查看: 11860|回复: 5
[Linux] NFS 挂载失败求教
发表于 2013-9-9 18:54:12 | 显示全部楼层 |阅读模式
我用系统是 ubuntu(非虚拟机) 12.04   +  OK6410B(256m,linux 3.0.1)
1.  文件系统已经正确解压  /home/liujun/arm/share/FileSystem-Yaffs2
                      liujun@AND:~/arm/share/FileSystem-Yaffs2$ ls
                      bin  dev  etc  lib  mnt  nfs.txt  opt  proc  root  sbin  sdcard  sys  tmp  udisk  usr  var
2. portmap 和 nfs-kernel-server正常运行(这之前 /etc/exports   中  /home/liujun/arm/share *(rw,sync,no_root_squash)  已经追加 )
                      iujun@AND:~/arm/share$ service portmap status                       portmap start/running, process 29386
                       liujun@AND:~/arm/share$ service nfs-kernel-server status
                       nfsd running
                       liujun@AND:~/arm/share$ ifconfig
3.终端  用的是  kermrc,已经正常使用
4.当我在uboot 输入,
setenv bootargs "root=/dev/nfs nfsroot=192.168.1.7:/home/liujun/arm/share/FileSystem-Yaffs2 ip=192.168.1.6:192.168.1.7:192.168.1.1:255.255.255.0:witech.com.cn:wlan0:off console=ttySAC0,115200"
重启之后,就出现图片错误:
usbhid: USB HID core driver
asoc: wm9713-hifi <-> samsung-ac97 mapping ok
ALSA device list:
  #0: smdk6410
TCP cubic registered
s3c-rtc s3c64xx-rtc: setting system clock to 2000-01-01 07:44:40 UTC (946712680)
[<c003aca8>] (unwind_backtrace+0x0/0xfc) from [<c04a7f2c>] (dump_stack+0x18/0x1c)
[<c04a7f2c>] (dump_stack+0x18/0x1c) from [<c04a7f90>] (panic+0x60/0x1ac)
[<c04a7f90>] (panic+0x60/0x1ac) from [<c0008fd0>] (mount_block_root+0x204/0x25c)
[<c0008fd0>] (mount_block_root+0x204/0x25c) from [<c00090b0>] (mount_root+0x88/0xd0)
[<c00090b0>] (mount_root+0x88/0xd0) from [<c0009204>] (prepare_namespace+0x10c/0x1a8)
[<c0009204>] (prepare_namespace+0x10c/0x1a8) from [<c00084c4>] (kernel_init+0xf0/0x130)
[<c00084c4>] (kernel_init+0xf0/0x130) from [<c0035a34>] (kernel_thread_exit+0x0/0x8)
换回来下面的重启就正常了:
setenv bootargs "root=/dev/mtdblock2 rootfstype=yaffs2 console=ttySAC0,115200"
 楼主| 发表于 2013-9-9 18:59:37 | 显示全部楼层
UBUNTU:192.168.1.7;            开发版192.168.1.6;路由:192.168.1.1
如下错误:
然后一直不动了
发表于 2013-9-10 08:43:04 | 显示全部楼层
NFS FileSystem
setenv bootargs "root=/dev/nfs nfsroot=192.168.0.231:/forlinx/root/FileSystem-Yaffs2 ip=192.168.0.232:192.168.0.231:192.168.0.201:255.255.255.0:witech.com.cn:eth0:off console=ttySAC0,115200"
发表于 2013-9-10 08:43:28 | 显示全部楼层
这个是板子默认的设置
 楼主| 发表于 2013-9-13 00:29:30 | 显示全部楼层
admin 发表于 2013-9-10 08:43
这个是板子默认的设置
我把IP替换成我的对应的IP,还是无法启动?????
你看下错误信息,是不 开发板 NFS 服务没启动、???、
发表于 2013-9-13 08:57:52 | 显示全部楼层
你看看你的电脑防火墙有没有拦截啊,ubuntu的防火墙和windows的防火墙杀毒软件
GMT+8, 2026-10-5 00:00
