查看: 9256|回复: 1
[Linux] 我买的板是4GB NAND FLASH ,256 MB DDR 为什么显示的只有 2GB 128MB
发表于 2013-10-11 19:29:59 | 显示全部楼层 |阅读模式
**    Updated for OK6410  TE6410 Board  **
**    Version (2012-09-23)          **
CPU:     S3C6410 @532MHz
Board:   SMDK6410
DRAM:    128 MB
Flash:   0 kB
NandFlash Information:
Nandflash:ChipType= MLC  ChipName=samsung-K9LBG08U0D
No  No Calc pagesize, blocksize, erasesize,  use ids table .............
NandFlash:name=NAND 4GiB 1,8V 8-bit,id=d7, pagesize=4096 ,chipsize=2048 MB,erasesize=524288 oobsize=128
NandFlash Size is 2048 MB
SD/MMC:  SD 2.0 SDHC / Manufacturer: 0x02,OEM: "TM/SE08G",REV: 0.6,S/N: -874237129,DATE: 2013/7
         SDHC size: 7460 MiB
         Freq = 50MHz
In:      serial
Out:     lcd
Err:     lcd
发表于 2013-10-12 16:10:29 | 显示全部楼层
你使用的uboot和mmc错误了吧,你使用的是128的uboot和mmc文件
GMT+8, 2026-10-5 00:01
