查看: 4438|回复: 3
请问wince中,用什么函数(C#)操作I/O口
gaopeng218 该用户已被删除
发表于 2011-4-13 21:44:32 | 显示全部楼层 |阅读模式
发表于 2011-4-14 08:21:33 | 显示全部楼层
[System.Runtime.InteropServices.DllImport("kernel32", SetLastError = true)]
    static extern unsafe System.IntPtr CreateFile
        string FileName,          // file name
        uint DesiredAccess,       // access mode
        uint ShareMode,           // share mode
        uint SecurityAttributes,  // Security Attributes
        uint CreationDisposition, // how to create
        uint FlagsAndAttributes,  // file attributes
        int hTemplateFile         // handle to template file
    static extern unsafe bool ReadFile
        System.IntPtr hFile,      // handle to file
        void* pBuffer,            // data buffer
        int NumberOfBytesToRead,  // number of bytes to read
        int* pNumberOfBytesRead,  // number of bytes read
        int Overlapped            // overlapped buffer
    static extern unsafe bool CloseHandle
        System.IntPtr hObject // handle to object
    public bool Open(string FileName)
        // open the existing file for reading
        handle = CreateFile
            FileName,
            GENERIC_READ,
            0,
            0,
            OPEN_EXISTING,
            0,
        if (handle != System.IntPtr.Zero)
            return true;
        else
            return false;
    public unsafe int Read(byte[] buffer, int index, int count)
        int n = 0;
        fixed (byte* p = buffer)
            if (!ReadFile(handle, p + index, count, &n, 0))
                return 0;
        return n;
gaopeng218 该用户已被删除
 楼主| 发表于 2011-4-16 21:23:28 | 显示全部楼层
fdlm 该用户已被删除
发表于 2011-10-21 23:12:22 | 显示全部楼层
GMT+8, 2026-9-21 19:51
