查看: 11134|回复: 0
[Linux] 使用光盘内的3.0.1内核编译uImage出错:"R_ARM_JUMP24 against"
发表于 2014-11-22 11:53:02 | 显示全部楼层 |阅读模式
没有编译内核模块和安装内核模块前直接编译uImage没有问题,但是编译完内核模块并安装到根文件系统后再编译uImage就出现如下错误:
WARNING: modpost: Found 2 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
  GEN     .version
  CHK     include/generated/compile.h
  UPD     include/generated/compile.h
  CC      init/version.o
  LD      init/built-in.o
  LD      .tmp_vmlinux1
kernel/built-in.o:(.fixup+0x158): relocation truncated to fit: R_ARM_JUMP24 against `.init.text'
make: *** [.tmp_vmlinux1] Error 1
root@ubuntu:/home/xiaoaf/forlinux/linux-3.0.1# make bzImage
  CHK     include/linux/version.h
make[1]: `include/generated/mach-types.h' is up to date.
  CALL    scripts/checksyscalls.sh
  GEN     .version
  CC      init/version.o
  LD      init/built-in.o
  LD      .tmp_vmlinux1
GMT+8, 2026-10-4 17:14
