查看: 3779|回复: 1
S3C6410能否支持24BIT采样位数?
centos 该用户已被删除
发表于 2011-4-11 13:41:21 | 显示全部楼层 |阅读模式
发表于 2011-4-11 13:53:53 | 显示全部楼层
The IIS-BUS interface includes the following features:
• 2-ports stereo IIS bus for audio interface with DMA-based operation
• Serial, 8/16/24 bit per channel data transfers
• Supports sampling rate from 8kHz to 192kHz
• Supports IIS, MSB-justified and LSB-justified data format
• 64 Bytes Tx FIFO/64 Bytes Rx FIFO per each port
GMT+8, 2026-10-5 13:44
