查看: 5124|回复: 0
FL2440中断裸机程序运行时出现Dabort exception!!!错误
发表于 2013-11-13 17:03:57 | 显示全部楼层 |阅读模式
  1. .extern INT_Main
  2. .section .init
  3. .global _start
  4. _start:
  5.
  6.         b Reset
  7. HandleUndef:
  8.
  9.         b HandleUndef
  10. HandleSWI:
  11.
  12.         b HandleSWI
  13. HandlePrefetchAbort:
  14.
  15.         b HandlePrefetchAbort
  16. HandleDataAbort:
  17.
  18.         b HandleDataAbort
  19. HandleNotUsed:
  20.
  21.         b HandleNotUsed
  22.
  23.
  24.         b HandleIRQ
  25. HandleFIQ:
  26.
  27.         b HandleFIQ
  28. Reset:
  29.
  30.         ldr sp,=0x1000
  31.
  32.         ldr r0,=0x53000000
  33.
  34.         mov r1,#0x0
  35.
  36.         str r1,[r0]
  37.
  38.
  39.         msr cpsr_c,#0xd2
  40.
  41.         ldr sp,=3072
  42.
  43.
  44.         msr cpsr_c,#0xdf
  45.
  46.         ldr sp,=0x1000
  47.
  48.
  49.         bl IO_Init
  50.
  51.         bl IRQ_Init
  52.
  53.         msr cpsr_c,#0x5f
  54.
  55.         ldr lr,=loop
  56.
  57.         ldr pc,=INT_Main
  58. loop:
  59.
  60.         b loop
  61. HandleIRQ:
  62.
  63.         sub lr,lr,#4
  64.
  65.         s>真美妙b sp!,{r0-r12,lr}
  66.
  67.         ldr lr,=int_return
  68.
  69.         ldr pc,=IRQ_Ser
  70. int_return:
  71.
  72.         ldmia sp!,{r0-r12,pc}^
  73. .end
  74. 》》》》》》》》》》》》》》》》》
  75. #define rSRCPND                (*(volatile unsigned *)0x4a000000)
  76. #define rINTMOD         (*(volatile unsigned *)0x4a000004)
  77. #define rINTMSK                (*(volatile unsigned *)0x4a000008)
  78. #define rPRIORITY        (*(volatile unsigned *)0x4a00000c)
  79. #define rINTPND                (*(volatile unsigned *)0x4a000010)
  80. #define rINTOFFSET        (*(volatile unsigned *)0x4a000014)
  81. #define rSUBSRCPND        (*(volatile unsigned *)0x4a000018)
  82. #define rINTSUBMSK        (*(volatile unsigned *)0x4a00001c)
  83. #define rGPBCON                (*(volatile unsigned *)0x56000010)
  84. #define rGPBDAT                (*(volatile unsigned *)0x56000014)
  85. #define rGPBUP                (*(volatile unsigned *)0x56000018)
  86. #define rGPFCON         (*(volatile unsigned *)0x56000050)
  87. #define rGPFDAT                (*(volatile unsigned *)0x56000054)
  88. #define rGPFUP                (*(volatile unsigned *)0x56000058)
  89. #define rEXTINT0         (*(volatile unsigned *)0x56000088)
  90. #define rEXTINT1        (*(volatile unsigned *)0x5600008c)
  91. #define rEXTINT2        (*(volatile unsigned *)0x56000090)
  92. #define rEINTFLT0        (*(volatile unsigned *)0x56000094)
  93. #define rEINTFLT1        (*(volatile unsigned *)0x56000098)
  94. #define rEINTFLT2        (*(volatile unsigned *)0x5600009c)
  95. #define rEINTFLT3        (*(volatile unsigned *)0x560000a0)
  96. #define rEINTMASK        (*(volatile unsigned *)0x560000a4)
  97. #define rEINTPEND        (*(volatile unsigned *)0x560000a8)
  98. void IO_Init(void);
  99. void IRQ_Init(void);
  100. void Delay(unsigned short t);
  101. int INT_Main(void)
  102. {
  103.         while(1)
  104.         {
  105.                 rGPBDAT = ~(1<<8);
  106.                 Delay(50);
  107.                 rGPBDAT = ~(1<<10);
  108.                 Delay(50);
  109.         }
  110.         return 0;
  111. }
  112. void IO_Init(void)
  113. {
  114.         rGPBCON = 0x1dd7fc;
  115.         rGPBDAT = (1<<5)|(1<<6)|(1<<8)|(1<<10);
  116.         rGPBDAT &= 0xffe;
  117.         rGPBUP = 0X00;
  118.         rGPFCON = 1<<5;
  119.         //rGPFUP |= (1<<0);
  120. }
  121. void IRQ_Init(void)
  122. {
  123.         rSRCPND = (1<<2);
  124.         rINTPND = (1<<2);
  125.         rINTMSK = ~(1<<2);
  126. }
  127. void IRQ_Ser(void)
  128. {
  129.         rEINTPEND = 0;
  130.         rSRCPND = 0;
  131.         rINTPND = (1<<2);
  132.         while(1)
  133.         {
  134.                 rGPBDAT = ~(1<<5);
  135.                 Delay(50);
  136.                 rGPBDAT = ~(0<<5);
  137.                 Delay(50);
  138.                 rGPBDAT = ~(1<<5);
  139.         }
  140. }
  141. void Delay(unsigned short t)
  142. {
  143.         unsigned char i,j;
  144.         while(t--)
  145.         {
  146.                 for(i=0;i<0xff;i++)
  147.                         for(j=0;j<0xff;j++);
  148.         }
  149. }
这段代码有什么问题吗?为什么会出现Dabort exception错误,求解决,求解决,求解决
GMT+8, 2026-10-4 22:47
