查看: 13962|回复: 5
[Linux] 一键烧写wince6.0系统的问题
发表于 2014-6-6 20:01:52 | 显示全部楼层 |阅读模式
我的是OK6410-A板子,烧写时DNW显示如下:
Welcome! This tool just for TE/OK6410
+OALArgsInit()
SocID:0x36410101
Arguments area is initialized
-OALArgsInit()
INFO: (unsigned)C_IsrHandler : 0x8008095C
INFO: (unsigned)ASM_IsrHandler : 0x80084018
INFO: (unsigned)pISR : 0xEA020FFE
HSMMC init
[HSMMC1] Setting registers for the EPLL (for SDCLK) : SYSCon.
[HSMMC0] Setting registers for the GPIO.
[HSMMC1] Setting registers for the EPLL : HSMMCCon.
#### this SD card is made on SPEC 2.0
This SD card is made on SPEC 2.0
This SD card is High Capacity
CardSize: 15278080 sector
[HSMMCLIB:INF] ClockConfig() Card Working Frequency = 24MHz
BP_Init
[FMD] ++FMD_Init() ****
[FMD:INF] FMD_Init() : Read ID = 0x0000ecd5
[FMD] FMD_Init() : NUM_OF_BLOCKS = 4096
[FMD] FMD_Init() : SECTORS_PER_PAGE = 8
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 4096(0x1000), SECTORSPERBLOCK = 128(0x80), BYTESPERSECTOR = 4096(0x1000)
wNUM_BLOCKS : 4096(0x1000)
[Eboot] ++InitializeDisplay()
[Eboot] --InitializeDisplay()
Initiating image launch in 0 seconds.
Starting auto-download ...
Erase  the block '0..3'
System ready!
Preparing for download...
IsCardInserted
f_mount return = 0x0
FileInfo.fsize = 0x2000
g_pDownPt = 0xA300211B
BL_IMAGE_TYPE_MANIFEST
BL_IMAGE_TYPE_UNKNOWN
Download BIN file information:
[0]: Base Address=0x0  Length=0x2000
Stepldr image
ImageStart = 0x0, ImageLength = 0x2000, LaunchAddr = 0x0
Completed file(s):
[0]: Address=0x0  Length=0x2000  Name="stepldr.nb0" Target=RAM
BP_Init  iSighForSlcMlc = 1
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 8192(0x2000), SECTORSPERBLOCK = 8(0x8), BYTESPERSECTOR = 2048(0x800)
dwImageLength = 0x2000
dwNumBlocks = 0x1
dwBlock(0x0) X g_FlashInfo.wSectorsPerBlock(0x8) = 0x0
dwBytesPerBlock : 16384
INFO: Step loader image stored to Smart Media.  Please Reboot.  Halting...
IsCardInserted
FileInfo.fsize = 0x5CB5B
g_pDownPt = 0xA305CB5B
BL_IMAGE_TYPE_BIN
[0]: Base Address=0x80030000  Length=0x5efe0
Eboot image
rom_offset=0x0.
ImageStart = 0x80030000, ImageLength = 0x5EFE0, LaunchAddr = 0x80081BC4
Completed file(s):
[0]: Address=0x80030000  Length=0x5EFE0  Name="" Target=RAM
ROMHDR at Address 80030044h
BP_Init  iSighForSlcMlc = 0
[FMD] --FMD_Init()
dwImageLength = 0x5efe0
dwNumBlocks = 0x1
dwBlock(0x2) X g_FlashInfo.wSectorsPerBlock(0x80) = 0x100
dwBytesPerBlock : 524288
TOC {
dwSignature: 0x434F544E
BootCfg {
  ConfigFlags: 0x20830
  BootDelay: 0x2
  ImageIndex: 1
  IP: 0.0.0.0
  MAC Address: 00:00:00:00:00:00
  Port: 0.0.0.0
  SubnetMask: 255.255.255.0
ID[0] {
  dwVersion: 0x20004
  dwSignature: 0x45424F54
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x5F
  dwLoadAddress: 0x80030000
  dwJumpAddress: 0x80081BC4
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x100
  sgList[0].dwLength: 0x5F
ID[1] {
  dwVersion: 0x1
  dwSignature: 0x43465348
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x23F9
  dwLoadAddress: 0x80150000
  dwJumpAddress: 0x8015768C
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x380
  sgList[0].dwLength: 0x23F9
chainInfo.dwLoadAddress: 0X00000000
chainInfo.dwFlashAddress: 0X00000000
chainInfo.dwLength: 0X00000000
INFO: Eboot image stored to Smart Media.  Please Reboot.  Halting...
Reserving Blocks [0x0 - 0x2] ...
...reserve complete.
Enter LowLevelFormat [0x3, 0xfff].
WriteMBR: MBR block = 0x3.
Done.
BinFS format done.
IsCardInserted
FileInfo.fsize = 0x235E653
g_pDownPt = 0xA535E653
BL_IMAGE_TYPE_BIN
[0]: Base Address=0x80150000  Length=0x23f8b98
RAM image
rom_offset=0x0.
ImageStart = 0x80150000, ImageLength = 0x23F8B98, LaunchAddr = 0x8015768C
Completed file(s):
[0]: Address=0x80150000  Length=0x23F8B98  Name="" Target=RAM
ROMHDR at Address 80150044h
+WriteOSImageToBootMedia: g_dwTocEntry =1, ImageStart: 0x80150000, ImageLength: 0x23f8b98, LaunchAddr:0x8015768c
INFO: OEMLaunch: Found chain extenstion: '' @ 0x80150000
Writing single region/multi-region update, dwBINFSPartLength: 37718936
IsValidMBR: block = 0x0.
IsValidMBR: block = 0x1.
IsValidMBR: block = 0x2.
IsValidMBR: MBR sector = 0x180 (valid MBR)
OpenPartition: Partition Exists=0x0 for part 0x21.
CreatePartition: Enter CreatePartition for 0x21.
LastLogSector: Last log sector is: 0x7fd7f.
CreatePartition: Start = 0x200, Num = 0x2400.
Log2Phys: Logical 0x200 -> Physical 0x380
BP_SetDataPointer at 0x0
Write OS to Nand Flash finished!!!
Updated TOC!
OpenPartition: Partition Exists=0x0 for part 0xb.
CreatePartition: Enter CreatePartition for 0xb.
FindFreeSector: FreeSector is: 0x2600 after processing part 0x21.
CreatePartition: Num sectors set to 0x7d280 to allow for compaction blocks.
CreatePartition: Start = 0x2600, Num = 0x7d280.
TOC {
BootCfg {
  BootDelay: 0x2
  ImageIndex: 1
  IP: 0.0.0.0
  Port: 0.0.0.0
ID[0] {
  dwVersion: 0x20004
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x5F
  dwStoreOffset: 0x0
ID[1] {
  dwVersion: 0x1
  String: ''
  dwImageType: 0x2
  dwStoreOffset: 0x0
waitforconnect
INFO: using TOC[1] dwJumpAddress: 0x8015768c
Success!
SpinForever...
到这里蜂鸣器响了。
发表于 2014-6-7 09:08:31 | 显示全部楼层
楼主,你想说啥问题啊?
对不起,我是新手,表达的不清楚,就是蜂鸣器响了后,就一直停在这里了。  详情 回复 发表于 2014-6-7 11:01
 楼主| 发表于 2014-6-7 11:01:30 | 显示全部楼层
飞凌-unix 发表于 2014-6-7 09:08
楼主,你想说啥问题啊?
发表于 2014-6-7 14:02:11 | 显示全部楼层
蜂鸣器响之后,表示系统烧写完成了,如图所示:
然后,断电,将拨码拨回nandflash启动。楼主,你没有看用户手册吗?
重烧了一遍,拨回nandflash启动,上电,白屏,dnw没显示,求指导。  详情 回复 发表于 2014-6-7 15:13
 楼主| 发表于 2014-6-7 15:13:40 | 显示全部楼层
然后,断电,将拨码拨回nandflash启动。楼主,你没有看用 ...
擦除一下nandflash,然后再重烧  详情 回复 发表于 2014-6-7 17:52
发表于 2014-6-7 17:52:04 | 显示全部楼层
擦除一下nandflash,然后再重烧
GMT+8, 2026-10-4 18:12
