查看: 9468|回复: 1
今天烧写安卓系统,按照手册上的烧写,发现系统起不来啊,求高手指点
A40i/T3/T507/T527通行证i.MX6UL通行证i.MX6Q通行证XX18通行证
发表于 2013-7-16 01:13:38 | 显示全部楼层 |阅读模式
两种方法都试过了,串口打印信息为
  Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
s3c-rtc s3c64xx-rtc: setting system clock to 2000-10-08 22:14:24 UTC (971043264)
yaffs: passed flags ""
devtmpfs: error mounting -2
Freeing init memory: 172K
s3c2410-ohci s3c2410-ohci: auto-stop root hub
[<c0039d38>] (unwind_backtrace+0x0/0xf8) from [<c053e558>] (panic+0x60/0x1a8)
[<c053e558>] (panic+0x60/0x1a8) from [<c00335ac>] (init_post+0xbc/0x130)
[<c00335ac>] (init_post+0xbc/0x130) from [<c0008488>] (kernel_init+0x118/0x160)
[<c0008488>] (kernel_init+0x118/0x160) from [<c0034aa8>] (kernel_thread_exit+0x0/0x8)
6万
发表于 2013-7-18 09:01:07 | 显示全部楼层
楼主按照手册清除一下坏块,再重新烧写一下,烧写文件用我们光盘提供的。根据你子板子的nandflash大小选取烧写文件。
GMT+8, 2026-10-5 00:56
