查看: 12306|回复: 2
无法usb安装wince
发表于 2013-4-11 14:32:31 | 显示全部楼层 |阅读模式
Reset by XnRESET[RSTSTAT:0x1]
VCO=1.064GHz
|  TE6410 USB OTG Downloader v0.1 (2009.12.22)  |
|  Forlinx embedded          www.witech.com.cn  |
ARMCLK: 532.00MHz  HCLKx2: 266.00MHz  HCLK: 133.00MHz  PCLK: 66.50MHz
VIC mode / Sync Mode
USB host is not connected yet.
Waiting for USB host connection.
!!! USB host is connected !!!
- Bulk In EP : 1
- Bulk Out EP : 2
- Speed : High
- Op Mode : DMA mode
Download & Run is selected
Select a file to download in DNW
[ADDRESS:50008000h,TOTAL:313306(0x4c7d0)]
VCO=1.064GHz
Insert an OTG cable into the connector!
- Bulk In EP : 1
- Bulk Out EP : 2
- Speed : High
卡死在这了,无法发送文件,但是驱动装了
发表于 2013-5-28 16:57:07 | 显示全部楼层
楼主是想通过usb单步烧写吗?
GMT+8, 2026-9-25 18:59
