查看: 25431|回复: 3
[Linux] 求助:随机linux3.2内核编译时出现未申明变量
发表于 2014-8-11 11:38:04 | 显示全部楼层 |阅读模式
拿到335xS后,将随机的交叉工具arm-arago-linux-gnueabi,用该工具编译随机的linux3.2系统是出现如下错误,感觉是gpio的驱动程序中有未申明的变量了。版主们,这个问题需要我对linux3.2的内核驱动进行修改么?怎么解决?
  LD      drivers/cdrom/built-in.o
  CC      drivers/char/mem.o
  CC      drivers/char/random.o
  CC      drivers/char/ttyprintk.o
  CC      drivers/char/misc.o
  CC      drivers/char/hw_random/core.o
  LD      drivers/char/hw_random/rng-core.o
  LD      drivers/char/hw_random/built-in.o
  LD      drivers/char/ipmi/built-in.o
  LD      drivers/char/pcmcia/built-in.o
  CC      drivers/char/io_ctl.o
drivers/char/io_ctl.c: In function 'gpio_state_store':
drivers/char/io_ctl.c:77:31: error: 'UART3_RTS_CTL' undeclared (first use in this function)
drivers/char/io_ctl.c:77:31: note: each undeclared identifier is reported only once for each function it appears in
drivers/char/io_ctl.c: At top level:
drivers/char/io_ctl.c:85:2: warning: initialization from incompatible pointer type
make[2]: *** [drivers/char/io_ctl.o] Error 1
make[1]: *** [drivers/char] Error 2
make: *** [drivers] Error 2
 楼主| 发表于 2014-8-11 11:39:42 | 显示全部楼层
我将makefile将编译器修改为arm-arago-linux-gnueabi后,直接进行make uImage的,然后出现上面的错误
发表于 2014-8-11 14:04:11 | 显示全部楼层
你先按照手册操作下 看看有问题没
北斗★火云 该用户已被删除
发表于 2014-8-11 14:05:39 | 显示全部楼层
GMT+8, 2026-9-23 13:58
