查看: 6342|回复: 2
[Linux] OK335XD商业开发板烧写linux无法启动
发表于 2014-12-29 20:38:37 | 显示全部楼层 |阅读模式
Starting kernel ...
[    0.000000] Linux version 3.2.0 (root@lf-bj) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #7 Mon Sep 1 14:55:00 CST 2014
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=ubi0:rootfs rw ubi.mtd=7,2048 rootfstype=ubifs rootwait=1 screentype=R screensize=800x480-7 calibrate=Y laohua=N
[    0.000000] Memory: 512032k/512032k available, 12256k reserved, 0K highmem
[    0.000000]       .text : 0xc0008000 - 0xc0699000   (6724 kB)
[    0.000000]       .init : 0xc0699000 - 0xc06d6000   ( 244 kB)
[    0.000000]       .data : 0xc06d6000 - 0xc0755b40   ( 511 kB)
[    0.000000]        .bss : 0xc0755b64 - 0xc07899b8   ( 208 kB)
[    0.000000] NR_IRQS:396
[    0.000191] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
[    0.057157] pid_max: default: 32768 minimum: 301
[    0.057295] Security Framework initialized
[    0.057399] Mount-cache hash table entries: 512
[    0.057797] CPU: Testing write buffer coherency: ok
[    0.058560] devtmpfs: initialized
[    0.078583] omap_hwmod: pruss: failed to hardreset
[    0.079680] print_constraints: dummy:
[    0.080037] NET: Registered protocol family 16
[    0.082202] OMAP GPIO hardware version 0.1
[    0.084757] omap_mux_init: Add partition: #1: core, flags: 0
[    0.086583]  omap_i2c.1: alias fck already exists
[    0.087748]  omap_hsmmc.0: alias fck already exists
[    0.088010]  omap_hsmmc.1: alias fck already exists
[    0.088592]  da8xx_lcdc.0: alias fck already exists
[    0.088879]  omap_i2c.2: alias fck already exists
[    0.090450]  d_can.0: alias fck already exists
[    0.090744]  davinci-mcasp.1: alias fck already exists
[    0.091992]  omap2_mcspi.1: alias fck already exists
[    0.092215]  omap2_mcspi.2: alias fck already exists
[    0.092479]  edma.0: alias fck already exists
[    0.092500]  edma.0: alias fck already exists
[    0.092519]  edma.0: alias fck already exists
[    0.128076] bio: create slab <bio-0> at 0
[    0.130294] SCSI subsystem initialized
[    0.132263] usbcore: registered new inte**ce driver usbfs
[    0.132584] usbcore: registered new inte**ce driver hub
[    0.132784] usbcore: registered new device driver usb
[    0.133096] registerd cppi-dma Intr @ IRQ 17
[    0.133111] Cppi41 Init Done Qmgr-base(e087a000) dma-base(e0878000)
[    0.133121] Cppi41 Init Done
[    0.133149] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[    0.133436] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[    0.147222] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[    0.148959] tps65217 1-0024: TPS65217 ID 0xe version 1.2
[    0.150928] print_constraints: DCDC1: 900 <--> 1800 mV at 1500 mV
[    0.152954] print_constraints: DCDC2: 900 <--> 3300 mV at 1100 mV
[    0.154941] print_constraints: DCDC3: 900 <--> 1500 mV at 1100 mV
[    0.156941] print_constraints: LDO1: 1000 <--> 3300 mV at 1800 mV
[    0.158945] print_constraints: LDO2: 900 <--> 3300 mV at 3300 mV
[    0.160916] print_constraints: LDO3: 1800 <--> 3300 mV at 1800 mV
[    0.162895] print_constraints: LDO4: 1800 <--> 3300 mV at 3300 mV
[    0.177226] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
[    0.178825] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.179578] Bluetooth: Core ver 2.16
[    0.179768] NET: Registered protocol family 31
[    0.179781] Bluetooth: HCI device and connection manager initialized
[    0.179797] Bluetooth: HCI socket layer initialized
[    0.179808] Bluetooth: L2CAP socket layer initialized
[    0.179838] Bluetooth: SCO socket layer initialized
[    0.180407] cfg80211: Calling CRDA to update world regulatory domain
[    0.181608] Switching to clocksource gp timer
[    0.199310] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.199519] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[    0.199855] MUSB0 controller's USBSS revision = 4ea20800
[    0.199890] musb0: Enabled SW babble control
[    0.200824] musb-hdrc musb-hdrc.0: USB OTG mode controller at e083e000 using DMA, IRQ 18
[    0.200993] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[    0.201299] MUSB1 controller's USBSS revision = 4ea20800
[    0.201327] musb1: Enabled SW babble control
[    0.201833] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    0.201930] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    0.202085] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.202101] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.202115] usb usb1: Product: MUSB HDRC host driver
[    0.202126] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[    0.202136] usb usb1: SerialNumber: musb-hdrc.1
[    0.203086] hub 1-0:1.0: USB hub found
[    0.203120] hub 1-0:1.0: 1 port detected
[    0.203725] musb-hdrc musb-hdrc.1: USB Host mode controller at e084a800 using DMA, IRQ 19
[    0.204163] NET: Registered protocol family 2
[    0.204358] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.204682] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.204980] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[    0.205155] TCP: Hash tables configured (established 16384 bind 16384)
[    0.205167] TCP reno registered
[    0.205179] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.205214] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.205395] NET: Registered protocol family 1
[    0.205654] RPC: Registered named UNIX socket transport module.
[    0.205667] RPC: Registered udp transport module.
[    0.205676] RPC: Registered tcp transport module.
[    0.205685] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.205910] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.206139] omap-gpmc omap-gpmc: GPMC revision 6.0
[    0.225652] VFS: Disk quotas dquot_6.5.2
[    0.225723] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.226294] msgmni has been set to 1000
[    0.229419] alg: No test for stdrng (krng)
[    0.229497] io scheduler noop registered
[    0.229508] io scheduler deadline registered
[    0.229605] io scheduler cfq registered (default)
[    0.231143] da8xx_lcdc da8xx_lcdc.0: GLCD: Found NHD-7.0-ATXI#-T-1 panel
[    0.241625] Console: switching to colour frame buffer device 100x30
[    0.248845] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    0.975849] console [ttyO0] enabled
[    0.980264] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    0.988224] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    0.996139] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    1.004044] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    1.011953] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    1.029904] brd: module loaded
[    1.038305] loop: module loaded
[    1.042248] i2c-core: driver [tsl2550] using legacy suspend method
[    1.048704] i2c-core: driver [tsl2550] using legacy resume method
[    1.055463] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.065912] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.073448] omap2-nand driver initializing
[    1.077803] info->phys_base 8000000
[    1.081506] ONFI flash detected
[    1.084925] ONFI param page 0 valid
[    1.088567] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron MT29F2G08ABAEAWP)
[    1.096923] omap2-nand: detected x8 NAND flash
[    1.101651] Page size 2048 Select ECC BCH8
[    1.105920] Nand ECC BCH8 HW
[    1.109156] Creating 8 MTD partitions on "omap2-nand.0":
[    1.114724] 0x000000000000-0x000000200000 : "SPL"
[    1.121561] 0x000000200000-0x000000400000 : "SPL.backup1"
[    1.128897] 0x000000400000-0x000000600000 : "SPL.backup2"
[    1.136280] 0x000000600000-0x000000800000 : "SPL.backup3"
[    1.143619] 0x000000800000-0x000000a00000 : "U-Boot"
[    1.150445] 0x000000a00000-0x000000c00000 : "U-Boot Env"
[    1.157737] 0x000000c00000-0x000001400000 : "Kernel"
[    1.165699] 0x000001400000-0x000010000000 : "File System"
[    1.213261] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[    1.221847] OneNAND driver initializing
[    1.226683] UBI: attaching mtd7 to ubi0
[    1.230696] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[    1.237270] UBI: logical eraseblock size:    126976 bytes
[    1.242909] UBI: smallest flash I/O unit:    2048
[    1.247813] UBI: sub-page size:              512
[    1.252637] UBI: VID header offset:          2048 (aligned 2048)
[    1.258902] UBI: data offset:                4096
[    1.362120] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
[    1.369117] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.392579] hub 1-1:1.0: USB hub found
[    1.396561] hub 1-1:1.0: 4 ports detected
[    1.702608] usb 1-1.1: new low-speed USB device number 3 using musb-hdrc
[    1.831096] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c077
[    1.838284] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.845915] usb 1-1.1: Product: USB Optical Mouse
[    1.850815] usb 1-1.1: Manufacturer: Logitech
[    2.885348] UBI: max. sequence number:       0
[    2.952364] UBI: volume 0 ("rootfs") re-sized from 1652 to 1857 LEBs
[    2.960056] UBI: attached mtd7 to ubi0
[    2.964014] UBI: MTD device name:            "File System"
[    2.969728] UBI: MTD device size:            236 MiB
[    2.974920] UBI: number of good PEBs:        1879
[    2.979821] UBI: number of bad PEBs:         9
[    2.984459] UBI: number of corrupted PEBs:   0
[    2.989088] UBI: max. allowed volumes:       128
[    2.993904] UBI: wear-leveling threshold:    4096
[    2.998802] UBI: number of internal volumes: 1
[    3.003441] UBI: number of user volumes:     1
[    3.008068] UBI: available PEBs:             0
[    3.012704] UBI: total number of reserved PEBs: 1879
[    3.017874] UBI: number of PEBs reserved for bad PEB handling: 18
[    3.024232] UBI: max/mean erase counter: 1/0
[    3.028677] UBI: image sequence number:  941521384
[    3.033760] UBI: background thread "ubi_bgt0d" started, PID 659
[    3.053986] CAN device driver inte**ce
[    3.057986] CAN bus driver for Bosch D_CAN controller 1.0
[    3.072976] d_can d_can.0: device registered (irq=52, irq_obj=53)
[    3.141872] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[    3.148323] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[    3.172711] davinci_mdio.0: probed
[    3.176264] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
[    3.192424] PPP generic driver version 2.4.2
[    3.203829] PPP BSD Compression module registered
[    3.208734] PPP Deflate Compression module registered
[    3.222919] usbcore: registered new inte**ce driver rtl8192cu
[    3.242143] usbcore: registered new inte**ce driver zd1201
[    3.248149] usbcore: registered new inte**ce driver cdc_ether
[    3.262884] usbcore: registered new inte**ce driver cdc_eem
[    3.281875] usbcore: registered new inte**ce driver dm9601
[    3.287731] cdc_ncm: 04-Aug-2011
[    3.291259] usbcore: registered new inte**ce driver cdc_ncm
[    3.297179] Initializing USB Mass Storage driver...
[    3.313289] usbcore: registered new inte**ce driver usb-storage
[    3.319549] USB Mass Storage support registered.
[    3.341774] usbcore: registered new inte**ce driver usbserial
[    3.348006] USB Serial support registered for generic
[    3.362120] usbcore: registered new inte**ce driver usbserial_generic
[    3.368927] usbserial: USB Serial Driver core
[    3.382056] USB Serial support registered for GSM modem (1-port)
[    3.393031] usbcore: registered new inte**ce driver option
[    3.398838] option: v0.7.2:USB Driver for GSM modems
[    3.423194]  gadget: Mass Storage Function, version: 2009/09/11
[    3.429373]  gadget: Number of LUNs=1
[    3.433202]  lun0: LUN: removable file: (no medium)
[    3.438309]  gadget: Mass Storage Gadget, version: 2009/09/11
[    3.444317]  gadget: userspace failed to provide iSerialNumber
[    3.450403]  gadget: g_mass_storage ready
[    3.454606] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[    3.460193] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[    3.468029] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    3.475122] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.482662] usb usb2: Product: MUSB HDRC host driver
[    3.487836] usb usb2: Manufacturer: Linux 3.2.0 musb-hcd
[    3.493378] usb usb2: SerialNumber: musb-hdrc.0
[    3.513864] hub 2-0:1.0: USB hub found
[    3.517789] hub 2-0:1.0: 1 port detected
[    3.533783] mousedev: PS/2 mouse device common for all mice
[    3.553032] [wds tsc probe]x.min=140,x.max=3946,y.min=319,y.max=3865,x.inverted=0,y.inverted=1
[    3.562460] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input0
[    3.612371] rtc-ds1307 1-0068: rtc core: registered ds1307 as rtc0
[    3.618837] rtc-ds1307 1-0068: 56 bytes nvram
[    3.632270] i2c /dev entries driver
[    3.636644] Linux video capture inte**ce: v2.00
[    3.652449] usbcore: registered new inte**ce driver uvcvideo
[    3.658444] USB Video Class driver (1.1.1)
[    3.672188] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    3.683015] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[    3.702261] usbcore: registered new inte**ce driver bcm203x
[    3.708161] Bluetooth: Generic Bluetooth USB driver ver 0.6
[    3.722626] usbcore: registered new inte**ce driver btusb
[    3.744073] cpuidle: using governor ladder
[    3.763978] cpuidle: using governor menu
[    3.852731] input: Logitech USB Optical Mouse as /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.1/1-1.1:1.0/input/input1
[    3.872481] generic-usb 0003:046D:C077.0001: input: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-musb-hdrc.1-1.1/input0
[    3.893494] usbcore: registered new inte**ce driver usbhid
[    3.899302] usbhid: USB HID core driver
[    3.923085] tiadc tiadc: attached adc driver
[    3.945229] _regulator_get: 2-001b supply IOVDD not found, using dummy regulator
[    3.953050] _regulator_get: 2-001b supply DVDD not found, using dummy regulator
[    3.960717] _regulator_get: 2-001b supply AVDD not found, using dummy regulator
[    3.968387] _regulator_get: 2-001b supply DRVDD not found, using dummy regulator
[    3.978904] asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
[    4.344205] ALSA device list:
[    4.347316]   #0: AM335X EVM
[    4.350313] oprofile: hardware counters not available
[    4.355594] oprofile: using timer interrupt.
[    4.360070] nf_conntrack version 0.5.0 (8000 buckets, 32000 max)
[    4.366913] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.372619] TCP cubic registered
[    4.375984] NET: Registered protocol family 17
[    4.380629] can: controller area network core (rev 20090105 abi 8)
[    4.387178] NET: Registered protocol family 29
[    4.391850] can: raw protocol (rev 20090105)
[    4.396302] can: broadcast manager protocol (rev 20090105 t)
[    4.423495] Bluetooth: RFCOMM TTY layer initialized
[    4.428599] Bluetooth: RFCOMM socket layer initialized
[    4.433967] Bluetooth: RFCOMM ver 1.11
[    4.437874] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.443420] Bluetooth: BNEP filters: protocol multicast
[    4.448866] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    4.455503] Registering the dns_resolver key type
[    4.460492] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    4.468526] ThumbEE CPU extension supported.
[    4.473052] mux: Failed to setup hwmod io irq -22
[    4.478654] Power Management for AM33XX family
[    4.483534] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[    4.490193] Copied the M3 firmware to UMEM
[    4.494562] Cortex M3 Firmware Version = 0x181
[    4.557325] clock: disabling unused clocks to save power
[    4.573650] Detected MACID=d0:ff:50:24:fd:76
[    4.592110] cpsw: Detected MACID = d0:ff:50:24:fd:78
[    4.614382] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[    4.637117] rtc-ds1307 1-0068: setting system clock to 2014-12-29 20:27:06 UTC (1419884826)
[    4.814176] UBIFS: start fixing up free space
[   34.089774] UBIFS: free space fixup complete
[   34.304812] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[   34.311091] UBIFS: file system size:   234397696 bytes (228904 KiB, 223 MiB, 1846 LEBs)
[   34.319485] UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[   34.327117] UBIFS: media format:       w4/r0 (latest is w4/r0)
[   34.333203] UBIFS: default compressor: lzo
[   34.337469] UBIFS: reserved for root:  0 bytes (0 KiB)
[   34.343572] UBIFS error (pid 1): ubifs_read_node: bad node type (255 but expected 9)
[   34.351668] UBIFS error (pid 1): ubifs_read_node: bad node at LEB 850:14240, LEB mapping status 1
[   34.360922] UBIFS error (pid 1): ubifs_iget: failed to read inode 1, error -22
[   34.432627] List of all partitions:
[   34.436326] 1f00            2048 mtdblock0  (driver?)
[   34.441598] 1f01            2048 mtdblock1  (driver?)
[   34.446909] 1f02            2048 mtdblock2  (driver?)
[   34.452191] 1f03            2048 mtdblock3  (driver?)
[   34.457464] 1f04            2048 mtdblock4  (driver?)
[   34.462745] 1f05            2048 mtdblock5  (driver?)
[   34.468014] 1f06            8192 mtdblock6  (driver?)
[   34.473296] 1f07          241664 mtdblock7  (driver?)
[   34.478560] No filesystem could mount root, tried:  ubifs
[   34.484210] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[   34.492832] Backtrace:
[   34.495421] [<c0017d68>] (dump_backtrace+0x0/0x110) from [<c04f4dbc>] (dump_stack+0x18/0x1c)
[   34.504226]  r6:df024006 r5:c06c93d4 r4:c07587d0 r3:c06f9088
[   34.510152] [<c04f4da4>] (dump_stack+0x0/0x1c) from [<c04f4e2c>] (panic+0x6c/0x1a0)
[   34.518157] [<c04f4dc0>] (panic+0x0/0x1a0) from [<c0699d3c>] (mount_block_root+0x20c/0x228)
[   34.526868]  r3:df02df4c r2:df02df78 r1:df02df78 r0:c05efdb0
[   34.532793]  r7:00008000
[   34.535439] [<c0699b30>] (mount_block_root+0x0/0x228) from [<c0699fd0>] (prepare_namespace+0xac/0x1e0)
[   34.545158] [<c0699f24>] (prepare_namespace+0x0/0x1e0) from [<c069990c>] (kernel_init+0x124/0x130)
[   34.554506]  r5:c06d5644 r4:c06d5644
[   34.558256] [<c06997e8>] (kernel_init+0x0/0x130) from [<c0041740>] (do_exit+0x0/0x67c)
[   34.566517]  r5:c06997e8 r4:00000000
到[34.566517]就无法继续了,我是用光盘带的系统,请帮下我
 楼主| 发表于 2014-12-30 18:35:55 | 显示全部楼层
这个bbs没人了?我自己编译的ubi.img也是这样的问题,错误都在下面几行:
6万
发表于 2014-12-31 15:43:20 | 显示全部楼层
楼主还是打下技术支持电话吧,0312-3119192,电话里说的可能更清楚一些
GMT+8, 2026-9-21 04:58
