查看: 6601|回复: 1
usd的wifi驱动
发表于 2014-12-26 22:52:34 | 显示全部楼层 |阅读模式
  你好,我在OK210添加了USB的RTL8188的wif,加载了驱动,试了测试程序,发现没有发射出热点,请问是不是内核配置的问题,添加IP地址时打印出下列信息,不知道正确与否,请指教谢谢!
[# /home/wifi]# ifconfig wlan0 192.168.11.1
[   92.083881] +871x_drv - drv_open, bup=0
[   92.095099]  ===> FirmwareDownload91C() fw:Rtl819XFwImageArray_TSMC
[   92.099904] FirmwareDownload92C accquire FW from embedded image
[   92.105821] fw_ver=v80, fw_subver=0, sig=0x88c0
[   92.260319] Polling FW ready fail!! REG_MCUFWDL:0x00030006 .
[   92.264574] Reset 51 write8 REG_SYS_FUNC_EN:0x00f8
[   92.269450] Reset 51 write8 REG_SYS_FUNC_EN:0x00fc
[   92.281574] fw download ok!
[   92.282881] Set RF Chip ID to RF_6052 and RF type to 1T1R.
[   92.869571] reg 0x800, usb write 4 fail, status:-110 value=0x80040000, vendorreq_times:1
[   93.373318] reg 0x800, usb write 4 fail, status:-110 value=0x80040000, vendorreq_times:2
[   93.877193] reg 0x800, usb write 4 fail, status:-110 value=0x80040000, vendorreq_times:3
[   94.381194] reg 0x800, usb write 4 fail, status:-110 value=0x80040000, vendorreq_times:4
[   94.885068] reg 0x800, usb write 4 fail, status:-110 value=0x80040000, vendorreq_times:5
[   94.891693] [dvobjpriv:f090b01c][ERROR] continual_urb_error:5 > 4
[   95.115696] ==>  _InitAntenna_Selection ....
[   95.118480] _InitAntenna_Selection,Cur_ant:(1)Antenna_B
[   95.123694] IQK:Start!!!
[   95.127353] Path A IQK Success!!
[   95.130405] Path A IQK Success!!
[   95.132626] IQK: final_candidate is 0
[   95.136263] IQK: RegE94=0 RegE9C=0 RegEA4=0 RegEAC=0 RegEB4=0 RegEBC=0 RegEC4=0 RegECC=0
[   95.136271]  pdmpriv->TxPowerTrackControl = 1
[   95.249831] MAC Address from REG_MACID = 00:00:00:00:00:00
[   95.255300] rtl8192cu_hal_init in 3167ms
[   95.259204] MAC Address = 00:00:30:34:43:30
[   95.263533] -871x_drv - drv_open, bup=1
[   95.267419] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[# /home/wifi]# [   97.267756] ==>pwr_state_check_handler .fw_state(0)
[   97.271157] ==> rtw_ps_cmd  , enqueue CMD
[   97.275247] ###> rtw_cmd_thread break.................
[   97.280475] rtw_cmd_thread: leaving... check & free all cmd_obj resources
[   97.287105] rtw_cmd_thread: leaving... drop cmdcode:57
[   97.292221] rtw_cmd_thread: leaving... call up terminate_cmdthread_sema
发表于 2014-12-29 16:39:44 | 显示全部楼层
楼主,你是要建立AP热点吗?如果是,请查看手册6.2.33的内容“AP 功能”
GMT+8, 2026-10-4 17:12
