查看: 5414|回复: 0
请教WINCE驱动问题
发表于 2014-5-3 16:55:17 | 显示全部楼层 |阅读模式
因为要用到一个中断,下降沿触发,所以自己尝试着写了一个中断驱动,运行起来没有什么问题,就是在关掉应用程序后再次打开应用程序后中断程序能进去,但是下降沿再也没有什么反应了:
初始化函数如下:
DWORD XPI_Open(DWORD hDeviceContext, DWORD AccessCode, DWORD ShareMode)
        RETAILMSG(1,(TEXT("************[XPI]: XPI_OPEN***********\r\n")));
        g_pGPIOReg = (volatile GPIO_REG*)DrvLib_MapIoSpace(BASE_REG_PA_GPIO, sizeof(GPIO_REG), FALSE);
        if (g_pGPIOReg == NULL) {
                RETAILMSG(TRUE, (TEXT("[XPI]:VirtualAlloc GPIO failed!\r\n")));
        g_pGPIOReg->GPH0.GP_CON &= 0xfffffff0;
        g_pGPIOReg->GPH0.GP_CON |= 0x0000000F;//set the pin EXT_INIT[0]
        g_pGPIOReg->GPH0.GP_PUD &= 0xfffffffc;//
        g_pGPIOReg->GPH0.GP_PUD |= 0x00000002;//pull-up enable
        g_pGPIOReg->EINTCON.EXT_INT0_CON &= 0xfffffff0;
        g_pGPIOReg->EINTCON.EXT_INT0_CON |= 0x00000002;//falling edge trigered
        g_pGPIOReg->EINTFLT.EXT_FLT0_CON._FLT_CON0 &= 0xffffff00;
        g_pGPIOReg->EINTFLT.EXT_FLT0_CON._FLT_CON0 |= 0x000000c0;//enable delay filter
        g_pGPIOReg->EINTMSK.EXT_INT0_MASK &= 0xffffffe;//enable interrupt
        g_pGPIOReg->EINTPND.EXT_INT0_PEND &= 0xffffffE;
        g_pGPIOReg->EINTPND.EXT_INT0_PEND |= 0x00000001;
        m_interruptPhyId = IRQ_EINT0;
        if(!KernelIoControl(IOCTL_HAL_REQUEST_SYSINTR, &m_interruptPhyId, sizeof(DWORD), &m_interruptSysId, sizeof(DWORD), NULL))
                RETAILMSG(1, (TEXT("*************kernelIoControl fail\r\n")));
                m_interruptSysId = SYSINTR_UNDEFINED;
                return FALSE;
        m_interruptEvent = CreateEvent(NULL, FALSE, FALSE, NULL);
        if(INVALID_HANDLE_VALUE == m_interruptEvent)
                RETAILMSG(1, (TEXT("[XPI]:Create m_interruptEvent fail\r\n")));
                return FALSE;
        m_interruptThread=CreateThread(NULL, //Security
                0, //No Stack Size
                (LPTHREAD_START_ROUTINE)Threadproc,//Interrupt Thread
                NULL,        //No Parameters
                CREATE_SUSPENDED,        //Create Suspended
                lpThreadId);//Thread Id
        //set the thread priority
        threadpriority = 6;
        if( !CeSetThreadPriority( m_interruptThread, threadpriority))
                RETAILMSG(1,(TEXT("test: Failed setting Thread Priority.\r\n")));
                return FALSE;
        if (!InterruptInitialize(m_interruptSysId,m_interruptEvent,NULL,0))
                ERRORMSG( 1, (TEXT("test interrupt is not initialized\n\r")));
                return(FALSE);
        //translate the event handle
        hEventRecev=CreateEvent(NULL,FALSE,FALSE,_T("XPIReadEvent"));//2??§3?±?D??aNULL,ê?·?è?1¤????£?ê?·?3?ê??ˉ?aí¨?a×′ì?£?Event??×?
        if(INVALID_HANDLE_VALUE == hEventRecev)
                RETAILMSG(1, (TEXT("[XPI]:Create hEventRecev failed\r\n")));
                return FALSE;
        m_ExitThread = FALSE;
        RETAILMSG(1,(TEXT("[XPI]:ResumeThread***********\r\n")));
        ResumeThread(m_interruptThread);
        return TRUE;
上面就是创建了一个中断关联的等待线程。然后等待线程如下:
DWORD WINAPI Threadproc(LPVOID lpvParam)
        DWORD  dwStatus=0;
        BOOL  fState = TRUE;
        static BOOL count = TRUE;
        RETAILMSG(1,(TEXT("[XPI]:Entry test thread \r\n")));
        while (!m_ExitThread)
                dwStatus = WaitForSingleObject(m_interruptEvent,INFINITE);
                if (m_ExitThread)
                        RETAILMSG(1,(TEXT("[XPI]:break the thread!***********\r\n")));
                        break;
                switch(dwStatus)
                case WAIT_FAILED:
                        RETAILMSG(1,(TEXT("[XPI]:Wait Failed!***********\r\n")));
                        break;
                case WAIT_TIMEOUT:
                        RETAILMSG(1,(TEXT("[XPI]:Wait time out!***********\r\n")));
                        break;
                case WAIT_OBJECT_0+0:
                        SetEvent(hEventRecev);
                        RETAILMSG(1,(TEXT("[XPI]:DAB_NXP request the communication!***********\r\n")));
                        break;
                case WAIT_OBJECT_0+1:
                        RETAILMSG(1,(TEXT("[XPI]:Wait Canceled!***********\r\n")));
                        return TRUE;
                        break;
                InterruptDone(m_interruptSysId);
        return TRUE;
关闭函数如下
BOOL XPI_Close(DWORD hOpenContext)
        RETAILMSG(1,(TEXT("[XPI]: XPI_CLOSE***********\r\n")));
        m_ExitThread = TRUE;
        SetEvent(m_interruptEvent);
        if (WaitForSingleObject(m_interruptThread,2000) == WAIT_TIMEOUT)
                TerminateThread(m_interruptThread,0);
                RETAILMSG(1,(TEXT("[XPI]: force to quite the thread***********\r\n")));
        m_interruptThread = NULL;
        CloseHandle(m_interruptEvent);//ó2?t?D??ó3é?μ??μí3?D??
        CloseHandle(hEventRecev);//′?μY??ó|ó?3ìDòó?
        return TRUE;
第一次运行应用程序那个线程可以进去,下降沿也可以触发WaitForSingleObject返回,但是关闭之后第二次运行应用程序,驱动中也可以进入该线程中,但是下降沿却始终无法触发WaitForSingleObject返回,请教一下大家,是不是在close或是Deinit时还有什么没有做的操作啊?
GMT+8, 2026-10-4 19:17
