查看: 6111|回复: 6
烧写linux内核和文件系统后无法启动
sdeeds 该用户已被删除
发表于 2013-8-7 22:05:59 | 显示全部楼层 |阅读模式
发表于 2013-8-8 08:27:39 | 显示全部楼层
你的信息显示你的文件系统没有烧写或者没有被挂在上
sdeeds 该用户已被删除
 楼主| 发表于 2013-8-8 15:11:41 | 显示全部楼层
发表于 2013-8-8 17:38:50 | 显示全部楼层
你烧写的文件有问题吧,你烧写的文件是我们提供的吗?
发表于 2014-9-20 19:08:51 | 显示全部楼层
我的也一样啊,哪个有办法啊?
s3c-rtc s3c64xx-rtc: setting system clock to 2000-01-01 02:52:32 UTC (946695152)
dm9000 dm9000.0: eth0: link down
IP-Config: Cannot add default route (-101).
dm9000 dm9000.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[<c003aca8>] (unwind_backtrace+0x0/0xfc) from [<c04a7f2c>] (dump_stack+0x18/0x1c)
[<c04a7f2c>] (dump_stack+0x18/0x1c) from [<c04a7f90>] (panic+0x60/0x1ac)
[<c04a7f90>] (panic+0x60/0x1ac) from [<c0008fd0>] (mount_block_root+0x204/0x25c)
[<c0008fd0>] (mount_block_root+0x204/0x25c) from [<c00090b0>] (mount_root+0x88/0xd0)
[<c00090b0>] (mount_root+0x88/0xd0) from [<c0009204>] (prepare_namespace+0x10c/0x1a8)
[<c0009204>] (prepare_namespace+0x10c/0x1a8) from [<c00084c4>] (kernel_init+0xf0/0x130)
[<c00084c4>] (kernel_init+0xf0/0x130) from [<c0035a34>] (kernel_thread_exit+0x0/0x8)
发表于 2014-9-20 19:09:53 | 显示全部楼层
MDK6410 # printenv
bootcmd=nand read 0xc0008000 0x200000 0x500000;bootm 0xc0008000
bootdelay=1
baudrate=115200
ethaddr=00:40:5c:26:0a:5b
netmask=255.255.255.0
bootargs=root=/dev/nfs nfsroot=192.168.0.128:/forlinx/root ip=192.168.0.103:192.168.0.128:192.168.0.255:255.255.255.0:witech.com.cn:eth0:off console=ttySAC0,115200
ipaddr=192.168.0.103
serverip=192.168.0.104
gatewayip=192.168.0.1
stdin=serial
stdout=serial
stderr=serial
Environment size: 411/524284 bytes
你是怎么烧写的?以及烧写的哪些文件?  详情 回复 发表于 2014-9-22 08:47
发表于 2014-9-22 08:47:45 | 显示全部楼层
Miles 发表于 2014-9-20 19:09
MDK6410 # printenv
你是怎么烧写的?以及烧写的哪些文件?
GMT+8, 2026-10-4 16:19
