查看: 14310|回复: 1
[Linux] crente()文件属性问题
发表于 2014-12-15 13:37:52 | 显示全部楼层 |阅读模式
#include<stdio.h>
#include<stdlib.h>
#include<sys/types.h>
#include<sys/stat.h>
#include<fcntl.h>
#define RWRWRW S_IRUSR|S_IWUSR|S_IRGRP|S_IWGRP|S_IROTH|S_IWOTH
void create_file(char *filename)
     umask(S_IRGRP|S_IROTH);
    if(creat(filename, RWRWRW ) < 0)
           printf("create file %s failure!\n", filename);
           exit(EXIT_FAILURE);
     else
           printf("create file %s success!\n", filename);
int main(int argc, char *argv[])
    mode_t mask = umask(0);
    if(argc<2)
      perror("you han't input the filename,please try again!\n");
       exit(EXIT_FAILURE);
create_file(argv[1]);
exit(EXIT_SUCCESS);
执行:gcc file_creat.c  -o file_creat
root@boyang-virtual-machine:/opt/set1# ./file_creat file1
-rw-r--r-- 1 root root    0 12月 15 13:27 file1
在从新编译下:
-rw-r--r-- 1 root root    0 12月 15 13:34 file1
只有在更改文件名后文件的属性才能更改,问什么?
root@boyang-virtual-machine:/opt/set1# ./file_creat file5
-rw--w--w- 1 root root    0 12月 15 13:36 file5
 楼主| 发表于 2014-12-17 14:16:26 | 显示全部楼层
没有人回答这个问题?
GMT+8, 2026-10-4 17:12
