查看: 7814|回复: 1
急!!!eboot启动出错
发表于 2011-4-11 22:39:30 | 显示全部楼层 |阅读模式
今天编译一个内核,想烧写到开发板上,但是无法从sd卡启动,后来就想是不是当时我从wince转到linux时,没有用eboot下的A选项,后来就去重新烧写eboot,在使用A选项,但是后来发现两个系统都无法烧写。
1.参考wince用户手册,从sd卡启动后,下载了eboot.nb0,后来进入选项,但是其中有5和6的选项,在刚开始的时候是正常的,但是后来使用其他选项时,就变得不正常了,具体情况如下:
!!! USB host is connected !!!
- Bulk In EP : 1
- Bulk Out EP : 2
- Speed : High
- Op Mode : DMA mode
Download & Run is selected
Select a file to download in DNW
[ADDRESS:50030000h,TOTAL:524298(0x80000)]
(29.175MB/s,0.017s)
Checksum is being calculated....
(If you want to skip, press 'x' key)
Checksum O.K.
H?
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Aug  8 2010 13:24:59
Microsoft Windows CE Bootloader for the Samsung SMDK6410 Version 2.4 Built Aug 23 2010
+OALArgsInit()
SocID:0x36410101
Arguments area is initialized
-OALArgsInit()
INFO: (unsigned)C_IsrHandler : 0x8003F9EC
INFO: (unsigned)ASM_IsrHandler : 0x80041FFC
INFO: (unsigned)pISR : 0xEA0107F7
BP_Init
[FMD] ++FMD_Init() ****
[FMD:INF] FMD_Init() : Read ID = 0x0000ecd3
[FMD] FMD_Init() : NUM_OF_BLOCKS = 4096
[FMD] FMD_Init() : SECTORS_PER_PAGE = 4
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 4096(0x1000), SECTORSPERBLOCK = 128(0x80), BYTESPERSECTOR = 2048(0x800)
wNUM_BLOCKS : 4096(0x1000)
[Eboot] ++InitializeDisplay()
[Eboot] --InitializeDisplay()
Initiating image launch in 4 seconds.
Ethernet Boot Loader Configuration:
0) IP address: 0.0.0.0
1) Subnet mask: 255.255.255.0
2) DHCP: Disabled
3) Boot delay: 5 seconds
7) Program DM9000A MAC address (00:00:00:00:00:00)
8) KITL Configuration: DISABLED
A) Erase All Blocks
B) Mark Bad Block at Reserved Block
C) Clean Boot Option: FALSE
D) Download image now
E) Erase Reserved Block
R) Read Configuration
S) Lcd Resolution select(320x240)
U) DOWNLOAD image now(USB)
Enter your selection: A
All block(4096) Erase...
2) DHCP: Disabled
A) Erase All Blocks
Enter your selection: 6
2) DHCP: Disabled
6) Program disk image into SmartMedia card: Disabled
A) Erase All Blocks
Enter your selection: 5
2) DHCP: Disabled
5) Startup image: DOWNLOAD NEW
A) Erase All Blocks
导致最后出现:
ownload BIN file information:
[0]: Base Address=0xfffff000  Length=0x3058
Stepldr image
ImageStart = 0x0, ImageLength = 0x0, LaunchAddr = 0x0
Completed file(s):
[0]: Address=0xFFFFF000  Length=0x3058  Name="" Target=RAM
Stepldr image can't launch from ram.
You should program it into flash.
SpinForever...
请问是什么原因,怎样可以解决啊?
2.我的那个usb经常出现这种情况:在串口连接上的时候,显示ok,但是经常在传送文件的过程中自己断了,显示为x,这是什么原因?是usb接口的问题吗?
发表于 2011-4-12 08:43:42 | 显示全部楼层
分别按一下
之后,你在烧写。
请仔细看一下用户手册~
GMT+8, 2026-10-5 11:07
