查看: 12311|回复: 10
ok6410板子可以一键烧写windowsce 但烧写完linux后 无法启动
发表于 2011-3-8 19:30:38 | 显示全部楼层 |阅读模式
用一键烧写linux后 或是用 sd卡烧写完 uboot后,从nand启动后 显示以下信
3c-nand: ECC uncorrectable error detected
s3c-nand: ECC uncorrectable error detected
*** Warning - bad CRC or NAND, using default environment
In:      serial
Out:     serial
Err:     serial
SMDK6410 #
在uboot中用 nand scrub 擦除块后 还是出现这个错误  请问这是怎么回事?
发表于 2011-3-9 08:30:03 | 显示全部楼层
用WINCE的EBOOT擦除一下flash吧,A功能就是擦除flash
 楼主| 发表于 2011-3-9 08:41:11 | 显示全部楼层
这个都试过了, uboot中用nand scrub 命令擦除所有块也不管用
 楼主| 发表于 2011-3-9 10:47:04 | 显示全部楼层
现在内核启动了 但由于到了别的错误
cheaking bad block...............
bad block at 1e80000
bad block at 2040000
.............................................................................................................................................................................................................................................................................................................................................................................................VFS: Mounted root (cramfs filesystem) readonly.
Freeing init memory: 148K
usb 1-2: new full speed USB device using s3c2410-ohci and address 2
hub 1-0:1.0: unable to enumerate USB device on port 2
mmc0: new high speed SDHC card at address 1234
mmcblk0: mmc0:1234 SA04G 3.68 GiB
mmcblk0: p1
hub 1-0:1.0: connect-debounce failed, port 2 disabled
     http://www.witech.com.cn
yaffs: passed flags ""
cp: cannot stat '/mnt/disk/pointercal': No such file or directory
Try to bring eth0 interface up......eth0: link down
Done
Starting Qtopia, please waiting...
touch...
Please press Enter to activate this console. hub 1-0:1.0: connect-debounce failed, port 2 disabled
usb 1-2: new full speed USB device using s3c2410-ohci and address 3
usb 1-2: device descriptor read/64, error -62
usb 1-2: new full speed USB device using s3c2410-ohci and address 4
usb 1-2: new full speed USB device using s3c2410-ohci and address 5
usb 1-2: device not accepting address 5, error -62
usb 1-2: new full speed USB device using s3c2410-ohci and address 6
usb 1-2: device not accepting address 6, error -62
又不动了
发表于 2011-3-9 13:17:37 | 显示全部楼层
请勿重复发帖
841565682 该用户已被删除
发表于 2011-3-17 13:59:52 | 显示全部楼层
841565682 该用户已被删除
发表于 2011-3-17 14:15:19 | 显示全部楼层
liuhaohao 该用户已被删除
发表于 2011-3-17 15:58:59 | 显示全部楼层
人海过客 该用户已被删除
发表于 2011-4-19 18:53:52 | 显示全部楼层
发表于 2011-4-20 08:28:57 | 显示全部楼层
楼上,你重新开一个帖子,把你的烧写步骤发上来,鉴定一下~
人海过客 该用户已被删除
发表于 2011-4-30 11:02:46 | 显示全部楼层
GMT+8, 2026-10-5 16:42
