查看: 6271|回复: 1
fl2440 插入U盘之后出现下面的信息!
发表于 2014-3-12 18:38:27 | 显示全部楼层 |阅读模式
当插入U盘的时候出现下面 的提示信息应该是安装驱动成功了,但是我在对应的/dev下面没发现对应的sda4驱动名就没发挂载,请问如何解决,
  1. # usb 1-1.2: USB disconnect, address 3
  2. usb 1-1.1: new full speed USB device using s3c2410-ohci and address 5
  3. usb 1-1.1: configuration #1 chosen from 1 choice
  4. scsi1 : SCSI emulation for USB Mass Storage devices
  5. usb 1-1.1: New USB device found, idVendor=0930, idProduct=6545
  6. usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  7. usb 1-1.1: Product: DataTraveler G3
  8. usb 1-1.1: Manufacturer: Kingston
  9. usb 1-1.1: SerialNumber: 001372982B41EC2085D202EF
  10. scsi 1:0:0:0: Direct-Access     Kingston DataTraveler G3  PMAP PQ: 0 ANSI: 0 CCS
  11. sd 1:0:0:0: [sda] 30481152 512-byte hardware sectors: (15.6 GB/14.5 GiB)
  12. sd 1:0:0:0: [sda] Write Protect is off
  13. sd 1:0:0:0: [sda] Assuming drive cache: write through
  14. sd 1:0:0:0: [sda] 30481152 512-byte hardware sectors: (15.6 GB/14.5 GiB)
  15. sd 1:0:0:0: [sda] Write Protect is off
  16. sd 1:0:0:0: [sda] Assuming drive cache: write through
  17. sda: sda4
  18. sd 1:0:0:0: [sda] Attached SCSI removable disk
  19. sd 1:0:0:0: Attached scsi generic sg0 type 0
发表于 2014-3-14 09:37:20 | 显示全部楼层
楼主,我已经在另一个帖子中回复您了:http://bbs.witech.com.cn/thread-47054-1-1.html
GMT+8, 2026-10-4 20:21
