查看: 9978|回复: 2
[Linux] NFS建立挂载时黑屏并且系统启动不了,,求请版主指点啊。。
发表于 2013-12-3 09:10:50 | 显示全部楼层 |阅读模式
uboot命令行执行这条:setenv bootargs "root=/dev/nfs nfsroot=192.168.6.137:/forlinx/root/FileSystem-Yaffs2 ip=192.168.6.232:192.168.6.137:192.168.6.201:255.255.255.0:witech.com.cn:eth0:off console=ttySAC0,115200"
然后saveenv。。。。发现显示屏白屏了。。。
重启开发板后系统启动不起来,卡住了,而且显示屏黑屏。。串口输出信息如下
dm9000 dm9000.0: eth0: link down
dm9000 dm9000.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[<c00393a8>] (unwind_backtrace+0x0/0xf8) from [<c04eecfc>] (dump_stack+0x18/0x1c
[<c04eecfc>] (dump_stack+0x18/0x1c) from [<c04eed64>] (panic+0x64/0x188)
[<c04eed64>] (panic+0x64/0x188) from [<c0008ea8>] (mount_block_root+0x180/0x250)
[<c0008ea8>] (mount_block_root+0x180/0x250) from [<c0009020>] (mount_root+0xa8/0
xcc)
[<c0009020>] (mount_root+0xa8/0xcc) from [<c0009178>] (prepare_namespace+0x134/0
x198)
[<c0009178>] (prepare_namespace+0x134/0x198) from [<c00084c0>] (kernel_init+0xec
/0x120)
[<c00084c0>] (kernel_init+0xec/0x120) from [<c0033c54>] (kernel_thread_exit+0x0/
0x8)
请求版主指点啊。。。怎么回事?为什么nfs不行。。
wuyiqinfeng 该用户已被删除
发表于 2013-12-3 09:34:41 | 显示全部楼层
 楼主| 发表于 2013-12-3 10:35:06 | 显示全部楼层
wuyiqinfeng 发表于 2013-12-3 09:34
一样的呀,我也是,上来看看有没有碰到过解决掉了的
呵呵。。静等版主哦。。
GMT+8, 2026-10-4 21:41
