查看: 5456|回复: 7
yaffs: auto selecting yaffs2停住了
coralht 该用户已被删除
发表于 2011-4-18 21:26:57 | 显示全部楼层 |阅读模式
发表于 2011-4-19 07:56:16 | 显示全部楼层
把串口打印的数据,都发上来吧·
这一点,看不出来问题~
coralht 该用户已被删除
 楼主| 发表于 2011-4-19 09:41:43 | 显示全部楼层
coralht 该用户已被删除
 楼主| 发表于 2011-4-19 09:43:21 | 显示全部楼层
发表于 2011-4-19 13:04:10 | 显示全部楼层
mtdblock3的地址,跟你yaffs烧写那个地址一致吗?
coralht 该用户已被删除
 楼主| 发表于 2011-4-19 13:41:31 | 显示全部楼层
发表于 2011-4-19 16:33:46 | 显示全部楼层
====================LINUX============================
LINUX分区表改为:(/arch/arm/mach-s3c2410/devs.c)
struct mtd_partition TE24xx_default_nand_part_b[]= {
        [0] = {
                .name   = "Boot",
                .size   = 0x00100000,
                .offset = 0
        [1] = {
                .name   = "MyApp",
                .size   = 0x003c0000,
                .offset = 0x00140000,
        [2] = {
                .name   = "Kernel",
                .size   = 0x00300000,
                .offset = 0x00500000,
        [3] = {
                .name   = "fs_yaffs",
                .size   = 0x07800000,    //原为60M现大小增大一倍
                .offset = 0x00800000,
/*      [4] = {
                .name   = "WINCE",
                .size   = 0x03c00000,
                .offset = 0x04400000,          //将wince屏蔽掉
struct s3c2410_nand_set nandset ={
nr_partitions: 4 ,               //原为5现改为4
partitions: TE24xx_default_nand_part_b,  //partition_info 64M
然后重新编译内核
boot源码中将nand.c中改为如下所示
static struct Partition NandPart[] = {
        {0,                          0x00100000, "boot"},                //128K
        {0x00100000, 0x00040000, "bootParam"},//two blocks
        {0x00140000, 0x003c0000, "MyApp"},                //4M512K
        {0x00500000, 0x00300000, "kernel"},                //3M128K
        //{0x00800000, 0x01400000, "fs_cramfs"},        //20M
        {0x00800000, 0x07800000, "fs_yaffs"},        //40M
//        {0x00500000, 0x03c00000, "wince"},                //60M
        {0,                         0         , 0}
然后重新编译boot即可
coralht 该用户已被删除
 楼主| 发表于 2011-4-20 16:04:28 | 显示全部楼层
GMT+8, 2026-10-5 14:53
