查看: 6041|回复: 1
在移植USB无线网卡遇到的问题
A40i/T3/T507/T527通行证i.MX6Q通行证i.MX6UL通行证i.MX8MM通行证i.MX8MP通行证RK3568通行证RK3399通行证LS1028A通行证LS1012A通行证LS1043A\46A通行证i.MX RT通行证
发表于 2013-1-21 11:13:49 | 显示全部楼层 |阅读模式
[root@6410 wireless]# ifconfig ra0 up
(Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc]
RTMP_TimerListAdd: add timer obj d1dbcc98!
RTMP_TimerListAdd: add timer obj d1dbccc8!
RTMP_TimerListAdd: add timer obj d1dbccf8!
RTMP_TimerListAdd: add timer obj d1dbcc68!
RTMP_TimerListAdd: add timer obj d1dbcbd8!
RTMP_TimerListAdd: add timer obj d1dbcc08!
RTMP_TimerListAdd: add timer obj d1d8780c!
one_wire_status: 4
RTMP_TimerListAdd: add timer obj d1d76fd0!
RTMP_TimerListAdd: add timer obj d1d77008!
RTMP_TimerListAdd: add timer obj d1d878b0!
RTMP_TimerListAdd: add timer obj d1d877ac!
RTMP_TimerListAdd: add timer obj d1d8787c!
one_wire_status: 4
-->RTUSBVenderReset
<--RTUSBVenderReset
Key1Str is Invalid key length(0) or Type(0)
Key2Str is Invalid key length(0) or Type(0)
Key3Str is Invalid key length(0) or Type(0)
Key4Str is Invalid key length(0) or Type(0)
1. Phy Mode = 5
2. Phy Mode = 5
NVM is Efuse and its size =2d[2d0-2fc]
phy mode> Error! The chip does not support 5G band 15!
RTMPSetPhyMode: channel is out of range, use first channel=1
3. Phy Mode = 9
AntCfgInit: primary/secondary ant 0/1
AsicSetRxAnt, switch to main antenna
MCS Set = ff 00 00 00 01
<==== rt28xx_init, Status=0
0x1300 = 00064300
[root@6410 wireless]# iwlist ra0 scan
===>rt_ioctl_giwscan. 3(3) BSS returned, data->length = 422
ra0       Scan completed :
          Cell 01 - Address: F0:7D:68:51:DC:6E
                    Protocol:802.11b/g/n
                    ESSID:"123456"
                    Mode:Managed
                    Frequency:2.412 GHz (Channel 1)
                    Quality=83/100  Signal level=-57 dBm  Noise level=-92 dBm
                    Encryption key:on
                    Bit Rates:54 Mb/s
                    IE: WPA Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (2) : TKIP CCMP
                        Authentication Suites (1) : PSK
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : TKIP
          Cell 02 - Address: 00:15:E9:0E:7E:9E
                    Protocol:802.11b/g
                    ESSID:""
                    Mode:Managed
                    Frequency:2.437 GHz (Channel 6)
                    Quality=26/100  Signal level=-79 dBm  Noise level=-74 dBm
                    Encryption key:on
                    Bit Rates:54 Mb/s
          Cell 03 - Address: 8C:21:0A:3C:A4:FA
                    ESSID:"CHNHE"
                    Mode:Managed
                    Quality=2/100  Signal level=-89 dBm  Noise level=-84 dBm
                    Encryption key:on
                    Bit Rates:54 Mb/s
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                    IE: Unknown: DD0E0050F204104A0001101044000102
[root@6410 /etc]# ./wlconfig
rtusb init rt2870 --->
=== pAd = d1d75000, size = 513648 ===
<-- RTMPAllocTxRxRingMemory, Status=0
<-- RTMPAllocAdapterBlock, Status=0
usbcore: registered new inte**ce driver rt2870
one_wire_status: 4
one_wire_status: 4
-->RTUSBVenderReset
<--RTUSBVenderReset
1. Phy Mode = 5
2. Phy Mode = 5
3. Phy Mode = 9
0x1300 = 00064300
udhcpc (v1.17.2) started
===>rt_ioctl_giwscan. 1(1) BSS returned, data->length = 171
==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=1)
Sending discover...
RTMP_TimerListAdd: add timer obj d1deb6b4!
Sending discover...
Rcv Wcid(1) AddBAReq
Start Seq = 00000000
RTMP_TimerListAdd: add timer obj d1ded6d4!
Sending select for 192.168.0.159...
Lease of 192.168.0.159 obtained, lease time 7200
deleting routers
route: SIOCDELRT: No such process
adding dns 192.168.0.250
adding dns 192.168.0.254
[root@6410 /etc]# GetDesiredTssiAndCurrentTssi: Out of range, *pCurrentTssi = -127
GetDesiredTssiAndCurrentTssi: BBP TSSI INFO is not ready. (BbpR47 = 0x94)
AsicAdjustTxPower: Incorrect desired TSSI or current TSSI
为什么打印输出信息提示:
deleting routers
以及
如何解决这些问题?望各位高手指点一下
发表于 2013-2-23 16:46:57 | 显示全部楼层
这信息很少,需要更多的信息帮你来看这个问题
GMT+8, 2026-9-25 21:16
