查看: 4767|回复: 0
根文件系统不启动
发表于 2013-8-3 10:30:30 | 显示全部楼层 |阅读模式
## Booting kernel from Legacy Image at 30200000 ...
   Image Name:   linux-2.6.22
   Created:      2013-08-01  11:10:11 UTC
   Data Size:    1510868 Bytes =  1.4 MB
   Load Address: 30008000
   Entry Point:  30008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux................................................................................................... done, booting the kernel.
Linux version 2.6.22 (root@localhost.localdomain) (gcc version 3.4.1) #4 Thu Aug 1 19:02:26 HKT 2013
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
Machine: SMDK2440
Warning: bad configuration page, trying to continue
CPU S3C2440A (id 0x32440001)
S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz
S3C24XX Clocks, (c) 2004 Simtec Electronics
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists.  Total pages: 4064
Kernel command line: root=/dev/hda1 ro init=/bin/bash console=ttySAC0
irq: clearing pending ext status 00080880
irq: clearing pending ext status 00000080
irq: clearing subpending status 00000003
irq: clearing subpending status 00000002
PID hash table entries: 64 (order: 6, 256 bytes)
timer tcon=00500000, tcnt a4ca, tcfg 00000200,00000000, usec 00001e57
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory: 16MB = 16MB total
Memory: 12944KB available (2788K code, 313K data, 132K init)
S3C2410 Power Management, (c) 2004 Simtec Electronics
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C2440: Clock Support, DVS off
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c1800000, irq 33
DMA channel 1 at c1800040, irq 34
DMA channel 2 at c1800080, irq 35
DMA channel 3 at c18000c0, irq 36
usbcore: registered new inte**ce driver usbfs
usbcore: registered new inte**ce driver hub
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler cfq registered
s3c2410-lcd s3c2410-lcd: invalid bpp 16
Console: switching to colour frame buffer device 30x40
fb0: s3c2410fb frame buffer device
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: module loaded
dm9000 Ethernet Driver
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
BAST NOR-Flash Driver, (c) 2004 Simtec Electronics
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2440-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 4 at 0x00080000
Bad eraseblock 12 at 0x00180000
Bad eraseblock 13 at 0x001a0000
Bad eraseblock 14 at 0x001c0000
Bad eraseblock 544 at 0x04400000
Bad eraseblock 548 at 0x04480000
Bad eraseblock 549 at 0x044a0000
Bad eraseblock 556 at 0x04580000
Bad eraseblock 557 at 0x045a0000
Bad eraseblock 558 at 0x045c0000
Bad eraseblock 559 at 0x045e0000
Bad eraseblock 560 at 0x04600000
Bad eraseblock 561 at 0x04620000
Bad eraseblock 562 at 0x04640000
Bad eraseblock 563 at 0x04660000
Bad eraseblock 564 at 0x04680000
Bad eraseblock 565 at 0x046a0000
Bad eraseblock 566 at 0x046c0000
Bad eraseblock 567 at 0x046e0000
Bad eraseblock 568 at 0x04700000
Bad eraseblock 569 at 0x04720000
Bad eraseblock 570 at 0x04740000
Bad eraseblock 571 at 0x04760000
Bad eraseblock 572 at 0x04780000
Bad eraseblock 573 at 0x047a0000
Bad eraseblock 574 at 0x047c0000
Bad eraseblock 575 at 0x047e0000
Bad eraseblock 576 at 0x04800000
Bad eraseblock 577 at 0x04820000
Bad eraseblock 578 at 0x04840000
Bad eraseblock 579 at 0x04860000
Bad eraseblock 580 at 0x04880000
Bad eraseblock 581 at 0x048a0000
Bad eraseblock 582 at 0x048c0000
Bad eraseblock 583 at 0x048e0000
Bad eraseblock 584 at 0x04900000
Bad eraseblock 585 at 0x04920000
Bad eraseblock 586 at 0x04940000
Bad eraseblock 587 at 0x04960000
Bad eraseblock 588 at 0x04980000
Bad eraseblock 589 at 0x049a0000
Bad eraseblock 590 at 0x049c0000
Bad eraseblock 591 at 0x049e0000
Bad eraseblock 592 at 0x04a00000
Bad eraseblock 593 at 0x04a20000
Bad eraseblock 594 at 0x04a40000
Bad eraseblock 595 at 0x04a60000
Bad eraseblock 596 at 0x04a80000
Bad eraseblock 597 at 0x04aa0000
Bad eraseblock 598 at 0x04ac0000
Bad eraseblock 599 at 0x04ae0000
Bad eraseblock 600 at 0x04b00000
Bad eraseblock 601 at 0x04b20000
Bad eraseblock 602 at 0x04b40000
Bad eraseblock 603 at 0x04b60000
Bad eraseblock 604 at 0x04b80000
Bad eraseblock 605 at 0x04ba0000
Bad eraseblock 606 at 0x04bc0000
Bad eraseblock 607 at 0x04be0000
Bad eraseblock 608 at 0x04c00000
Bad eraseblock 609 at 0x04c20000
Bad eraseblock 610 at 0x04c40000
Bad eraseblock 611 at 0x04c60000
Bad eraseblock 612 at 0x04c80000
Bad eraseblock 613 at 0x04ca0000
Bad eraseblock 614 at 0x04cc0000
Bad eraseblock 615 at 0x04ce0000
Bad eraseblock 616 at 0x04d00000
Bad eraseblock 617 at 0x04d20000
Bad eraseblock 618 at 0x04d40000
Bad eraseblock 619 at 0x04d60000
Bad eraseblock 620 at 0x04d80000
Bad eraseblock 621 at 0x04da0000
Bad eraseblock 622 at 0x04dc0000
Bad eraseblock 623 at 0x04de0000
Bad eraseblock 624 at 0x04e00000
Bad eraseblock 625 at 0x04e20000
Bad eraseblock 626 at 0x04e40000
Bad eraseblock 627 at 0x04e60000
Bad eraseblock 628 at 0x04e80000
Bad eraseblock 629 at 0x04ea0000
Bad eraseblock 630 at 0x04ec0000
Bad eraseblock 631 at 0x04ee0000
Bad eraseblock 632 at 0x04f00000
Bad eraseblock 633 at 0x04f20000
Bad eraseblock 634 at 0x04f40000
Bad eraseblock 635 at 0x04f60000
Bad eraseblock 636 at 0x04f80000
Bad eraseblock 637 at 0x04fa0000
Bad eraseblock 638 at 0x04fc0000
Bad eraseblock 639 at 0x04fe0000
Bad eraseblock 640 at 0x05000000
Bad eraseblock 641 at 0x05020000
Bad eraseblock 642 at 0x05040000
Bad eraseblock 643 at 0x05060000
Bad eraseblock 644 at 0x05080000
Bad eraseblock 645 at 0x050a0000
Bad eraseblock 646 at 0x050c0000
Bad eraseblock 647 at 0x050e0000
Bad eraseblock 648 at 0x05100000
Bad eraseblock 649 at 0x05120000
Bad eraseblock 650 at 0x05140000
Bad eraseblock 651 at 0x05160000
Bad eraseblock 652 at 0x05180000
Bad eraseblock 653 at 0x051a0000
Bad eraseblock 654 at 0x051c0000
Bad eraseblock 655 at 0x051e0000
Bad eraseblock 656 at 0x05200000
Bad eraseblock 657 at 0x05220000
Bad eraseblock 658 at 0x05240000
Bad eraseblock 659 at 0x05260000
Bad eraseblock 660 at 0x05280000
Bad eraseblock 661 at 0x052a0000
Bad eraseblock 662 at 0x052c0000
Bad eraseblock 663 at 0x052e0000
Bad eraseblock 664 at 0x05300000
Bad eraseblock 665 at 0x05320000
Bad eraseblock 666 at 0x05340000
Bad eraseblock 667 at 0x05360000
Bad eraseblock 668 at 0x05380000
Bad eraseblock 669 at 0x053a0000
Bad eraseblock 670 at 0x053c0000
Bad eraseblock 671 at 0x053e0000
Bad eraseblock 672 at 0x05400000
Bad eraseblock 673 at 0x05420000
Bad eraseblock 674 at 0x05440000
Bad eraseblock 675 at 0x05460000
Bad eraseblock 676 at 0x05480000
Bad eraseblock 677 at 0x054a0000
Bad eraseblock 678 at 0x054c0000
Bad eraseblock 679 at 0x054e0000
Bad eraseblock 680 at 0x05500000
Bad eraseblock 681 at 0x05520000
Bad eraseblock 682 at 0x05540000
Bad eraseblock 683 at 0x05560000
Bad eraseblock 684 at 0x05580000
Bad eraseblock 685 at 0x055a0000
Bad eraseblock 686 at 0x055c0000
Bad eraseblock 687 at 0x055e0000
Bad eraseblock 688 at 0x05600000
Bad eraseblock 689 at 0x05620000
Bad eraseblock 690 at 0x05640000
Bad eraseblock 691 at 0x05660000
Bad eraseblock 692 at 0x05680000
Bad eraseblock 693 at 0x056a0000
Bad eraseblock 694 at 0x056c0000
Bad eraseblock 695 at 0x056e0000
Bad eraseblock 696 at 0x05700000
Bad eraseblock 697 at 0x05720000
Bad eraseblock 698 at 0x05740000
Bad eraseblock 699 at 0x05760000
Bad eraseblock 700 at 0x05780000
Bad eraseblock 701 at 0x057a0000
Bad eraseblock 702 at 0x057c0000
Bad eraseblock 703 at 0x057e0000
Bad eraseblock 704 at 0x05800000
Bad eraseblock 705 at 0x05820000
Bad eraseblock 706 at 0x05840000
Bad eraseblock 707 at 0x05860000
Bad eraseblock 708 at 0x05880000
Bad eraseblock 709 at 0x058a0000
Bad eraseblock 710 at 0x058c0000
Bad eraseblock 711 at 0x058e0000
Bad eraseblock 712 at 0x05900000
Bad eraseblock 713 at 0x05920000
Bad eraseblock 714 at 0x05940000
Bad eraseblock 715 at 0x05960000
Bad eraseblock 716 at 0x05980000
Bad eraseblock 717 at 0x059a0000
Bad eraseblock 718 at 0x059c0000
Bad eraseblock 719 at 0x059e0000
Bad eraseblock 720 at 0x05a00000
Bad eraseblock 721 at 0x05a20000
Bad eraseblock 722 at 0x05a40000
Bad eraseblock 723 at 0x05a60000
Bad eraseblock 724 at 0x05a80000
Bad eraseblock 725 at 0x05aa0000
Bad eraseblock 726 at 0x05ac0000
Bad eraseblock 727 at 0x05ae0000
Bad eraseblock 728 at 0x05b00000
Bad eraseblock 729 at 0x05b20000
Bad eraseblock 730 at 0x05b40000
Bad eraseblock 731 at 0x05b60000
Bad eraseblock 732 at 0x05b80000
Bad eraseblock 733 at 0x05ba0000
Bad eraseblock 734 at 0x05bc0000
Bad eraseblock 735 at 0x05be0000
Bad eraseblock 736 at 0x05c00000
Bad eraseblock 737 at 0x05c20000
Bad eraseblock 738 at 0x05c40000
Bad eraseblock 739 at 0x05c60000
Bad eraseblock 740 at 0x05c80000
Bad eraseblock 741 at 0x05ca0000
Bad eraseblock 742 at 0x05cc0000
Bad eraseblock 743 at 0x05ce0000
Bad eraseblock 744 at 0x05d00000
Bad eraseblock 745 at 0x05d20000
Bad eraseblock 746 at 0x05d40000
Bad eraseblock 747 at 0x05d60000
Bad eraseblock 748 at 0x05d80000
Bad eraseblock 749 at 0x05da0000
Bad eraseblock 750 at 0x05dc0000
Bad eraseblock 751 at 0x05de0000
Bad eraseblock 752 at 0x05e00000
Bad eraseblock 753 at 0x05e20000
Bad eraseblock 754 at 0x05e40000
Bad eraseblock 755 at 0x05e60000
Bad eraseblock 756 at 0x05e80000
Bad eraseblock 757 at 0x05ea0000
Bad eraseblock 758 at 0x05ec0000
Bad eraseblock 759 at 0x05ee0000
Bad eraseblock 760 at 0x05f00000
Bad eraseblock 761 at 0x05f20000
Bad eraseblock 762 at 0x05f40000
Bad eraseblock 763 at 0x05f60000
Bad eraseblock 764 at 0x05f80000
Bad eraseblock 765 at 0x05fa0000
Bad eraseblock 766 at 0x05fc0000
Bad eraseblock 767 at 0x05fe0000
Bad eraseblock 768 at 0x06000000
Bad eraseblock 769 at 0x06020000
Bad eraseblock 770 at 0x06040000
Bad eraseblock 771 at 0x06060000
Bad eraseblock 772 at 0x06080000
Bad eraseblock 773 at 0x060a0000
Bad eraseblock 774 at 0x060c0000
Bad eraseblock 775 at 0x060e0000
Bad eraseblock 776 at 0x06100000
Bad eraseblock 777 at 0x06120000
Bad eraseblock 778 at 0x06140000
Bad eraseblock 779 at 0x06160000
Bad eraseblock 780 at 0x06180000
Bad eraseblock 781 at 0x061a0000
Bad eraseblock 782 at 0x061c0000
Bad eraseblock 783 at 0x061e0000
Bad eraseblock 784 at 0x06200000
Bad eraseblock 785 at 0x06220000
Bad eraseblock 786 at 0x06240000
Bad eraseblock 787 at 0x06260000
Bad eraseblock 788 at 0x06280000
Bad eraseblock 789 at 0x062a0000
Bad eraseblock 790 at 0x062c0000
Bad eraseblock 791 at 0x062e0000
Bad eraseblock 792 at 0x06300000
Bad eraseblock 793 at 0x06320000
Bad eraseblock 794 at 0x06340000
Bad eraseblock 795 at 0x06360000
Bad eraseblock 796 at 0x06380000
Bad eraseblock 797 at 0x063a0000
Bad eraseblock 798 at 0x063c0000
Bad eraseblock 799 at 0x063e0000
Bad eraseblock 800 at 0x06400000
Bad eraseblock 801 at 0x06420000
Bad eraseblock 802 at 0x06440000
Bad eraseblock 803 at 0x06460000
Bad eraseblock 804 at 0x06480000
Bad eraseblock 805 at 0x064a0000
Bad eraseblock 806 at 0x064c0000
Bad eraseblock 807 at 0x064e0000
Bad eraseblock 808 at 0x06500000
Bad eraseblock 809 at 0x06520000
Bad eraseblock 810 at 0x06540000
Bad eraseblock 811 at 0x06560000
Bad eraseblock 812 at 0x06580000
Bad eraseblock 813 at 0x065a0000
Bad eraseblock 814 at 0x065c0000
Bad eraseblock 815 at 0x065e0000
Bad eraseblock 816 at 0x06600000
Bad eraseblock 817 at 0x06620000
Bad eraseblock 818 at 0x06640000
Bad eraseblock 819 at 0x06660000
Bad eraseblock 820 at 0x06680000
Bad eraseblock 821 at 0x066a0000
Bad eraseblock 822 at 0x066c0000
Bad eraseblock 823 at 0x066e0000
Bad eraseblock 824 at 0x06700000
Bad eraseblock 825 at 0x06720000
Bad eraseblock 826 at 0x06740000
Bad eraseblock 827 at 0x06760000
Bad eraseblock 828 at 0x06780000
Bad eraseblock 829 at 0x067a0000
Bad eraseblock 830 at 0x067c0000
Bad eraseblock 831 at 0x067e0000
Bad eraseblock 1477 at 0x0b8a0000
Bad eraseblock 1478 at 0x0b8c0000
Bad eraseblock 1479 at 0x0b8e0000
Bad eraseblock 1480 at 0x0b900000
Bad eraseblock 1481 at 0x0b920000
Bad eraseblock 1482 at 0x0b940000
Bad eraseblock 1483 at 0x0b960000
Bad eraseblock 1484 at 0x0b980000
Bad eraseblock 1485 at 0x0b9a0000
Bad eraseblock 1486 at 0x0b9c0000
Bad eraseblock 1487 at 0x0b9e0000
Bad eraseblock 1488 at 0x0ba00000
Bad eraseblock 1489 at 0x0ba20000
Bad eraseblock 1490 at 0x0ba40000
Bad eraseblock 1491 at 0x0ba60000
Bad eraseblock 1492 at 0x0ba80000
Bad eraseblock 1493 at 0x0baa0000
Bad eraseblock 1494 at 0x0bac0000
Bad eraseblock 1495 at 0x0bae0000
Bad eraseblock 1496 at 0x0bb00000
Bad eraseblock 1497 at 0x0bb20000
Bad eraseblock 1498 at 0x0bb40000
Bad eraseblock 1499 at 0x0bb60000
Bad eraseblock 1500 at 0x0bb80000
Bad eraseblock 1501 at 0x0bba0000
Bad eraseblock 1502 at 0x0bbc0000
Bad eraseblock 1503 at 0x0bbe0000
Bad eraseblock 1504 at 0x0bc00000
Bad eraseblock 1505 at 0x0bc20000
Bad eraseblock 1506 at 0x0bc40000
Bad eraseblock 1507 at 0x0bc60000
Bad eraseblock 1508 at 0x0bc80000
Bad eraseblock 1509 at 0x0bca0000
Bad eraseblock 1510 at 0x0bcc0000
Bad eraseblock 1511 at 0x0bce0000
Bad eraseblock 1512 at 0x0bd00000
Bad eraseblock 1513 at 0x0bd20000
Bad eraseblock 1514 at 0x0bd40000
Bad eraseblock 1515 at 0x0bd60000
Bad eraseblock 1516 at 0x0bd80000
Bad eraseblock 1517 at 0x0bda0000
Bad eraseblock 1518 at 0x0bdc0000
Bad eraseblock 1519 at 0x0bde0000
Bad eraseblock 1520 at 0x0be00000
Bad eraseblock 1521 at 0x0be20000
Bad eraseblock 1522 at 0x0be40000
Bad eraseblock 1523 at 0x0be60000
Bad eraseblock 1524 at 0x0be80000
Bad eraseblock 1525 at 0x0bea0000
Bad eraseblock 1526 at 0x0bec0000
Bad eraseblock 1527 at 0x0bee0000
Bad eraseblock 1528 at 0x0bf00000
Bad eraseblock 1529 at 0x0bf20000
Bad eraseblock 1530 at 0x0bf40000
Bad eraseblock 1531 at 0x0bf60000
Bad eraseblock 1532 at 0x0bf80000
Bad eraseblock 1533 at 0x0bfa0000
Bad eraseblock 1534 at 0x0bfc0000
Bad eraseblock 1535 at 0x0bfe0000
Bad eraseblock 1536 at 0x0c000000
Bad eraseblock 1537 at 0x0c020000
Bad eraseblock 1538 at 0x0c040000
Bad eraseblock 1539 at 0x0c060000
Bad eraseblock 1540 at 0x0c080000
Bad eraseblock 1541 at 0x0c0a0000
Bad eraseblock 1542 at 0x0c0c0000
Bad eraseblock 1543 at 0x0c0e0000
Bad eraseblock 1544 at 0x0c100000
Bad eraseblock 1545 at 0x0c120000
Bad eraseblock 1546 at 0x0c140000
Bad eraseblock 1547 at 0x0c160000
Bad eraseblock 1548 at 0x0c180000
Bad eraseblock 1549 at 0x0c1a0000
Bad eraseblock 1550 at 0x0c1c0000
Bad eraseblock 1551 at 0x0c1e0000
Bad eraseblock 1552 at 0x0c200000
Bad eraseblock 1553 at 0x0c220000
Bad eraseblock 1554 at 0x0c240000
Bad eraseblock 1555 at 0x0c260000
Bad eraseblock 1556 at 0x0c280000
Bad eraseblock 1557 at 0x0c2a0000
Bad eraseblock 1558 at 0x0c2c0000
Bad eraseblock 1559 at 0x0c2e0000
Creating 3 MTD partitions on "NAND 256MiB 3,3V 8-bit":
0x00000000-0x00200000 : "kernel"
0x00200000-0x00a00000 : "jffs2"
0x00a00000-0x10000000 : "yaffs22"
usbmon: debugfs is not available
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
mice: PS/2 mouse device common for all mice
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
TCP cubic registered
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Root-NFS: No NFS server available, giving up.
VFS: Cannot open root device "hda1" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00       2048 mtdblock0 (driver?)
1f01       8192 mtdblock1 (driver?)
1f02     251904 mtdblock2 (driver?)
移植的uboot 已经可以支持yaffs2 jffs2 文件  但是烧录 根文件之后出现了上面的情况
今天把伪坏块的问题解决了 但烧录的时候 发现真的有坏块
还望大神指点一二
GMT+8, 2026-9-25 18:07
