查看: 13403|回复: 5
[Linux] OK6410A烧写程序白屏
发表于 2013-7-5 10:18:34 | 显示全部楼层 |阅读模式
我烧写的是RAM256和nand2g的程序,我问过卖家我的板子信息,他说我的板子是256RAM和4G nandflash,证明我烧写的程序没错,而且我也是下载论坛里面最新的程序(2013-3-1号更新),顺便说一下,我在烧写程序之前也在uboot状态下进行了Format the nandflash。为什么我试了N遍(完全按照手册做的,SD卡一键烧写,SD_Writer烧写mmc.bin,文件拷贝到SD卡改名称之类的都没错,我的电脑是XP的),一直都是白屏,难道出厂就是坏的。请给予解释。
发表于 2013-7-5 15:16:56 | 显示全部楼层
你的板子之前用wince擦出过吗?
 楼主| 发表于 2013-7-5 15:35:54 | 显示全部楼层
没有啊。我是在uboot下面选1进行format the nandflash,然后再一键烧写程序的
 楼主| 发表于 2013-7-5 15:37:57 | 显示全部楼层
**    Updated for OK6410  TE6410 Board  **
**    Version (2012-09-23)          **
CPU:     S3C6410 @532MHz
         Fclk = 532MHz, Hclk = 133MHz, Pclk = 66MHz, Serial = CLKUART (SYNC Mode
Board:   SMDK6410
DRAM:    256 MB
Flash:   0 kB
NandFlash Information:
Nandflash:ChipType= MLC  ChipName=samsung-K9LBG08U0D
No  No Calc pagesize, blocksize, erasesize,  use ids table .............
NandFlash:name=NAND 4GiB 1,8V 8-bit,id=d7, pagesize=4096 ,chipsize=2048 MB,erase
size=524288 oobsize=128
NandFlash Size is 2048 MB
SD/MMC:  SD 2.0 SDHC / Manufacturer: 0x02,OEM: "TM/SA04G",REV: 1.1,S/N: 11168784
05,DATE: 2012/12
         SDHC size: 3724 MiB
         Freq = 50MHz
In:      serial
Out:     lcd
Err:     lcd
Skipping bad block at  0x00000000
Skipping bad block at  0x00080000
Skipping bad block at  0x00100000
Skipping bad block at  0x30a80000
Erasing at 0x7ff80000 -- 100% complete.
OK
reading u-boot.bin
212992 bytes read
NAND write: device 0 offset 0x0, size 0x200000
1032192 bytes written: OK
reading zImage
3638592 bytes read
NAND write: device 0 offset 0x200000, size 0x500000
Writing data at 0x6ff000 -- 100% complete.
5242880 bytes written: OK
reading rootfs.yaffs2
129761280 bytes read
NAND write: device 0 offset 0x700000, size 0x7bc0000
Writing data at 0x7eff000 -- 100% complete.
129761280 bytes written: OK
这是串口信息
 楼主| 发表于 2013-7-5 15:52:38 | 显示全部楼层
现在板子只能当电灯用哦,救命啊。五一买的到现在都没烧进linux.
发表于 2013-7-5 19:15:36 | 显示全部楼层
楼主的问题已经解决了
GMT+8, 2026-10-5 02:02
