查看: 8479|回复: 2
[Linux] 三根线调通GPRS模块,QT应用程序,实现短信发送,电话接听和打电话的功能
发表于 2014-1-24 19:24:28 | 显示全部楼层 |阅读模式
源码:
gprs.cpp
#include <QtGui/QApplication>
#include <QtCore/QTextCodec>
#include "gprs_main.h"
int main(int argc,char* argv[])
QApplication app(argc,argv);
GprsWindow gprsWin;
QFont font  = app.font();
font.setPointSize(7);
app.setFont(font);
gprsWin.show();
return app.exec();
message.cpp
#include <QtGui>
#include <QtCore>
#include <sys/ioctl.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/types.h>
#include <fcntl.h>
#include <stdio.h>
#include "message.h"
#include <termio.h>
int gprs_fd;
int state;
int calling_state;
MesDialog::MesDialog(QWidget* parent):QDialog(parent)
setupUi(this);
setWindowTitle(tr("Message and calling"));
    connect(num1,SIGNAL(clicked()),this,SLOT(numbtnclicked()));
    connect(num2,SIGNAL(clicked()),this,SLOT(numbtnclicked()));
        connect(num3,SIGNAL(clicked()),this,SLOT(numbtnclicked()));
    connect(num4,SIGNAL(clicked()),this,SLOT(numbtnclicked()));
    connect(num5,SIGNAL(clicked()),this,SLOT(numbtnclicked()));
    connect(num6,SIGNAL(clicked()),this,SLOT(numbtnclicked()));
        connect(num7,SIGNAL(clicked()),this,SLOT(numbtnclicked()));
        connect(num8,SIGNAL(clicked()),this,SLOT(numbtnclicked()));
        connect(num9,SIGNAL(clicked()),this,SLOT(numbtnclicked()));
        connect(num0,SIGNAL(clicked()),this,SLOT(numbtnclicked()));
        connect(a,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(b,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(c,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(d,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(f,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(g,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(h,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(i,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(j,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(k,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(l,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(m,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(n,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(o,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(p,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(q,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(r,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(s,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(t,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(u,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(v,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(w,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(xx,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(yy,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(z,SIGNAL(clicked()),this,SLOT(charbtnclicked()));
        connect(call,SIGNAL(clicked()),this,SLOT(callbtn()));
        connect(send,SIGNAL(clicked()),this,SLOT(sendbtn()));
        connect(send_2,SIGNAL(clicked()),this,SLOT(cancel_message()));
        connect(send_3,SIGNAL(clicked()),this,SLOT(break_call()));
        connect(d_num,SIGNAL(clicked()),this,SLOT(delete_num()));
        connect(d_chr,SIGNAL(clicked()),this,SLOT(delete_char()));
        connect(open_tty,SIGNAL(clicked()),this,SLOT(open_uart()));
        connect(listenButton,SIGNAL(clicked()),this,SLOT(listen_call()));
        connect(receive_message,SIGNAL(clicked()),this,SLOT(receive_message1()));
        send_3->setEnabled(false);//将挂断按键设置为可用
        listenButton->setEnabled(false);//将接电话的按键使能
    send_3->setEnabled(false);  //将挂断电话的按键使能
        state=0;
        calling_state=0;
MesDialog::~MesDialog()//析构函数
        ::system("killall pppd");
        if (gprs_fd >= 0) {
       ::close(gprs_fd);
       gprs_fd = -1;
void MesDialog::numbtnclicked()  //那好几个按键
        QPushButton *btn=(QPushButton*)sender();//返回发送信号的对象的指针
        QString numValue=btn->text();
        lineEdit->setText(lineEdit->text()+numValue);
void MesDialog::charbtnclicked()//那好几个按键
        QString charValue=btn->text();
    textEdit->moveCursor(QTextCursor::End);//在文本框中添加字符
    textEdit->insertPlainText(charValue);
void MesDialog::callbtn()
     state=CALL_OK;
     QString telnum;
         telnum=lineEdit->text();//
     QString send="ATD"+telnum+";\r";
     if (telnum.isEmpty())
                QMessageBox::information(this,"gprs","plesse input the address",0);//这是提示消息框!!要会用
                    return ;
         ::write(gprs_fd,"ATE1\r",strlen("ATE1\r"));
         sleep(1);
         ::write(gprs_fd,"AT+COLP=1\r",strlen("AT+COLP=1\r"));
         sleep(1);
        if(::write(gprs_fd,send.toLatin1(),send.length()))//可能是包含中文字符的意思  这样转换一下来可以,不然上边的不会正常发送的!!!!!!!!!!!!!!!!!!!!!!!!!!!
                send_3->setEnabled(true);//将挂断按键设置为可用
void MesDialog::sendbtn()
QString mess=textEdit->toPlainText()+"\x1a";//最后的发送指令
QString num;
char getch[15];
QString tell="AT+CMGS=\""+num+"\"\r";
    ::write(gprs_fd,"AT+CMGF=1\r",strlen("AT+CMGF=1\r"));
        sleep(1);
        ::write(gprs_fd,"AT+CSCS=\"GSM\"\r",strlen("AT+CSCS=\"GSM\"\r"));
        sleep(1);
if(::write(gprs_fd,tell.toLatin1(),tell.length()))
        sleep(1);
        //QMessageBox::information(this,"gprs",mess,0);
if(::write(gprs_fd,mess.toLatin1(),mess.length()))
      sleep(1);
          state=SEND_OK;
void MesDialog::cancel_message()
QMessageBox::information(this,"gprs","cancel_message",0);
void MesDialog::break_call() //挂断电话
::write(gprs_fd,"ATH\r",strlen("ATH\r"));
sleep(1);
calling_state=0;
void MesDialog::delete_num()
     QString telnum;
     telnum=lineEdit->text();//获取文本框中的号码
         QString t = telnum.left(telnum.length()-1);//长度减去1 就是回删键
      lineEdit->setText(t);
void MesDialog::delete_char()
textEdit->clear();//这个可以
void MesDialog::listen_call()
::write(gprs_fd,"ATA\r",strlen("ATA\r"));
sleep(1);
calling_state=0;
void MesDialog::receive_message1()
void MesDialog::open_uart()
gprs_fd = openSerialPort();
    if (gprs_fd < 0) {
    QMessageBox::warning(this, tr("Error"), tr("Fail to open serial port!"));
    return ;
        ::write(gprs_fd,"AT+CNMI=2,1\r",strlen("AT+CNMI=2,1\r"));
        sleep(1);
        state=3;
   m_notifier = new QSocketNotifier(gprs_fd, QSocketNotifier::Read, this); //监听系统的文件操作
   connect (m_notifier, SIGNAL(activated(int)), this, SLOT(remoteDataIncoming())); //即串口有数据回读回来后就会调用这个
int MesDialog::openSerialPort()
  int fd = -1;
  fd = ::open("/dev/ttySAC1", O_RDWR|O_NONBLOCK);//驱动设备打开函数
  if (fd < 0) {
    QMessageBox::warning(this, tr("Error"), tr("cannot open the driver of uart1"));
    return -1;
  termios serialAttr;//qt中关于串口的函数标准的c函数  这是一个结构体!
  memset(&serialAttr, 0, sizeof serialAttr);//在一段没纯种添加某一值,通常用作清零   将首地址为serialAttr大小为serialAttr的设为0
        cfsetispeed(&serialAttr,B9600);
        cfsetospeed(&serialAttr,B115200);//115200
        serialAttr.c_cflag &= ~CSIZE;//8位
        serialAttr.c_cflag |= CS8;
        serialAttr.c_iflag = IGNPAR;//没有奇偶校验
  if (tcsetattr(fd, TCSANOW, &serialAttr) != 0) //把我们的设置写进结构体
    QMessageBox::warning(this, tr("Error"), tr("cannot write into qt_struct"));
    return -1;
  return fd;
//获取回显信息
void MesDialog::remoteDataIncoming()
        char getch[30];
        if(::read(gprs_fd,getch,30))//就是这一个
        //QMessageBox::information(this,"gprs","uart feedback information!",0);
        QString mes_or_tell = QString(getch); //数据的首地址 数组
    QString r_message=QString(getch);
        int m_ok=r_message.indexOf(QRegExp("OK"),0);
        int m_err=r_message.indexOf(QRegExp("ERROR"),0);
    int tell_iscome=mes_or_tell.indexOf(QRegExp("RING"), 0);//若是找到这个字符串
        int mes_iscome=mes_or_tell.indexOf(QRegExp("CMTI"), 0);//找到这个字符串   来信息的字符串
        int send_message=mes_or_tell.indexOf(QRegExp("CMGS"),0);
        if(send_message>=0)
        {state=0;
        QMessageBox::information(this,"gprs","message has been send",0);
        if(m_ok>=0)
        if(state==3)
        {state=0;
        QMessageBox::information(this,"gprs","receive setting is ok",0);
        if(m_err>=0)
        if(state==3)
        state=0;
        QMessageBox::information(this,"gprs","receive setting is error",0);
        if(state==SEND_OK)
        state=0;
        QMessageBox::information(this,"gprs","error when send message",0);
        if(mes_iscome>=0)
                        QMessageBox::information(this,"gprs"," new message",0);
                if(tell_iscome>=0)
                    if(calling_state==0)
                QMessageBox::StandardButton rb=QMessageBox::information(this,"gprs","tell is coming",QMessageBox::Ok);
                        if(rb==QMessageBox::Ok)
                        calling_state=1;
                        else
                        calling_state=0;
                        listenButton->setEnabled(true);//将接电话的按键使能
                        send_3->setEnabled(true);  //将挂断电话的按键使能
message.h
#ifndef MESSAGE_H_
#define MESSAGE_H_
#include <QtGui>
#include "message_ui.h"
#define CALL_OK  1
#define SEND_OK  2
#define HAVE_SEND  8
class MesDialog:public QDialog,public Ui_message_dialog
Q_OBJECT
private:
     int openSerialPort();
public:
MesDialog(QWidget* =0);
virtual ~MesDialog();
public slots:
void numbtnclicked();
void charbtnclicked();
void sendbtn();
void callbtn();
void break_call();
void cancel_message();
void delete_num();
void delete_char();
void open_uart();
void remoteDataIncoming();
void listen_call();
void receive_message1();
private:
QSocketNotifier *m_notifier;
#endif
发表于 2014-1-25 13:11:40 | 显示全部楼层
发表于 2014-2-10 10:30:43 | 显示全部楼层
:lol:lol:lol:lol
GMT+8, 2026-10-4 20:29
