查看: 9587|回复: 13
FL2440 烧写kernel 失败
发表于 2013-4-1 15:13:28 | 显示全部楼层 |阅读模式
5贡献
在重新烧写linux系统的时候,先擦除了核心板上的内容,用J_TAGE烧写bootloader显示成功的,能进入到如下菜单,但是烧写kernel 的时候,就出现了错误,错误如下,Checksum Error 这个是bootloader的问题么。
|   FL2440 Bootloader VER-5.1              www.witech.com.cn |
|CPU ID is 0x32440001                                        |
|FCLK=400MHz,HCLK=100MHz,PCLK=50MHz, CPU is running at 400MHz|
|UPLL=96MHz, UCLK=48MHz                                      |
|Serial port 0, Baud rate is 115200.                         |
|OS image stored in NAND Flash.                              |
|Autoboot delay is 7 seconds.                                |
|                     Select Menu                            |
| [0] Download & Run                                         |
| [1] Download to flash                                      |
| [2] Download From UART                                     |
| [3] Boot My Application                                    |
| [4] Boot Linux                                             |
| [5] Boot Wince                                             |
| [6] Erase Flash Partition                                  |
| [7] Config parameters                                      |
NAND ID is 0xecda
Please select which region to write : Esc to abort
0 : offset 0x00000000, size 0x00020000 [boot]
1 : offset 0x00020000, size 0x00060000 [bootParam]
2 : offset 0x00080000, size 0x00100000 [pic]
3 : offset 0x00180000, size 0x00380000 [MyApp]
4 : offset 0x00500000, size 0x00300000 [kernel]
5 : offset 0x00800000, size 0x03c00000 [fs_yaffs]
6 : offset 0x04400000, size 0x00080000 [eboot]
7 : offset 0x04480000, size 0x03b80000 [wince]
Now download and write nand flash part [ kernel ]
press [USB Port-->transmit] to choose the file
Now, Downloading [ADDRESS:c000000h,TOTAL:1708398]
RECEIVED FILE SIZE: 1708398
(819.2KB/S,2.1S)
Now, Checksum calculation
Checksum Error!!! MEM:6353 DN:4
Now write nand flash page 0xa00 from ram address 0xc000000, filesize = 1708398
.Check data at page 0xa00, offset 0x0 fail
.Check data at page 0xa40, offset 0x0 fail
.Check data at page 0xa80, offset 0x10 fail
.Check data at page 0xac0, offset 0x1 fail
.Check data at page 0xb00, offset 0x54 fail
.Check data at page 0xb40, offset 0x45 fail
.Check data at page 0xb80, offset 0x1 fail
.Check data at page 0xbc0, offset 0x42 fail
.Check data at page 0xc00, offset 0x11 fail
.Check data at page 0xc40, offset 0x3 fail
.Check data at page 0xc80, offset 0x5d fail
Program nand flash fail
最佳答案
查看完整内容
哦哦 这一大意费了多少脑汁儿啊
发表于 2013-4-1 15:13:29 | 显示全部楼层
哦哦 这一大意费了多少脑汁儿啊
技术支持邮箱:Hardware@forlinx.com
点评回复
 楼主| 发表于 2013-4-2 12:08:12 | 显示全部楼层
怎么没人来指导下呢?
点评回复
发表于 2013-4-7 09:41:45 | 显示全部楼层
现在成功了吗?不行的话可以重新烧写bootloader在烧系统
点评回复
 楼主| 发表于 2013-4-7 10:33:23 | 显示全部楼层
重新烧写了好几次,都不行;bootloader烧写每次都是都烧录kernel 时提示出错
点评回复
发表于 2013-4-7 10:49:37 | 显示全部楼层
嗯 我的意思是您是不是把bootloader全都擦了然后JTAG烧的吗?在就是看看自己的nandflash是现代的还是三星的 程序要对应
点评回复
 楼主| 发表于 2013-4-7 12:52:37 | 显示全部楼层
飞凌-peacelove 发表于 2013-4-7 10:49
嗯 我的意思是您是不是把bootloader全都擦了然后JTAG烧的吗?在就是看看自己的nandflash是现代的还是三星的 ...
是把bootloader全都擦了然后JTAG烧的,nandflash是三星的,程序也是对应的。
点评回复
发表于 2013-4-7 13:44:34 | 显示全部楼层
你的dnw地址设置的多少?
点评回复
 楼主| 发表于 2013-4-7 14:10:57 | 显示全部楼层
飞凌-unix 发表于 2013-4-7 13:44
你的dnw地址设置的多少?
0x30800000
点评回复
发表于 2013-4-8 15:41:09 | 显示全部楼层
nandflash多大?有型号吗贴一下
点评回复
 楼主| 发表于 2013-4-9 13:24:15 | 显示全部楼层
飞凌-peacelove 发表于 2013-4-8 15:41
nandflash多大?有型号吗贴一下
好像是256M,是FL2440 SCS2440 V2.1的核心板
点评回复
发表于 2013-4-10 10:14:47 | 显示全部楼层
大概是什么时候买的板子 摘下核心板看看核心板底部那个nandflash芯片上写的型号然后贴出来,三星的或者是现代的 烧相应的
点评回复
 楼主| 发表于 2013-4-12 08:52:03 | 显示全部楼层
飞凌-peacelove 发表于 2013-4-10 10:14
大概是什么时候买的板子 摘下核心板看看核心板底部那个nandflash芯片上写的型号然后贴出来,三星的或者是现 ...
SAMSUNG 137 K9F2G08U0B PCB0
点评回复
 楼主| 发表于 2013-4-12 09:32:32 | 显示全部楼层
现在突然解决了,是DNW地址少了个0,感谢你的帮助!大意害死人啊
点评回复
GMT+8, 2026-10-5 03:09
