查看: 24089|回复: 5
[Linux] OK335XS_II的板子以太网phy速度只能达到10M
发表于 2014-9-11 08:42:50 | 显示全部楼层 |阅读模式
买的OK335XS_II的开发板,进行网络测试的时候,网络的速度只能达到10M / full.用TFTP进行传输的时候速度很慢,请问下技术人员这是什么现象,按道理来说不应该的
发表于 2014-9-11 08:54:02 | 显示全部楼层
楼主,你测试网络速度的时候,是怎么测试的?
从内核的启动信息来看:具体如下: 1.719506] Bluetooth: RFCOMM ver 1.11 [ 1.723427] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 1.728961] Bluetooth: BNEP filters: protocol multicast [  详情 回复 发表于 2014-9-11 11:27
 楼主| 发表于 2014-9-11 11:27:16 | 显示全部楼层
从内核的启动信息来看:具体如下:
[    1.734418] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    1.741026] Registering the dns_resolver key type
[    1.746041] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    1.754056] ThumbEE CPU extension supported.
[    1.758570] mux: Failed to setup hwmod io irq -22
[    1.764188] Power Management for AM33XX family
[    1.769049] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[    1.775740] Copied the M3 firmware to UMEM
[    1.780100] Cortex M3 Firmware Version = 0x181
[    1.793127] clock: disabling unused clocks to save power
[    1.800940] Detected MACID=d0:39:72:17:b6:60
[    1.806695] cpsw: Detected MACID = d0:39:72:17:b6:62
[    1.816884] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    1.825718] rtc-ds1307 2-0068: setting system clock to 2014-07-14 21:27:43 UTC (1405373263)
[    1.838787] net eth0: CPSW phy found : id is : 0x20005c90
[    1.912784] mmc0: host does not support reading read-only switch. assuming write-enable.
[    1.923751] mmc0: new high speed SDHC card at address 1234
[    1.930110] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[    1.937236]  mmcblk0: p1 p2
[    3.832530] PHY: 0:00 - Link is Up - 10/Full
最后一行显示的是PHY: 0:00 - Link is Up - 10/Full  显示的10M
发表于 2014-9-11 15:38:54 | 显示全部楼层
楼上朋友,您的板卡是直接连接到100M交换机上面的吗?这样的现象出现的很特别,我们这边都是100M的板卡:
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting telnet daemon.
Starting inetd daemon.
Starting syslogd/klogd: done
2000-01-01 00:00:26: (log.c.166) server started
Stopping Bootlog daemon: bootlogd.
[   12.342884] PHY: 0:00 - Link is Up - 100/Full
_____   _____   _____    _       _   __   _  __    __
|  ___| /  _   |  _    | |     | | |   | |    / /
| |__   | | | | | |_| |  | |     | | |   | |   / /
|  __|  | | | | |  _  /  | |     | | | |   |   }  {
| |     | |_| | | |    | |___  | | | |   |  / /
|_|     _____/ |_|  _ |_____| |_| |_|  _| /_/  _
ok335x login:
发表于 2014-9-11 15:39:27 | 显示全部楼层
10M网络的现象还是很特别的,换一个网络环境试试看。如果还是有问题更新到我们最新升级镜像2014-09-10版本,再试试看。
我是直接连在电脑上的  详情 回复 发表于 2014-9-11 15:43
 楼主| 发表于 2014-9-11 15:43:33 | 显示全部楼层
飞凌-develop 发表于 2014-9-11 15:39
10M网络的现象还是很特别的,换一个网络环境试试看。如果还是有问题更新到我们最新升级镜像2014-09-10版本, ...
我是直接连在电脑上的
GMT+8, 2026-9-23 13:58
