit()
i.MX8MM通行证
 楼主| 发表于 2011-3-1 15:41:58 | 显示全部楼层
高手门给说说吧,2G的SD卡,烧的OK6410_SDboot.nb0
拨码是0001 1111都没错
i.MX8MM通行证
 楼主| 发表于 2011-3-1 16:02:08 | 显示全部楼层
补充,我买的是256RAM的,会不会有区别啊
i.MX8MM通行证
 楼主| 发表于 2011-3-1 16:07:06 | 显示全部楼层
存储器是2G的,和光盘上的不一样?
xuxiao 该用户已被删除
发表于 2011-3-1 22:43:24 | 显示全部楼层
发表于 2011-3-2 08:24:20 | 显示全部楼层
:handshake
w88193363 该用户已被删除
发表于 2011-4-14 15:14:45 | 显示全部楼层
GMT+8, 2026-10-5 13:44
